Hi, I’m using a similar device Woox R7048 Smart Humidity & Temperature Sensor
This device right now send only humidity data, in the web ui it seems to be online, but from cli it is offline.
openhab> zigbee nodes
Total known nodes in network: 2
Network Addr IEEE Address Logical Type State EP Profile Device Type Manufacturer Model
0 0000 000D6F000DD02839 COORDINATOR ONLINE
16068 3EC4 847127FFFE0323E1 END_DEVICE ONLINE 1 ZIGBEE_HOME_AUTOMATION TEMPERATURE_SENSOR _TZ3000_rusu2vzb TS0201
openhab> zigbee node 50014
IEEE Address : 847127FFFE0323E1
Network Address : 50014
Node Descriptor : NodeDescriptor [apsFlags=0, bufferSize=82, complexDescriptorAvailable=false, manufacturerCode=1002, logicalType=END_DEVICE, serverCapabilities=[], incomingTransferSize=82, outgoingTransferSize=82, userDescriptorAvailable=false, frequencyBands=[FREQ_2400_MHZ], macCapabilities=[REDUCED_FUNCTION_DEVICE], extendedEndpointListAvailable=false, extendedSimpleDescriptorListAvailable=false, stackCompliance=22]
Power Descriptor : PowerDescriptor [currentPowerMode=RECEIVER_ON_IDLE, availablePowerSources=[MAINS], currentPowerSource=MAINS, powerLevel=FULL]
Associations : []
Endpoints :
1 : Profile 0104 ZIGBEE_HOME_AUTOMATION
: Device Type 0302 TEMPERATURE_SENSOR
-> BASIC
-> POWER_CONFIGURATION
-> TEMPERATURE_MEASUREMENT
-> RELATIVE_HUMIDITY_MEASUREMENT
<- TIME
<- OTA_UPGRADE
Neighbors:
openhab> zigbee fingerprint 847127FFFE0323E1
Requesting ZCL Version
Requesting Application Version
Requesting Stack Version
Requesting HW Version
Requesting Manufacturer Name
Requesting Model Identifier
Requesting Date Code
Requesting Power Source
Requesting Generic Device Class
Requesting Generic Device Type
Requesting Product Code
Requesting Product URL
Requesting Location Description
Requesting Physical Environment
Requesting Device Enabled
Requesting Alarm Mask
Requesting Disable Local Config
Requesting SW Build ID
Device information for endpoint 3EC4/1
Node Info Value
Application Version 67
Date Code
HW Version 1
Manufacturer Name _TZ3000_rusu2vzb
Model Identifier TS0201
Stack Version 0
ZCL Version 3
`zigbee info 16068/1
|>| Node Descriptor
| |> Logical Type END_DEVICE
| |> MAC Capabilities [REDUCED_FUNCTION_DEVICE]
| |> Stack Compliance 22
| |> Server Capabilities []
| |> Buffer Size 82
| |> Incoming Transfer Size 82
| |> Outgoing Transfer Size 82
|>| Power Descriptor
| |> Available Power Sources [MAINS]
| |> Current Power Source MAINS
| |> Current Power Mode RECEIVER_ON_IDLE
| |> Power Level FULL
|>| ZDO
| |> ManagementBindRequest TIMEOUT
| |> IeeeAddressRequest SUCCESS
| |> ManagementLqiRequest SUCCESS
| |> ManagementRoutingRequest SUCCESS
|>| Basic Information
| |> Generic Device Type
| |> Manufacturer Name
| |> Model Indentifier
| |> Product Code
| |> Product URL
| |> Date Code
| |> Application Version
| |> Software Build ID
| |> Hardware Version
| |> Zcl Version
| |> Stack Version
| |>| Endpoint 1
| | |> Device Version 1
| | |>| Input Clusters
| | | |>| Cluster 0000 Basic
| | | | |> Type Server [Input]
| | | | |> Manufacturer Spec. No
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | |>| Attributes Supported
| | | | | |> FAILURE
| | | |>| Cluster 0001 Power Configuration
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | | |>| Cluster 0402 Temperature Measurement
| | | | |> Type Server [Input]
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> FAILURE
| | | |>| Cluster 0405 Relative Humidity Measurement
| | | | |> Type Server [Input]
| | | | |> Unsupported locally
| | |>| Output Clusters
| | | |>| Cluster 000A Time
| | | | |> Type Client [Output]
| | | | |> Unsupported locally
| | | |>| Cluster 0019 Ota Upgrade
| | | | |>| Commands Generated
| | | | | |> FAILURE
| | | | |>| Commands Received
| | | | |> FAILURE
| | | | | |> FAILURE
Now it seems to be up since one hour and sending temperature data every 5 minutes.
Can the send temperature time be adjusted?
I’m available for any test to fix this.
Thanks, BR
