I’m starting this as a bit of a generic question, not sure if there’s a method to get this working properly that I’ve missed or if this is a bug/issue.
I had some Feconn Zigbee lamps, this led me to openHAB so after some faff (buying an ember coordinator as the current WiFi/BLE/Zigbee gateways don’t work with openHAB) I got the Zigbee devices added directly to openHAB. These same devices added via the Smarthome/J Tuya binding showed channels for colours/scenes/modes etc. Adding them directly I only get colour, which when added to a room goes a bit mental and just randomly changes the colour until it is removed from a room. Moot point anyway as most channels are missing so not a lot I can do with it.
Following this I added all the lamps and Zigbee devices back through Tuya but now when they are discovered they ask for an IP address. Using the IP address of the gateway seems to work but seems that only the first 2 or 3 devices can connect. The rest of the devices show as offline with a brief flash to online every few seconds.
So before I start wading through pages and pages of settings and configs is anything of this known to work or is there a known issue with/is anyone else having issues with Tuya binding and Zigbee devices?
Bear in mind also, related to a couple of topics I’ve read about new users and marketing, that all these devices work fine in the Tuya Smart Life app (along with the Zigbee scene switches, switch/relay modules and thermostat etc) and does 95% of what I want. This is what openHAB is up against, I’ve spent days on openHAB and got effectively nowhere, versus a couple of hours with Tuya/Alexa and barring a couple of integrations/options regarding geofencing it “just works”.
