I’ve migrated from Windows OH2 to RPi4 OH3, and the serial port interaction is a little different than I’m used to. On Windows, I simply had this line in an items file:
String NX8V2_Panel “Security System” (Security) {serial=“COM4”}
Does anyone know how I can tell what serial port I’m connected to on RPi? My ZWave device is connected to /dev/ttyACM0. I have a rule already that triggers on “Item NX8V2_Panel received update”, which reads the buffer via NX8V2_Panel.status, and sends commands via NX8V2_Panel.sendCommend, so the one item takes care of all the 2-way communication with the alarm panel.
Do I need to be concerned with the config menu? i.e.:
(all RPi) Disable serial console to give room for HATs
(RPi3/4) move Bluetooth to mini UART
I got a little further. I figured out that /dev/ttyUSB0 is the port in question. I can use the “screen /dev/ttyUSB0” command in Linux to get feedback from the alarm panel, so I know that part is working. Yet, in OH3, the serial port buffer doesn’t seem to be getting any data back. My items file now reads:
