the main topic looks like it is no longer being updated.
and these later ones are locked.
Can someone help me with this.
I have a fan which everything else is working except for speed
But when i set DPS 3 to anything it defaults back with 6.
So setting DPS 3 to 1 sends back a state of 6.
Only on this ceiling fan, i have an arlec tower fan too. and DPS 3 works perfectly fine on that.
this is my debug dump
tuya-mqtt:command Received MQTT message -> {"topic":"tuya/ceilingfan/dps/3/command","message":"3"} +0ms
tuya-mqtt:command Received command for DPS3: 3 +0ms
tuya-mqtt:tuyapi Set device bf5efd82c5fc58276b0eus -> {"dps":"3","set":3} +8s
TuyAPI SET Payload: +3s
TuyAPI {
TuyAPI devId: 'bf5efd82c5fc58276b0eus',
TuyAPI gwId: 'bf5efd82c5fc58276b0eus',
TuyAPI uid: '',
TuyAPI t: 1637230669,
TuyAPI dps: { '3': 3 }
TuyAPI } +0ms
TuyAPI Received data: 000055aa00000004000000070000000c00000000b82a1a070000aa55 +119ms
TuyAPI Parsed: +1ms
TuyAPI { payload: false, leftover: false, commandByte: 7, sequenceN: 4 } +0ms
TuyAPI Got SET ack. +1ms
TuyAPI Received data: 000055aa00000000000000080000004b00000000332e330000000000000f1c000000010592a7062c690d7406f13e7b8a5a551e5fc429e5c44237168011960117e8f6e704b37b5f8469ff419ba25ceabb7eb4118e21b5b50000aa55 +308ms
TuyAPI Parsed: +1ms
TuyAPI {
TuyAPI payload: { dps: { '3': '6' }, t: 1637230668 },
TuyAPI leftover: false,
TuyAPI commandByte: 8,
TuyAPI sequenceN: 0
TuyAPI } +1ms
tuya-mqtt:tuyapi Received JSON data from device bf5efd82c5fc58276b0eus -> {"3":"6"} +434ms
tuya-mqtt:state MQTT DPS JSON: tuya/ceilingfan/dps/state -> {"3":"6"} +9s
mqttjs:client publish :: message `{"3":"6"}` to topic `tuya/ceilingfan/dps/state` +439ms
mqttjs:client publish :: qos 1 +0ms
mqttjs:client MqttClient:publish: packet cmd: publish +0ms
mqttjs:client _sendPacket :: (mqttjs_390ec969) :: start +0ms
mqttjs:client storeAndSend :: store packet with cmd publish to outgoingStore +1ms
mqttjs:client nop :: undefined +0ms
mqttjs:client sendPacket :: packet: {
mqttjs:client cmd: 'publish',
mqttjs:client topic: 'tuya/ceilingfan/dps/state',
mqttjs:client payload: '{"3":"6"}',
mqttjs:client qos: 1,
mqttjs:client retain: false,
mqttjs:client messageId: 42234,
mqttjs:client dup: false
mqttjs:client } +0ms
mqttjs:client sendPacket :: emitting `packetsend` +1ms
mqttjs:client sendPacket :: writing to stream +0ms
mqtt-packet:writeToStream generate called +9s
mqtt-packet:writeToStream generate: packet.cmd: publish +0ms
mqtt-packet:writeToStream publish: packet: { cmd: 'publish', topic: 'tuya/ceilingfan/dps/state', payload: '{"3":"6"}', qos: 1, retain: false, messageId: 42234, dup: false } +1ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 26> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 25 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 19> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 42234 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer a4 fa> +0ms
mqtt-packet:writeToStream publish: payload: '{"3":"6"}' +0ms
mqttjs:client sendPacket :: writeToStream result true +3ms
mqttjs:client _sendPacket :: (mqttjs_390ec969) :: end +1ms
tuya-mqtt:state MQTT DPS3: tuya/ceilingfan/dps/3/state -> 6 +7ms
mqttjs:client publish :: message `6` to topic `tuya/ceilingfan/dps/3/state` +0ms
mqttjs:client _sendPacket :: (mqttjs_390ec969) :: start +1ms
mqttjs:client storeAndSend :: store packet with cmd publish to outgoingStore +0ms
mqttjs:client topic: 'tuya/ceilingfan/dps/3/state',
mqttjs:client payload: '6',
mqttjs:client messageId: 42235,
mqtt-packet:writeToStream generate called +3ms
mqtt-packet:writeToStream generate: packet.cmd: publish +1ms
mqtt-packet:writeToStream publish: packet: { cmd: 'publish', topic: 'tuya/ceilingfan/dps/3/state', payload: '6', qos: 1, retain: false, messageId: 42235, dup: false } +0ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 20> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 27 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 1b> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 42235 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer a4 fb> +0ms
mqtt-packet:writeToStream publish: payload: '6' +0ms
mqttjs:client sendPacket :: writeToStream result true +4ms
mqttjs:client _sendPacket :: (mqttjs_390ec969) :: end +0ms
mqttjs:client writable stream :: parsing buffer +2ms
