I want to use ther polly tts for my Sonos One Speaker. But ther is no sound at all. It looks like the mp3 file is created but the Sonos one does not want to play it. Does anyone have an idea why?
The log shows that a generated .mp3 file should be played, have you tried to listen to that file in another way? If such test would not produce a sound, the TTS is 't working.
As of the log, the actually played song got interrupted, correct?
Canāt say if the change to UNDEF of the āFernbedienungā is correct ( it does not sound so).
The change of volume should match your Config Setting of the Things Volume for Notifications. However your setting of 21 could be overheard.
The current song is interrupted and plays again after playing the tts mp3. Where can i find the mp3 file or how can i play the mp3 on another way? shouldnt the mp3 be a URL?
The TTS service creates this file. As I do not use Polly Iād have to search in the documentation as well in order to know where the file is stored.
If you copy that file to another machine( the device you are presently using?) with a connected speaker, you should be able to play it there.
I noticed that it doesnāt work āsometimesā, stopping the actually played music and trying the say command then helps. Reason is unknown to me ( there used to be a problem when the music was started via Alexa, like starting a radio station with a voicecommand instead of the sonosapp).
Edit:
Tested it at my system, the problem with a started radio station via voicecommand ( used ARD Mediathek) is back. If the radiostation is started via the Sonos App it works. If I remember it correctly the old problem was when another service ( not ARD Mediathek) was used by the Sonos player, this problem was solved, the change to ARD raised it again. I did not file an issue for that yet. Note that the music does NOT stop in this case.
I have now tried it with the radio playing, the playlist playing and without anything playing. When something is playing, it is paused and then resumed. I could not find the path for the MP3 file in the addon description.
I can play the files with the normal media player.
I noticed that the name in the log and the name on the filesystem are different.
Filesystem: a6f39546-7b48-4629-ac34-a47584b6b981.mp3
Log: Vicki_b1fdec37144d030b8b86a612b75dc865.mp3
Did another check on my system, this time with the channels Fernbedienung and volume linked to items.
Your line: " Item xxx_Fernbedienung changed from PAUSE to UNDEF" seems to indicate the culprit, on my system it changed to PLAY.
A solution is unknown to me, sorry for that.
Did you setup openHAB to use Polly and your desired voice under the menu āEinstellungen " āSpracheā( to be found in the section System Servicesā)?
Yes i set it up under āSpracheā i tried a new Rule with Blockly and barking.mp3 or doorbell.mp3 it does not work either. Perhabs there is something wrong with the Sonos Add In? I am able to use the Sonos speaker in Openhab like play pause and so on. Perhabs its the blockly rule?
No, your setup looks good to me. I added the above mentioned items only in order to see the same log-lines as you had.
Could you play one of the standard sounds? ( doorbell or bark)
Other then that I am out of clues.
An additional test would be moving one of the stored tts .mp3 files into the openHAB sounds directory and play it with the audio command from the console. If that plays well the different naming COULD be a cause.
