Trying to install OH 2 beta 4 on OpenEnergyMonitor image
Hi all,
I have the OpenEnergyMonitor image as a base (Jessie Lite, OH1.8, Node-Red, emonCS)
See: https://community.openenergymonitor.org/t/emonsd-03may16-release/
I removed openhab-runtime via apt-get and I installed the Oracle Java JDK and OpenHAB 2 through apt-get (sudo apt-get install openhab2-offline)
When I try to run OH2 I get the following error log:
pi@emonpi:~ $ sudo systemctl status openhab2.service
● openhab2.service - openHAB 2 - empowering the smart home
   Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled)
   Active: deactivating (stop) (Result: exit-code) since Thu 2016-09-29 09:35:53 UTC; 665ms ago
     Docs: http://docs.openhab.org
           https://community.openhab.org
  Process: 4435 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=255)
 Main PID: 4435 (code=exited, status=255);         : 4559 (karaf)
   CGroup: /system.slice/openhab2.service
           └─control
             ├─4559 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf stop
             ├─4656 /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java -version
             └─4657 grep ^IBM
Sep 29 09:35:52 emonpi systemd[1]: Started openHAB 2 - empowering the smart home.
Sep 29 09:35:52 emonpi start.sh[4435]: Launching the openHAB runtime...
Sep 29 09:35:53 emonpi start.sh[4435]: /var/log/openhab2/openhab.log (No such file or directory)
Sep 29 09:35:53 emonpi systemd[1]: openhab2.service: main process exited, code=exited, status=255/n/a
Sep 29 09:35:53 emonpi stop[4559]: stop: Ignoring predefined value for KARAF_HOME
Any idea’s what this Karaf thing is?
Karaf info here: Overview (basically: it is used by OH2 as the main runtime container)
Not sure what is wrong here…
I have a hunch… try checking your folder permissions (example: check the permissions of the /var/log/openhab2 folder. It should be owned by the user openhab (not root).) Maybe some permissions are messed up due to the previous installation of OH1.
BR,
Dimitris
Indeed, funny enough, I don’t have a openhab2 folder…
pi@emonpi:/var/log $ ls -l
total 10312
drwxr-xr-x 2 root    adm          60 Sep 28 21:00 apache2
-rw-r----- 1 root    adm      370016 Sep 29 16:01 auth.log
-rw------- 1 root    utmp        384 Sep 29 16:00 btmp
-rw-r----- 1 root    adm     1119185 Sep 29 16:01 daemon.log
-rw-r----- 1 root    adm     1176003 Sep 29 15:17 daemon.log.1
-rw-r----- 1 root    adm     1527289 Sep 29 14:17 daemon.log.2
-rw-r----- 1 root    adm        1014 Sep 28 21:00 debug
-rw-rw-rw- 1 root    root     935686 Sep 29 16:01 emoncms.log
drwxr-xr-x 2 emonhub root        100 Sep 29 14:17 emonhub
drwxr-xr-x 2 pi      root         60 Sep 28 21:00 emonpilcd
-rw-r----- 1 root    adm      509984 Sep 29 16:00 kern.log
drwxr-xr-x 2 pi      pi           80 Sep 29 15:17 logrotate
-rw-r----- 1 root    adm      508172 Sep 29 16:00 messages
-rw-rw-rw- 1 root    root          0 Sep 28 21:00 mqtt_input.log
drwxr-xr-x 2 mysql   adm          60 Sep 28 21:00 mysql
-rw-rw-rw- 1 root    root          0 Sep 28 21:00 mysql.log
drwxr-xr-x 2 openhab openhab      40 Sep 28 21:00 openhab
drwxr-xr-x 2 redis   redis        60 Sep 28 21:00 redis
-rw-rw-rw- 1 root    root          0 Sep 28 21:00 service-runner.log
-rw-r----- 1 root    adm     1142788 Sep 29 16:01 syslog
-rw-r----- 1 root    adm     1208341 Sep 29 15:17 syslog.1
-rw-r----- 1 root    adm     1559261 Sep 29 14:17 syslog.2
-rw-r----- 1 root    adm      462292 Sep 29 16:00 ufw.log
-rw-rw-r-- 1 root    utmp       3456 Sep 29 16:00 wtmp
When I manually create this folder and Chown the right rights to it, OpenHAB 2 works.
But after a reboot the folder is deleted and OpenHAB 2 won’t start before re-creating the folder and put the filesystem back into read-write mode ( rpi-rw ). I think there are some specific configurations (by the OpenEnergyMonitor team) to run in Read-Only mode.
The openhab user does not have permission to create/write to log files in /var/log.
I think I have to do this:
Read-only filesystem
If you want to run openHAB on emonPi with read-only file system you will need to mount /var/lib/openhab as tempfs in RAM
$ sudo sh -c "echo 'tmpfs           /var/lib/openhab   tmpfs   nodev,nosuid,size=20M,mode=1777        0    0' >> /etc/fstab"
Also the correct ports will ned to be opend and RAM tmpfs log file created on startup. At the following to /etc/rc.local
sudo iptables -A INPUT -p tcp -m tcp --dport 8080 -j ACCEPT
sudo mkdir /var/log/openhab
sudo chmod 666 /var/log/openhab
/etc/init.d/openhab start
I confirm the steps from above won’t work. After a reboot my openhab2 folder is gone.
Sep 30 16:13:34 emonpi start.sh[988]: at java.lang.Thread.run(Thread.java:745)
pi@emonpi:~ $ tail -f /var/log/openhab2/openhab.log
  Unresolved requirement: Import-Package: org.eclipse.smarthome.ui.items; resolution:="optional"
    -> Export-Package: org.eclipse.smarthome.ui.items; bundle-symbolic-name="org.eclipse.smarthome.ui"; bundle-version="0.9.0.b1"; version="0.0.0"
       org.eclipse.smarthome.ui [130]
         Unresolved requirement: Import-Package: org.osgi.service.http
        at org.eclipse.osgi.container.Module.start(Module.java:434)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
    at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1498)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
    at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
    at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
    at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)[org.eclipse.osgi-3.10.2.v20150203-1939.jar:]
According to Glyn from OpenEnergyMonitor, he thinks this line is the issue:
Can I manually install this?
P.S.: Installing OH2 b4 on a clean Jessie Lite image works fine.
Anyone :wink:?
The OEM Image runs read only, and the logging is redirected with folders being created in the ramdrive /var/log at boot. My guess is you will need to create the openhab2 folder in /var/log before you start OH2. I think this has something to do with /home/pi/emonpi/rc.local_jessieminimal which is linked to /etc/rc.local Buried away on the OEM site will be a guide for building the image which may contain clues about how this all works. Personally I’d image backup the card, and then edit /home/pi/emonpi/rc.local_jessieminimal to change “openhab” into “openhab2” on line 11 of the file.
I run a version of that image that I created myself with OH 1.8 in its own folder off the RW Data Partition.
I’ve done that already :slight_smile:
I also asked the OEM guys: Install OpenHAB2 on emonSD / emonPi - #2 by glyn.hudson - Integrations - OpenEnergyMonitor Community
So it must be something else where OH2 needs to write to.
I’m interested in where this ends up - I took the easy way out on OH1 and ran it in a single RW folder at /home/pi/data/openhab with unnecessary logging turned off, and openhab.log redirected to the RAMDrive’d /tmp.
I may go the normal route when I go up to OH2, assuming the read only file system doesn’t make it stroppy
Ok, I retried. Took a clean image. How I started:
sudo apt-get update
sudo apt-get remove openhab-runtime
java -version
sudo apt-get install screen mc vim git htop
sudo apt-get install oracle-java8-jdk
sudo echo ‘deb http://dl.bintray.com/openhab/apt-repo2 testing main’ | sudo tee /etc/apt/sources.list.d/openhab2.list
sudo wget -qO - ‘Service End for Bintray, JCenter, GoCenter, and ChartCenter | JFrog’ | sudo apt-key add -
sudo apt-get update
sudo reboot
sudo nano ~/emonpi/rc.local_jessieminimal
Changed line 11 openhab to openhab2
Changed line 17 /var/log/openhab to /var/log/openhab2
sudo reboot
sudo nano ~/emonpi/fstab
Changed line 5 /var/lib/openhab to /var/lib/openhab2
added underneath line 5 tmpfs /usr/share/openhab2 tmpfs nodev,nosuid,size=40M,mode=1777 0 0
sudo systemctl start openhab2.service
sudo systemctl daemon-reload
sudo systemctl enable openhab2.service
sudo reboot
openHAB2 won’t run, also no log file in /var/log/openhab2
pi@emonpi:/ $ sudo systemctl status openhab2.service
Active: failed (Result: start-limit) since Mon 2016-10-10 22:23:32 UTC; 3s ago
Process: 32132 ExecStop=/usr/share/openhab2/runtime/karaf/bin/stop (code=exited, status=203/EXEC)
Process: 32130 ExecStart=/usr/share/openhab2/start.sh server (code=exited, status=203/EXEC)
Main PID: 32130 (code=exited, status=203/EXEC)
Oct 10 22:23:32 emonpi systemd[1]: Unit openhab2.service entered failed state.
Oct 10 22:23:32 emonpi systemd[1]: openhab2.service holdoff time over, scheduling restart.
Oct 10 22:23:32 emonpi systemd[1]: Stopping openHAB 2 - empowering the smart home…
Oct 10 22:23:32 emonpi systemd[1]: Starting openHAB 2 - empowering the smart home…
Oct 10 22:23:32 emonpi systemd[1]: openhab2.service start request repeated too quickly, refusing to start.
Oct 10 22:23:32 emonpi systemd[1]: Failed to start openHAB 2 - empowering the smart home.
Then again, a sudo reboot and a sudo apt-get upgrade. Same result .
Not sure if this will help, but try adding more space to your /usr/share/openhab2 mount (and then re-install OH2).
In my system, it takes 56M and it is a new installation:
root@openhab:/usr/share/openhab2# du -h --max-depth=1
56M	./runtime
4.0K	./bin
8.0K	./addons
56M	.
Try also the following: set DEBUG=true (or on?) in /etc/default/openhab2 and try to see if the log file gets populated (tail -f /var/log/openhab2/openhab.log)
On the other hand… remember that mounting this folder (/usr/share/openhab2) into ramdisk means that all files in that mount will be deleted upon reboot… and as a result, the start script will fail.
BR,
Dimitris
Correct, it was not nescessary to mount /usr/share/openhab2 to the ramdisk.
I removed it from fstab and now I’m a little bit further.
pi@emonpi:~ $ sudo systemctl status openhab2.service -l
   Active: active (running) since Tue 2016-10-11 09:08:36 UTC; 5min ago
 Main PID: 972 (karaf)
           ├─ 972 /bin/sh /usr/share/openhab2/runtime/karaf/bin/karaf server
           └─1592 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openhab2 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Xmx256m -Djava.awt.headless=true -Djava.endorsed.dirs=/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/jre/lib/endorsed:/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/lib/endorsed:/usr/share/openhab2/runtime/karaf/lib/endorsed -Djava.ext.dirs=/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/jre/lib/ext:/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/lib/ext:/usr/share/openhab2/runtime/karaf/lib/ext -Dkaraf.instances=/usr/share/openhab2/runtime/karaf/instances -Dkaraf.home=/usr/share/openhab2/runtime/karaf -Dkaraf.base=/var/lib/openhab2 -Dkaraf.data=/var/lib/openhab2 -Dkaraf.etc=/usr/share/openhab2/runtime/karaf/etc -Dkaraf.restart.jvm.supported=true -Djava.io.tmpdir=/var/lib/openhab2/tmp -Djava.util.logging.config.file=/var/lib/openhab2/etc/java.util.logging.properties -Dkaraf.startLocalConsole=false -Dkaraf.startRemoteShell=true -classpath /usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.diagnostic.boot-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.jaas.boot-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.apache.karaf.main-4.0.4.jar:/usr/share/openhab2/runtime/karaf/lib/boot/org.osgi.core-6.0.0.jar org.apache.karaf.main.Main
Oct 11 09:11:50 emonpi start.sh[972]: at org.eclipse.osgi.storage.Storage.save0(Storage.java:1038)
Oct 11 09:11:50 emonpi start.sh[972]: at org.eclipse.osgi.storage.Storage.save(Storage.java:1009)
Oct 11 09:11:50 emonpi start.sh[972]: at org.eclipse.osgi.internal.framework.StorageSaver$StorageSaverTask.run(StorageSaver.java:28)
Oct 11 09:11:50 emonpi start.sh[972]: at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
Oct 11 09:11:50 emonpi start.sh[972]: at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)
Oct 11 09:11:51 emonpi start.sh[972]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)
Oct 11 09:11:51 emonpi start.sh[972]: at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)
Oct 11 09:11:51 emonpi start.sh[972]: at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
Oct 11 09:11:51 emonpi start.sh[972]: at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
Oct 11 09:11:51 emonpi start.sh[972]: at java.lang.Thread.run(Thread.java:745)
Again this: Unresolved requirement: Import-Package: org.osgi.service.http
