So part of my OpenHAB fun so far has been to set a rule that enforces what I feel proper temperature settings should be in the house. Now that he seasons are shifting I see the need to maybe adjust those to new baseline numbers and I want to do this via the GUI and not manually setting a number by editing the default.rules file every time.
My thinking is I create three new items:
Number TargetTemp "Enforced Temp [%.1f °F]" (NestDetails)
Number TargetTempLow "Enforced Temp Low [%.1f °F]" (NestDetails)
Number TargetTempHigh "Enforced Temp HIgh [%.1f °F]" (NestDetails)
All they do is hold the number of the actual temperature that the rules use to enforce. I would like to be able to increase them and decrease them as needed much like the Setpoint item.
My problem is that if I define them as a setpoint in the sitemap, they show up on the main page. I don’t want them there for obvious reasons. I want it buried 3 levels deep in Group Nest → Group NestDetails. I set them up how I think they should look, but I can’t toggle the numbers. It just displays them. Furthermore, explicitly using the following in the sitemap yields the controls I want, but they are at the top level.
Setpoint item=TargetTemp label="Enforced Temp [%.1f °F]" (NestDetails) minValue=60 maxValue=80 step=1 visibility=[Nest_hvac_mode=="cool"]
Setpoint item=TargetTempHigh label="Enforced Temp High [%.1f °F]" (NestDetails) minValue=70 maxValue=80 step=1 visibility=[Nest_hvac_mode=="heat-cool"]
Setpoint item=TargetTempLow label="Enforced Temp Low [%.1f °F]" (NestDetails) minValue=60 maxValue=70 step=1 visibility=[Nest_hvac_mode=="heat-cool"]
In short,
I want the Enforced temp items to show up ONLY with group NestDetails and with the ability to change the number. What am I doing wrong?
Here are the full item, sitemap and screenshots for reference
Default.items
Group Nest
Group Living_Room
Group Master_Bedroom
Group Kids_Bedroom
Group Astro
Group NestDetails "Nest Details" <temperature> (Nest)
/*Nest */
Number NestAmbTemp "Current Temp [%.1f °F]" (Nest,NestDetails) { nest="<[thermostats(Hallway).ambient_temperature_f]" }
Number NestHumidity "Humidity [%d %%]" (Nest,NestDetails) { nest="<[thermostats(Hallway).humidity]" }
String Nest_hvac_state "HVAC is currently... [%s]" (Nest,NestDetails) { nest="<[thermostats(Hallway).hvac_state]" }
String Nest_hvac_mode "HVAC Mode [%s]" (NestDetails) { nest="=[thermostats(Hallway).hvac_mode]"}
DateTime Nest_last_connection "Last Connection [%1$tm/%1$td/%1$tY %1$tH:%1$tM:%1$tS]" <calendar> (NestDetails) { nest="<[thermostats(Hallway).last_connection]" }
Switch Nest_has_leaf "Has Leaf [%s]" (NestDetails) { nest="<[thermostats(Hallway).has_leaf]" }
Number Nest_target_temperature_f "Target Temperature [%.1f °F]" (Nest,NestDetails) { nest="=[thermostats(Hallway).target_temperature_f]" }
Number Nest_target_temperature_high_f "Target Temperature High [%.1f °F]" (Nest,NestDetails) { nest="=[thermostats(Hallway).target_temperature_high_f]" }
Number Nest_target_temperature_low_f "Target Temperature Low [%.1f °F]" (Nest,NestDetails) { nest="=[thermostats(Hallway).target_temperature_low_f]" }
Switch Nest_fan_timer_active "Fan Timer Active [%s]" (NestDetails) { nest="=[thermostats(Hallway).fan_timer_active]" }
DateTime Nest_fan_timer_timeout "Fan Timer Timeout [%1$tm/%1$td/%1$tY %1$tH:%1$tM:%1$tS]" <calendar> (NestDetails) { nest="<[thermostats(Hallway).fan_timer_timeout]" }
/*Lights */
Dimmer Light_LR_Dimmer "Living Room Dimmer [%d %%]" (Living_Room) { zwave="5:command=SWITCH_MULTILEVEL" }
Dimmer Light_MB_Dimmer "Master Room Dimmer [%d %%]" (Master_Bedroom) { zwave="4:command=SWITCH_MULTILEVEL" }
Dimmer Light_KR_Dimmer "Kids Room Dimmer [%d %%]" (Kids_Bedroom) { zwave="7:command=SWITCH_MULTILEVEL" }
/*Astro */
DateTime Sunrise_Time "Sunrise [%1$tH:%1$tM]" (Astro) {astro="planet=sun, type=rise, property=start"}
Switch Sunrise_Event (Astro) {astro="planet=sun, type=rise, property=start"}
DateTime Sunset_Time "Sunset [%1$tH:%1$tM]" (Astro) {astro="planet=sun, type=set, property=end"}
Switch Sunset_Event (Astro) {astro="planet=sun, type=set, property=end"}
Default.sitemap
sitemap default label=“My Home”
Frame label="Casa "{
Text item=NestAmbTemp labelcolor=[Nest_hvac_state==“cooling”=“BLUE”, Nest_hvac_state==“heating”=“RED” ]
Slider item=Light_LR_Dimmer label=“Living Room Light”
Slider item=Light_MB_Dimmer label=“Master Bedroom Light”
Slider item=Light_KR_Dimmer label=“Kids Bedroom Light”
Frame label=“HVAC”{
Setpoint item=Nest_target_temp_f label=“Temperature Setting [%.1f °F]” minValue=60 maxValue=80 step=1 visibility=[Nest_hvac_mode==“cool”]
Setpoint item=Nest_target_temperature_high_f label=“Max Temperature Setting [%.1f °F]” minValue=70 maxValue=80 step=1 visibility=[Nest_hvac_mode==“heat-cool”]
Setpoint item=Nest_target_temperature_low_f label=“Min Temperature Setting [%.1f °F]” minValue=60 maxValue=70 step=1 visibility=[Nest_hvac_mode==“heat-cool”]
Text item=Nest_hvac_state label=“HVAC is currently…[%s]”
Group item=Nest label=“Nest” icon=“temperature”
Setpoint item=TargetTemp label=“Enforced Temp [%.1f °F]” (NestDetails) minValue=60 maxValue=80 step=1 visibility=[Nest_hvac_mode==“cool”]
Setpoint item=TargetTempHigh label=“Enforced Temp High [%.1f °F]” (NestDetails) minValue=70 maxValue=80 step=1 visibility=[Nest_hvac_mode==“heat-cool”]
Setpoint item=TargetTempLow label=“Enforced Temp Low [%.1f °F]” (NestDetails) minValue=60 maxValue=70 step=1 visibility=[Nest_hvac_mode==“heat-cool”]
Frame label=“Astro”{
Text item=Sunrise_Time
Text item=Sunset_Time
