I just got a Tuya TS0002 clone (Avatto ZWSM16-2) which is a 2 Gang Zigbee Switch Module. Installation in openHAB works fine, the device is discovered as “Unknown ZigBee Device” and a thing is created with 6 channels (Current, Metering Summation Delivered, two ON_OFF_LIGHT: Switch, Total Active Power, Voltage).
I added the two switches as points and tried to control the switch state via the WebGUI. However, every time, I turn on switch 1, switch 2 is turned on as well and the other way around. This means, the two switches are always in the same position, no matter what I do. This way, my roller shutter, which I’m trying to control, is not moving an inch.
Any ideas what I could do?
… supported by Zigbee2MQTT: AVATTO ZWSM16-2-Zigbee control via MQTT | Zigbee2MQTT
Two options:
- Post a fingerprint from your device (modifications to the Zigbee binding might be required).
- Install Zigbee2MQTT, MQTT broker, openHAB MQTT binding.
Getting Zigbee2MQTT and MQTT broker working is a pain. I would post a fingerprint if there is a docu how to do that …
Thanks for the docu link. Here is the fingerprint:
openhab> zigbee fingerprint 27140
|>| Node Descriptor
| |> Logical Type ROUTER
| |> MAC Capabilities [FULL_FUNCTION_DEVICE, MAINS_POWER, RECEIVER_ON_WHEN_IDLE]
| |> Stack Compliance 21
| |> Server Capabilities []
| |> Buffer Size 66
| |> Incoming Transfer Size 66
| |> Outgoing Transfer Size 66
|>| Power Descriptor
| |> Available Power Sources [MAINS]
| |> Current Power Source MAINS
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest SUCCESS
| |> IeeeAddressRequest SUCCESS
| |> ManagementLqiRequest SUCCESS
| |> ManagementRoutingRequest TIMEOUT
|>| Basic Information
| |> Generic Device Class
| |> Generic Device Type
| |> Manufacturer Name _TZ3000_mtnpt6ws
| |> Model Indentifier TS0002
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version 72
| |> Software Build ID
| |> Hardware Version 1
| |> Zcl Version 3
| |> Stack Version 0
| |>| Endpoint 1
| | |> Profile 0104 ZIGBEE_HOME_AUTOMATION
| | |> Device Type 0100 ON_OFF_LIGHT
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> 0000 ZCL Version >> UNSIGNED_8_BIT_INTEGER 3
| | | | | |> 0001 Application Version >> UNSIGNED_8_BIT_INTEGER 72
| | | | | |> 0002 Stack Version >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0003 HW Version >> UNSIGNED_8_BIT_INTEGER 1
| | | | | |> 0004 Manufacturer Name >> CHARACTER_STRING _TZ3000_mtnpt6ws
| | | | | |> 0005 Model Identifier >> CHARACTER_STRING TS0002
| | | | | |> 0006 Date Code >> CHARACTER_STRING
| | | | | |> 0007 Power Source >> ENUMERATION_8_BIT 1
| | | | | |> FFDE >> UNSIGNED_8_BIT_INTEGER 13
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 2
| | | | | |> FFFE Attribute Reporting Status >> ENUMERATION_16_BIT 0
| | | |>| Cluster 0003 Identify
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0004 Groups
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000 Scene Count >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0001 Current Scene >> UNSIGNED_8_BIT_INTEGER 0
| | | | | |> 0002 Current Group >> UNSIGNED_16_BIT_INTEGER 0
| | | | | |> 0003 Scene Valid >> BOOLEAN false
| | | | | |> 0004 Name Support >> BITMAP_8_BIT 0
| | | |>| Cluster 0006 On/Off
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000 On Off >> BOOLEAN false
| | | | | |> 4001 On Time >> UNSIGNED_16_BIT_INTEGER 0
| | | | | |> 4002 Off Wait Time >> UNSIGNED_16_BIT_INTEGER 0
| | | | | |> 5000 >> ENUMERATION_8_BIT 1
| | | | | |> 8001 >> ENUMERATION_8_BIT 1
| | | | | |> 8002 >> ENUMERATION_8_BIT 0
| | | |>| Cluster 0702 Metering
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0B04 Electrical Measurement
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster E000
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster E001
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 000A Time
| | | | |> Type Client [Output]
| | | | |> Unsupported locally
| | | |>| Cluster 0019 Ota Upgrade
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> 0000 Upgrade Server ID >> IEEE_ADDRESS FFFFFFFFFFFFFFFF
| | | | | |> 0001 File Offset >> UNSIGNED_32_BIT_INTEGER -1
| | | | | |> 0002 Current File Version >> UNSIGNED_32_BIT_INTEGER 72
| | | | | |> 0003 Current ZigBee Stack Version >> UNSIGNED_16_BIT_INTEGER 2
| | | | | |> 0004 Downloaded File Version >> UNSIGNED_32_BIT_INTEGER -1
| | | | | |> 0005 Downloaded ZigBee Stack Version >> UNSIGNED_16_BIT_INTEGER 65535
| | | | | |> 0006 Image Upgrade Status >> ENUMERATION_8_BIT 0
| | | | | |> 0007 Manufacturer ID >> UNSIGNED_16_BIT_INTEGER 4417
| | | | | |> 0008 Image Type ID >> UNSIGNED_16_BIT_INTEGER 65535
| | | | | |> 0009 Minimum Block Request Period >> UNSIGNED_16_BIT_INTEGER 0
| | | | | |> FFFD Cluster Revision >> UNSIGNED_16_BIT_INTEGER 3
| |>| Endpoint 2
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0004 Groups
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0005 Scenes
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | |>| Cluster 0006 On/Off
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | |>| Output Clusters
| |>| Endpoint 242
| | |> Profile A1E0 ZIGBEE_GREEN_POWER
| | |> Device Type 0061
| | |> Device Version 0
There are major differences between Endpoint 1 and Endpoint 2 in terms of supported clusters and supported attributes, which could explain the behavior. @chris Could you confirm this (and adjust the Zigbee binding if possible)?
What does zigbee nodes
say (cf. Aqara button not working anymore after OH3 upgrade - #15 by bartkummel)? Are there two different endpoints (EP)?
Here the output of zigbee nodes
openhab> zigbee nodes
Total known nodes in network: 2
Network Addr IEEE Address Logical Type State EP Profile Device Type Manufacturer Model
0 0000 E0798DFFFEB3D751 COORDINATOR ONLINE
27140 6A04 A4C13859E675C5A1 ROUTER ONLINE 1 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT _TZ3000_mtnpt6ws TS0002
2 ZIGBEE_HOME_AUTOMATION ON_OFF_LIGHT
242 ZIGBEE_GREEN_POWER 0061
Looks OK to me. Let’s wait for input from forum members more knowledgeable than me.
Would anybody be able to help here?
Okay, I got it working using zigbee2mqtt. I don’t like this solution because it takes up resources (close to 1GB of SD storage and half of my available RAM) but it works. I really hope the zigbee binding will be enhanced to support more devices, this way would more be a lot more resource efficient.
Mostly, I followed this guide: openHAB 3 - Zigbee über MQTT steuern - Hoerli.NET (german but can be translated well).
The tricky part at the end was to set the channels up correctly. I managed to get things working with the following channel config:
channels:
- id: Switch1
channelTypeUID: mqtt:switch
label: Switch1
description: ""
configuration:
commandTopic: zigbee2mqtt/TS0002/set
formatBeforePublish: '{"state_l1": "%s"}'
stateTopic: zigbee2mqtt/TS0002
transformationPattern: JSONPATH:$.state_l1
off: OFF
on: ON
- id: Switch2
label: Switch2
description: null
configuration:
formatBeforePublish: '{"state_l2": "%s"}'
transformationPattern: JSONPATH:$.state_l2
off: OFF
on: ON
TS0002 needs to be replaced with whatever your device friendly_name is in /opt/zigbee2mqtt/data/configuration.yaml
Hope this helps anyone …
