Tuya Zigbee Temperature & Humidity sensor TS0201 offers no temperature channel
  • Platform information:
    • OS: Ubuntu server
    • Java Runtime Environment: openJDK 17
    • openHAB version: 4.0.4
    • deconz zigbee gateway
Recently i bought a generic “multi-sensor” on Aliexpress to get temperature and humidity values. It’s a similar item to this: 2.4€ 78% OFF|Tuya WIFI Zigbee Temperatur und Feuchtigkeit Sensor Innen Hygrometer Controller Smart Home APP Überwachung Für Alexa Google Hause| | - AliExpress
I can pair the device with phoscon / deconz dongle and in the software it’s labeled “TZ3000 Multisensor”. Also i can get temperature, humidity and battery state without any problems.
So, as for every device, i wanted to add the ‘thing’ to obenhab for further configuration. It’s discovered automaticly but when i add it, i see the following channels:
  • humidity
  • last_updated
  • battery_level
  • battery_low
  • last_seen
obviously: there is no channel for temperature!
After searching a while i see not many information about such sensors, but last thread from feb '23 was like “look for other things related to the same device” and i tried, but there is no other thing.
So it’s pretty much like a channel is missing…
Is there way to ‘force’ openhab to get the temperature value from this device? Or any other fix/workaround?
