Hi there,
Setup:
tuya-mqtt running, device type ‘RGBTWLight’
Device needs
tuya/ikeabulb05/hsb_state 32,100,100
tuya/ikeabulb05/dps/state {“24”:“002003e803e8”}
tuya/ikeabulb05/dps/24/state 002003e803e8
i need to convert HSB type from 32,100,100 to hex befor publish. Whats the best way to do it ? use tuya-mqqt device config:
commandMath: ‘…’ // but how to substring 3 values conver to hex and concat
openhab formatbeforpublish ? how ?
Please help
rossko57
(Rossko57)
April 23, 2022, 3:23pm
#2
Jacek_Kaczmarczyk:
formatbeforpublish
No, you cannot do maths there. You’ll need a scripted transformation. Search this forum for e.g. HSV → RGB transforms for ideas.
Sorry, did it without transformation. Tuya exposes a channel with can be directly used for that :
Working config:
Thing topic ikeabulb05 "IKEA Bulb 05" {
Channels:
Type switch : switch "Ikea Bulb 05 Switch" [ stateTopic="tuya/ikeabulb05/dps/20/state", commandTopic="tuya/ikeabulb05/dps/20/command", on="true", off="false"]
Type dimmer : dimmer "Ikea Bulb 05 Dimmer" [ stateTopic="tuya/ikeabulb05/dps/22/state", commandTopic="tuya/ikeabulb05/dps/22/command", min=10, max=1000, step=1]
Type string : work_mode "Ikea Bulb 05 Work Mode" [ stateTopic="tuya/ikeabulb05/dps/21/state", commandTopic="tuya/ikeabulb05/dps/21/command"]
Type number : color_temp "Ikea Bulb 05 ColorTemp" [ stateTopic="tuya/ikeabulb05/dps/23/state", commandTopic="tuya/ikeabulb05/dps/23/command", min=0, max=1000, step=1]
Type colorHSB : colour_data "Ikea Bulb 05 HSB colour data" [ stateTopic="tuya/ikeabulb05/hsb_state", commandTopic="tuya/ikeabulb05/hsb_command"]
Group gSwiatlo5 "Lampa 5" { homekit="Lighting", ga="Light" [ useKelvin=true, colorTemperatureRange="2200,4000", roomHint="Jadalnia"]}
Switch ZigbeeKitchenBulb5Switch "5 [%s]" <light> (gSwiatlo5) { homekit="Lighting.OnState", ga="lightPower", channel="mqtt:topic:mymqttbroker:ikeabulb05:switch"}
Number ZigbeeKitchenBulb5ColorTemperature "5 [%s]" <light> (gSwiatlo5) { homekit="Lighting.ColorTemperature" [minValue=50, maxValue=400],channel="mqtt:topic:mymqttbroker:ikeabulb05:color_temp"}
Color ZigbeeKitchenBulb5ColourData "5 HSB [%s]" <light> (gSwiatlo5) { homekit="Lighting.Hue, Lighting.Brightness, Lighting.Saturation", ga="lightColor", channel="mqtt:topic:mymqttbroker:ikeabulb05:colour_data"}
system
(system)
closed
June 5, 2022, 12:27am
#4
