Tuya System Alarm WiFi + radio + GSM
Hello forum
What about binding to OpenHab something like this:
Full tittle from Ali
Tuya 433MHz WiFi 3G&4G Home Burglar&Security Alarm System APP Remote Control Wireless Alarm Host Kit With IP Camera Baby Monitor
Any idea?
Welcome to the community!
You might be able to communicate with this device using MQTT (search for “Tuya MQTT”), but you’re not likely to see a dedicated binding for it unless you build one yourself.
Personally, I would have concerns about installing a security system like this, both due to privacy and it’s actual effectiveness. If you’re really serious about security, it’s best to get a professional security system…not something off of AliExpress.
If you just want cameras, door sensors and motion sensors, then I’d suggest looking at the Zigbee-based Xiaomi devices, which are inexpensive and can be controlled with openHAB so that they don’t have direct access to the Internet. You could also go with Z-Wave devices if those are available in your area.
Thank you 4 your answer.
