Hi everyone, I reopen a discussion of a closed post (I have read various posts but I have not been able to solve the problem). I’m having trouble getting tuya-mqtt to work, if I run “DEBUG = * node tuya-mqtt.js” I get this result:
"tdanyele@ubuntu:~/tuya-mqtt$ DEBUG=* node tuya-mqtt.js
mqttjs connecting to an MQTT broker… +0ms
mqttjs:client MqttClient :: options.protocol mqtt +0ms
mqttjs:client MqttClient :: options.protocolVersion 4 +0ms
mqttjs:client MqttClient :: options.username +0ms
mqttjs:client MqttClient :: options.keepalive 60 +1ms
mqttjs:client MqttClient :: options.reconnectPeriod 1000 +0ms
mqttjs:client MqttClient :: options.rejectUnauthorized undefined +0ms
mqttjs:client MqttClient :: options.topicAliasMaximum undefined +0ms
mqttjs:client MqttClient :: clientId mqttjs_cc918d07 +0ms
mqttjs:client MqttClient :: setting up stream +2ms
mqtt-packet:parser _resetState: resetting packet, error, _list, and _stateCounter +0ms
mqttjs:client _setupStream :: calling method to clear reconnect +4ms
mqttjs:client _clearReconnect : clearing reconnect timer +0ms
mqttjs:client _setupStream :: using streamBuilder provided to client to create stream +0ms
mqttjs calling streambuilder for mqtt +13ms
mqttjs:tcp port 1883 and host localhost +0ms
mqttjs:client _setupStream :: pipe stream to writable stream +10ms
mqttjs:client _setupStream: sending packet connect
+1ms
mqttjs:client sendPacket :: packet: { cmd: ‘connect’ } +1ms
mqttjs:client sendPacket :: emitting packetsend
+3ms
mqttjs:client sendPacket :: writing to stream +0ms
mqtt-packet:writeToStream generate called +0ms
mqtt-packet:writeToStream generate: packet.cmd: connect +84ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 1f> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 4 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 04> +1ms
mqtt-packet:writeToStream writeString: MQTT +0ms
mqtt-packet:writeToStream writeNumberCached: number: 60 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 3c> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 15 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 0f> +0ms
mqtt-packet:writeToStream writeString: mqttjs_cc918d07 +0ms
mqtt-packet:writeToStream writeNumberCached: number: 0 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 00> +1ms
mqtt-packet:writeToStream writeString: +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 00> +0ms
mqttjs:client sendPacket :: writeToStream result true +90ms
mqttjs:client writable stream :: parsing buffer +10ms
mqtt-packet:parser parse: current state: _parseHeader +117ms
mqtt-packet:parser _parseHeader: packet: Packet { cmd: ‘connack’, retain: false, qos: 0, dup: false, length: -1, topic: null, payload: null } +3ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 1 +2ms
mqtt-packet:parser parse: packet.length: -1, buffer list length: 3 +1ms
mqtt-packet:parser _parseVarByteNum +0ms
mqtt-packet:parser _parseVarByteNum: result: { bytes: 1, value: 2 } +1ms
mqtt-packet:parser _parseLength 2 +0ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 2 +0ms
mqtt-packet:parser parse: packet.length: 2, buffer list length: 2 +0ms
mqtt-packet:parser _parsePayload: payload BufferListStream {
mqtt-packet:parser _bufs: [ <Buffer 00 00> ],
mqtt-packet:parser length: 2,
mqtt-packet:parser _readableState:
mqtt-packet:parser ReadableState {
mqtt-packet:parser objectMode: false,
mqtt-packet:parser highWaterMark: 16384,
mqtt-packet:parser buffer: BufferList { head: null, tail: null, length: 0 },
mqtt-packet:parser length: 0,
mqtt-packet:parser pipes: null,
mqtt-packet:parser pipesCount: 0,
mqtt-packet:parser flowing: null,
mqtt-packet:parser ended: false,
mqtt-packet:parser endEmitted: false,
mqtt-packet:parser reading: false,
mqtt-packet:parser sync: true,
mqtt-packet:parser needReadable: false,
mqtt-packet:parser emittedReadable: false,
mqtt-packet:parser readableListening: false,
mqtt-packet:parser resumeScheduled: false,
mqtt-packet:parser paused: true,
mqtt-packet:parser emitClose: true,
mqtt-packet:parser autoDestroy: false,
mqtt-packet:parser destroyed: false,
mqtt-packet:parser defaultEncoding: ‘utf8’,
mqtt-packet:parser awaitDrain: 0,
mqtt-packet:parser readingMore: false,
mqtt-packet:parser decoder: null,
mqtt-packet:parser encoding: null },
mqtt-packet:parser readable: true,
mqtt-packet:parser _events: [Object: null prototype] {},
mqtt-packet:parser _eventsCount: 0,
mqtt-packet:parser _maxListeners: undefined,
mqtt-packet:parser _writableState:
mqtt-packet:parser WritableState {
mqtt-packet:parser finalCalled: false,
mqtt-packet:parser needDrain: false,
mqtt-packet:parser ending: false,
mqtt-packet:parser finished: false,
mqtt-packet:parser decodeStrings: true,
mqtt-packet:parser writing: false,
mqtt-packet:parser corked: 0,
mqtt-packet:parser bufferProcessing: false,
mqtt-packet:parser onwrite: [Function],
mqtt-packet:parser writecb: null,
mqtt-packet:parser writelen: 0,
mqtt-packet:parser bufferedRequest: null,
mqtt-packet:parser lastBufferedRequest: null,
mqtt-packet:parser pendingcb: 0,
mqtt-packet:parser prefinished: false,
mqtt-packet:parser errorEmitted: false,
mqtt-packet:parser bufferedRequestCount: 0,
mqtt-packet:parser corkedRequestsFree:
mqtt-packet:parser CorkedRequest { next: null, entry: null, finish: [Function] } },
mqtt-packet:parser writable: true,
mqtt-packet:parser allowHalfOpen: true } +1ms
mqtt-packet:parser _parseConnack +4ms
mqtt-packet:parser _parseConnack: complete +0ms
mqtt-packet:parser _parsePayload complete result: true +1ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 3 +0ms
mqtt-packet:parser _newPacket +0ms
mqtt-packet:parser _newPacket: parser emit packet: packet.cmd: connack, packet.payload: null, packet.length: 2 +0ms
mqttjs:client parser :: on packet push to packets array. +14ms
mqtt-packet:parser _newPacket: new packet +1ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 4 +0ms
mqtt-packet:parser parse: packet.length: -1, buffer list length: 0 +0ms
mqtt-packet:parser parse: exited while loop. packet: -1, buffer list length: 0 +0ms
mqttjs:client work :: getting next packet in queue +1ms
mqttjs:client work :: packet pulled from queue +0ms
mqttjs:client _handlePacket :: emitting packetreceive +0ms
mqttjs:client _handleConnack +1ms
mqttjs:client _setupPingTimer :: keepalive 60 (seconds) +1ms
mqttjs:client connect :: sending queued packets +3ms
mqttjs:client deliver :: entry undefined +1ms
mqttjs:client _resubscribe +0ms
tuya-mqtt:info Connection established to MQTT server +0ms
mqttjs:client subscribe: array topic tuya/# +2ms
mqttjs:client subscribe: pushing topic tuya/#
and qos 0
to subs list +0ms
mqttjs:client subscribe :: resubscribe true +0ms
mqttjs:client subscribe :: call _sendPacket +1ms
mqttjs:client _sendPacket :: (mqttjs_cc918d07) :: start +0ms
mqttjs:client sendPacket :: packet: { cmd: ‘subscribe’,
mqttjs:client subscriptions: [ { topic: ‘tuya/#’, qos: 0 } ],
mqttjs:client qos: 1,
mqttjs:client retain: false,
mqttjs:client dup: false,
mqttjs:client messageId: 48017 } +1ms
+1ms
mqtt-packet:writeToStream generate called +36ms
mqtt-packet:writeToStream generate: packet.cmd: subscribe +0ms
mqtt-packet:writeToStream subscribe: packet: +1ms
mqtt-packet:writeToStream subscribe: writing to stream: [ [ [ <Buffer 80>, <Buffer 81> ], [ <Buffer 88>, <Buffer 89> ] ], [ [ <Buffer 82>, <Buffer 83> ], [ <Buffer 8a>, <Buffer 8b> ] ], [ [ <Buffer 84>, <Buffer 85> ], [ <Buffer 8c>, <Buffer 8d> ] ] ] +0ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 0b> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 48017 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer bb 91> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 6 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 06> +0ms
mqtt-packet:writeToStream writeString: tuya/# +0ms
mqttjs:client sendPacket :: writeToStream result true +4ms
mqttjs:client sendPacket :: invoking cb +0ms
mqttjs:client nop :: undefined +0ms
mqttjs:client subscribe: array topic homeassistant/status +0ms
mqttjs:client subscribe: pushing topic homeassistant/status
and qos 0
to subs list +0ms
mqttjs:client subscribe :: resubscribe true +1ms
mqttjs:client subscribe :: call _sendPacket +0ms
mqttjs:client subscriptions: [ { topic: ‘homeassistant/status’, qos: 0 } ],
mqttjs:client messageId: 48018 } +0ms
+1ms
mqtt-packet:writeToStream generate called +3ms
mqtt-packet:writeToStream subscribe: packet: +0ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 19> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 48018 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer bb 92> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 20 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 14> +1ms
mqtt-packet:writeToStream writeString: homeassistant/status +0ms
mqttjs:client sendPacket :: writeToStream result true +2ms
mqttjs:client sendPacket :: invoking cb +1ms
mqttjs:client subscribe: array topic hass/status +0ms
mqttjs:client subscribe: pushing topic hass/status
and qos 0
to subs list +0ms
mqttjs:client _sendPacket :: (mqttjs_cc918d07) :: start +2ms
mqttjs:client subscriptions: [ { topic: ‘hass/status’, qos: 0 } ],
mqttjs:client messageId: 48019 } +0ms
+1ms
mqtt-packet:writeToStream generate called +4ms
mqtt-packet:writeToStream writeVarByteInt: writing to stream: <Buffer 10> +1ms
mqtt-packet:writeToStream writeNumberCached: number: 48019 +0ms
mqtt-packet:writeToStream writeNumberCached: <Buffer bb 93> +0ms
mqtt-packet:writeToStream writeNumberCached: number: 11 +1ms
mqtt-packet:writeToStream writeNumberCached: <Buffer 00 0b> +0ms
mqtt-packet:writeToStream writeString: hass/status +1ms
mqttjs:client sendPacket :: writeToStream result true +3ms
mqttjs:client nop :: undefined +1ms
tuya-mqtt:tuyapi Search for device id 80637808c82b966a1765 +0ms
TuyAPI IP and ID are already both resolved. +0ms
tuya-mqtt:tuyapi Search for device id 0243461450029127e511 +3ms
TuyAPI IP and ID are already both resolved. +2ms
tuya-mqtt:tuyapi Search for device id 46483003bcddc23b6226 +0ms
tuya-mqtt:tuyapi Search for device id bf0b8123d92d73cbbawakk +1ms
tuya-mqtt:tuyapi Found device id 80637808c82b966a1765 +2ms
TuyAPI Connecting to 192.168.178.31… +2ms
tuya-mqtt:tuyapi Found device id 0243461450029127e511 +3ms
TuyAPI Connecting to 192.168.178.30… +2ms
tuya-mqtt:tuyapi Found device id 46483003bcddc23b6226 +0ms
TuyAPI Connecting to 192.168.178.40… +1ms
tuya-mqtt:tuyapi Found device id bf0b8123d92d73cbbawakk +1ms
TuyAPI Connecting to 192.168.178.41… +0ms
mqttjs:client writable stream :: parsing buffer +16ms
mqtt-packet:parser parse: current state: _parseHeader +46ms
mqtt-packet:parser _parseHeader: packet: Packet { cmd: ‘suback’, retain: false, qos: 0, dup: false, length: -1, topic: null, payload: null } +0ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 1 +6ms
mqtt-packet:parser parse: packet.length: -1, buffer list length: 14 +0ms
mqtt-packet:parser _parseVarByteNum +3ms
mqtt-packet:parser _parseVarByteNum: result: { bytes: 1, value: 3 } +0ms
mqtt-packet:parser _parseLength 3 +0ms
mqtt-packet:parser parse: state complete. _stateCounter is now: 2 +1ms
mqtt-packet:parser parse: packet.length: 3, buffer list length: 13 +0ms
mqtt-packet:parser _bufs: [ <Buffer bb 91 00 90 03 bb 92 00 90 03 bb 93 00> ],
mqtt-packet:parser length: 13,
mqtt-packet:parser allowHalfOpen: true } +0ms
mqtt-packet:parser _parseSuback +2ms
mqtt-packet:parser _parseNum: result: 48017 +2ms
mqtt-packet:parser _parseMessageId: packet.messageId 48017 +2ms
mqtt-packet:parser _parsePayload complete result: true +2ms
mqtt-packet:parser _newPacket +1ms
mqtt-packet:parser _newPacket: parser emit packet: packet.cmd: suback, packet.payload: null, packet.length: 3 +0ms
TuyAPI Connecting to 192.168.178.41… +1ms
TuyAPI Error event from socket. 192.168.178.41 { Error: connect EHOSTUNREACH 192.168.178.41:6668
at TCPConnectWrap.afterConnect [as oncomplete] (net.js:1107:14)
errno: ‘EHOSTUNREACH’,
code: ‘EHOSTUNREACH’,
syscall: ‘connect’,
address: ‘192.168.178.41’,
port: 6668 } +3s
tuya-mqtt:error Error: Error from socket
tuya-mqtt:error at Socket.client.on.err (/home/danyele/tuya-mqtt/node_modules/tuyapi/index.js:399:30)
tuya-mqtt:error at Socket.emit (events.js:198:13)
tuya-mqtt:error at emitErrorNT (internal/streams/destroy.js:91:8)
tuya-mqtt:error at emitErrorAndCloseNT (internal/streams/destroy.js:59:3)
tuya-mqtt:error at process._tickCallback (internal/process/next_tick.js:63:19) +13s
tuya-mqtt:error connect EHOSTUNREACH 192.168.178.41:6668 +2ms
tuya-mqtt:error Error connecting to device id bf0b8123d92d73cbbawakk…retry in 10 seconds. +1ms
TuyAPI Socket closed: 192.168.178.41 +4ms
TuyAPI Pinging 192.168.178.40 +4s
TuyAPI Pinging 192.168.178.30 +35ms
TuyAPI Pinging 192.168.178.31 +8ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +26ms
TuyAPI Parsed: +1ms
TuyAPI { payload: false, leftover: false, commandByte: 9, sequenceN: 0 } +0ms
TuyAPI Pong from 192.168.178.40 +1ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +39ms
TuyAPI Parsed: +0ms
TuyAPI { payload: false, leftover: false, commandByte: 9, sequenceN: 0 } +1ms
TuyAPI Pong from 192.168.178.31 +0ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +0ms
TuyAPI Parsed: +1ms
TuyAPI Pong from 192.168.178.30 +1ms
tuya-mqtt:tuyapi Search for device id bf0b8123d92d73cbbawakk +13s
TuyAPI IP and ID are already both resolved. +6s
tuya-mqtt:tuyapi Found device id bf0b8123d92d73cbbawakk +0ms
syscall: ‘connect’,
port: 6668 } +3s
tuya-mqtt:error connect EHOSTUNREACH 192.168.178.41:6668 +1ms
tuya-mqtt:error Error connecting to device id bf0b8123d92d73cbbawakk…retry in 10 seconds. +0ms
TuyAPI Socket closed: 192.168.178.41 +1ms
TuyAPI Pinging 192.168.178.40 +807ms
TuyAPI Pinging 192.168.178.30 +36ms
TuyAPI Pinging 192.168.178.31 +7ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +33ms
TuyAPI Parsed: +0ms
TuyAPI Pong from 192.168.178.40 +0ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +64ms
TuyAPI Parsed: +2ms
TuyAPI Pong from 192.168.178.30 +7ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +2ms
TuyAPI Parsed: +1ms
TuyAPI Pong from 192.168.178.31 +1ms
TuyAPI IP and ID are already both resolved. +9s
TuyAPI Pinging 192.168.178.40 +798ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +28ms
TuyAPI Parsed: +1ms
TuyAPI Pong from 192.168.178.30 +2ms
TuyAPI Parsed: +1ms
TuyAPI Received data: 000055aa00000000000000090000000c00000000b051ab030000aa55 +30ms
TuyAPI Parsed: +1ms
syscall: ‘connect’,
port: 6668 } +2s
TuyAPI Socket closed: 192.168.178.41 +5ms
^\Uscita (core dump creato)"
In mqtt explorer veco the lamp and the on - off controls but does not turn on.
I hope for your help thanks
