I try to add a rule which shall use “say” or “play a sound”. But the result is: silent
Openhab log: No compatible audio format found for TTS ‘voicerss’ and sink ‘javasound’
I defined the default audio-system.
When I try to play any sound directly via putty with aplay XYZ.wav - it works fine.
