actual I start to integrate a Tuya device into my environment. Now I have the problem that the DP is a alphanumeric string (switch_1). If I want create a channel to this switch I can enter only a numeric DP and I’m not able to enter a string. Also the automatic discovery doesn’t work but the connection is still there. I can use the generic device or the developer device - same result.
On HA it works and I have no clue anymore. Is this a but or is it wanted or do I something wrong ? If I enter only 1 it doesn’t work.
I want use the official binding (ot the Smarthome/J) and the definition via UI.
I use OH 5.0.1 on a Raspberry.
Hope someone can help me.
bests, Christian
