I just tried automatically adding one of these devices to my configuration via the openHAB ZigBee Binding (3.0.0). The scan discovers and appears to recognise the switch and allocates 2 channels, 1 for each gang. So far all well and good.
The problem is that when I switch it on, either manually or via the associated Items switch point, it automatically switches itself off after 2 minutes. If I delete the “Thing” then it appears to work as a normal light switch, not timing out after 2 minutes, when I re-bind it the problem reappears. So I am thinking that either the switch has a built in timer which is only activated when bound, or the “Item” has a hidden expire timer, in either case I would like to be able to disable, or significantly increase, the timeout. Has anyone come across this, or a similar problem and if so can you point me in ther direction of resolving it.
Many thanks in advance.
