This is my first try to install a docker image or container on my own.
For the first step (1) I understood that I had to provide a working folder which I named /home/fl/tuya-mqtt/ within wich there should already be a config subfolder.
Then: cd /home/fl/tuya-mqtt/ I could issue the command:
docker run -it --rm -v $(pwd)/config:/config ghcr.io/mwinters-stuff/tuya-mqtt-docker:latest
Things did not went well and many error messages came out.
How do I clean this docker container and install it properly?
One of the advantages of Docker is the containers don’t save anything. Every time you update the image or change the arguments pass while starting the container results in a brand-new container with nothing from any other containers you may have created.
The way to store data to be reused by new containers (e.g. configuration, data, etc) one mounts volumes into the container. When the container writes to a given folder (e.g. /config) that gets saved to a volume so if you start a new container with the same volume mounted it starts with all the data you need to save.
Therefore, to start a new fresh container, just mount a new fresh volume.
Trying to reinstall tuya-mqtt-docker, here is what I get:
fl@Satellite-Z930:~/tuya-mqtt$ docker run -it --rm -v $(pwd)/config:/config Package tuya-mqtt-docker · GitHub
Devices file not found!
tuya-mqtt:error SyntaxError: JSON5: invalid end of input at 1:1
tuya-mqtt:error at syntaxError (/home/node/tuya-mqtt/node_modules/json5/lib/parse.js:1083:17)
tuya-mqtt:error at invalidEOF (/home/node/tuya-mqtt/node_modules/json5/lib/parse.js:1032:12)
tuya-mqtt:error at Object.start (/home/node/tuya-mqtt/node_modules/json5/lib/parse.js:821:19)
tuya-mqtt:error at Object.parse (/home/node/tuya-mqtt/node_modules/json5/lib/parse.js:32:32)
tuya-mqtt:error at main (/home/node/tuya-mqtt/tuya-mqtt.js:95:31)
tuya-mqtt:error at Object. (/home/node/tuya-mqtt/tuya-mqtt.js:177:1)
tuya-mqtt:error at Module._compile (internal/modules/cjs/loader.js:1063:30)
tuya-mqtt:error at Object.Module._extensions..js (internal/modules/cjs/loader.js:1092:10)
tuya-mqtt:error at Module.load (internal/modules/cjs/loader.js:928:32)
tuya-mqtt:error at Function.Module._load (internal/modules/cjs/loader.js:769:14) +0ms
tuya-mqtt:info Exit code: 1 +0ms
You might need to step back a bit and make sure you really understand docker and containers. There is no “installation” with containers. You pull the image. You run an instance of that image with a certain configuration, i.e. the container.
I know nothing about this tuya2mqtt container but usually the first time a container starts with an empty volume mounted to the right place, it will populate that folder with the files it needs to run. When that fails that is usually because of permission problems. The user stuff is running as inside the container doesn’t have permission to write to the volume mounted into the container.
Beyond that . Again I don’t know anything about this image.
Maybe irrelevant for your case, but if you are trying to integrate Tuya in OpenHAB, you could also try to install the SmartHome/J Tuya Binding instead messing up with Docker.
Smarthomej tuya binding has been merged into the main openhab distro in 5.0. I’d suggest using 5.0 milestone 2 for this reason. Installing smarthomej binding wasn’t straight forward for me.
Whilst you could do this, you would need to specify different port numbers (http, https, ssh, lsp). and separate conf/userdata/addons mounts. Might be a bit trickier.
It might be easier to:
Duplicate/backup your conf/userdata/addons, e.g.
cd ~/openhab
mkdir oh4
rsync -a conf userdata addons oh4
Then update your existing docker image (in your compose.yml) to image: openhab/openhab:snapshot
Then do docker compose up -d - it will automatically pull the latest snapshot and upgrade your installation.
IMO, it’s fine to use snapshot instead of M2. That’s what I use.
Thanks for sharing your experience! I also found the SmartHome/J Tuya Binding integrated into openHAB 5.0 to be a more straightforward solution compared to setting up tuya-mqtt in Docker. The discovery process was smoother, and it reduced the complexity of managing multiple containers. For anyone using Docker, running openHAB with the --net=host option helped with device discovery in my setup.
jimtng is the one who proposed to go for openhab 5 milestone 2 to get tuya-mqtt integration. Thanks to him.
For a beginner like me, your comment is not enough. Can you give some details, step by step to how you did link some of your devices.
I have been on openhab for almost two months and none of my devices or sensors are controlled by the openhab system: temperature, door, movement and alarm sirens.
Yes I already did before creating this thread. Tuya-mqqt hyperlink in the first post lead me to the detailed information to do so, a tuya-api thread. And I have stored the critical information somewhere.
Reading the information on Smarthomej tuya link in my precedent post, I realise that I will have to work with the oponhab main UI for next steps.
I am at my girlfriend’s house for the weekend. My system is at home. I will be back on the task tomorrow.
