Tuya Air Quality on zigbee binding
Hello everyone,
I installed the new openhab5 on a new VM to test it.
I decided also to add a zigbee network to the zwave network (which works perfectly from OH1).
I read a bit and understood the differences between the zigbee binding (for certified devices) and zigbee2mqtt.
I decided to install traditional binding, is there a way to make it recognize sensors that are certainly not certified?
Example this:
Vendor: _TZE200_mja3fuja
I saw that it has several names but all the same:
Or will be impossibile?
Thanks!
If you are going to use non-standard devices zigbee2mqtt is a better bet.
@chris could possibly add this device, but the OH ZigBee binding generally only has standard devices.
yes, I understood that there are only standard devices. I didn’t understand if instead the non-standard ones can be added or if it is necessary to switch to the mqtt version.
