Just for reference:
Assuming you are using a recent Z-Wave binding:
If there are no differences, @chris could just copy the data for ZWA009@1.0-1.255 to a new ZWA009@12.0-255.255 (BTW, parameter 4/min value should be set to 30 for the ‘new’ ZWA009 and should be set to 900 for ZWA009@1.0-1.255).
Edit:
Details for firmware 12.01:
apella12
(Bob Eckhoff)
December 4, 2022, 2:31pm
42
Somewhat oddly there is only one ZWA009 in the DB. I don’t know the history but with one device the blog suggests 255.225 as the version. Anyway another option if the same is to just change that.
Most devices don’t use the firmware version, but some devices have different firmware versions with different features in the same device. The database handles this by introducing a new device and using a minimum and maximum version numbers that is applicable to the device. By default, a device should be configured with the maximum version to detect all new versions (ie set to 255.255). This means that new devices will work, even if new features are not supported without a database update. When a new device is made available, the existing device should be set to a max version lower than the new device, and the new device min version set appropriately.
History is important. There a three Aeotec devices that share the same ‘References’, see Two brand new Aeotec Z-Wave devices to add to the database - #29 by chris .
karlfife
(Karl Fife)
December 5, 2022, 6:34am
44
XML file for the new v12.1 FW for the ZWA009 is attached here:
network_dd296cb6__node_36.xml (14.7 KB)
FWIW:
The diff between v1.1 and v12.1 FW in my installation is here:
duneHilda$ diff network_dd296cb6__node_9.xml network_dd296cb6__node_36.xml
3c3
< <nodeId>9</nodeId>
> <nodeId>36</nodeId>
14c14
< <sleepDelay>1000</sleepDelay>
> <sleepDelay>500</sleepDelay>
144,153d143
< <commandClass>COMMAND_CLASS_BASIC</commandClass>
< <COMMAND__CLASS__BASIC>
< <version>0</version>
< <instances>0</instances>
< <control>false</control>
< <versionSupported>0</versionSupported>
< <isGetSupported>true</isGetSupported>
< </COMMAND__CLASS__BASIC>
< </entry>
< <entry>
264c254,256
< <reportedEvents/>
> <reportedEvents>
> <int>11</int>
> </reportedEvents>
321c313
< <batteryLevel>80</batteryLevel>
> <batteryLevel>100</batteryLevel>
361c353
< <applicationVersion>1.1</applicationVersion>
[network_dd296cb6__node_36.xml|attachment](upload://mB9Xm1pVYU29JctVqPDI6cwBAPu.xml) (14.7 KB)
> <applicationVersion>12.1</applicationVersion>
395,402c387,388
< <nodeNeighbors>
< <int>5</int>
< <int>7</int>
< <int>10</int>
< <int>12</int>
< <int>13</int>
< </nodeNeighbors>
< <lastReceived>2022-12-03 06:49:03.458 UTC</lastReceived>
> <nodeNeighbors/>
> <lastReceived>2022-12-05 00:40:00.220 UTC</lastReceived>
karlfife
(Karl Fife)
December 6, 2022, 1:02am
45
Annoying:
The site, the doc, the filenames… all show fw v12.01 but the firmware itself shows 12.1.
This version is meant to improve the use of aerQ Temperature and Humidity sensor listed as model ZWA009 with internal firmware V1.00 / V1.0 or V1.01 / V1.1 specifically.
So… v 1.01 and 1.1 are the same version
Is there anything else I can provide in order to assist creation of a new entry?
chris
(Chris Jackson)
December 6, 2022, 2:21am
46
Sadly, this is actually correct. Version numbers are read as two separate numbers - separated by a point. It’s actually a major and minor version - so in this case, the major version is 1, and the minor version is 1 - 1.1, 1.01, 1.001 are all the same.
I know this is confusing (and anoying), but it’s actually quite common, and is exactly the same as used in other software - such as openHAB . You’ll get other confusing issues such as version 2.2 is actually older than version 2.12 - since this is actually version 2, minor version 12 compared to minor version 2.
karlfife
(Karl Fife)
December 6, 2022, 2:45am
47
What remains to be done:
@chris could copy the old ZWA009 to the new one and adapt the ‘Version’ of the new device (punch a hole in the version space of ZWA009 …)
or
@karlfife could modifiy the new XML file so that it points to a non-existent device (use 0xAAAA:0xBBBB or something similar), upload it to the Z-Wave database, augment it in the Z-Wave database, set the ‘Version’ of the new ZWA009 to 12.1-12.255 and fix the ‘References’ (0xAAAA:0xBBBB to 0002:0009,0102:0009,0202:0009). Don’t forget to request a review.
chris
(Chris Jackson)
December 6, 2022, 7:09pm
49
Just to clarify - I can’t (easily) copy one complete device to another. I (and anyone else) can copy the configuration/associations from one device to another, but the XML still needs to be used to generate the device description first (eg this generates the channels etc).
karlfife
(Karl Fife)
December 19, 2022, 5:40am
50
I’ve uploaded the XML file above, as taken from my OH3 instance.
Is the augmenting and uploading part something that should be done by someone with the device in-hand? e.g. With the device paired to an OH3 instance, augmenting it in OH, then exporting (or re-exporting in this case)?
If so, I’m happy to do it, but I may need some guidance on what the steps are, and how it’s done.
Otherwise, if someone who already knows how to make the change and upload it, might be a better person than I.
I’m happy to guide you through the necessary steps. Basically, you need to transfer the information from the device manual to the Z-Wave database - and here you are in the fortunate position that a very similar device already exists in the Z-Wave database.
Could you please provide a link to the database entry you just created?
Mclupo
(Wolf Kroenert )
February 3, 2023, 3:35pm
52
I got two sensors zwa009 , firmware 12.1. Is there any way to free them from „unknown device“ state in OH 3.4.1. at the moment?
apella12
(Bob Eckhoff)
February 3, 2023, 8:02pm
53
There are entries in the DB for zwa009 although I’m sure about your firmware number. If you have a fully configured device there should be a xml in var/lib/openhab/zwave (userdata/zwave). Also probably on the UI page under thing properties. Can you pick out the Deviceid and the devicetype ? Are you getting some sort of string like 0371:0202:0009:12.1 ?? Could be a new version or possibly not fully initialized.
edit: Just reviewed the history of this again. I do not think your device is in the DB. I do not see that some of the actions above were finished. Could be missing something. I’ll ping @anon71759204 as he was following this closely.
The second option in my previous post would be the way to go to add support for a ZWA009@12.1. As @apella12 pointed out the XML file for the ZWA009@12.1 would be required.
Mclupo
(Wolf Kroenert )
February 4, 2023, 10:14am
55
Thanks for help. I just testet the Simplicity studio software ( Firmware upload) on this aerQ Sensor ( update vom 1.1 to 12.1 ).
If some one got the 1.1 Firmware, it would be nice to downgrade again
All I get from device info is
and the xml file
<node>
<homeId>xxxx</homeId>
<nodeId>32</nodeId>
<version>4</version>
<manufacturer>0x371</manufacturer>
<deviceId>0x9</deviceId>
<deviceType>0x2</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations/>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<version>2</version>
<versionSupported>2</versionSupported>
<types>
<binarySensorType>GENERAL</binarySensorType>
</types>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<version>10</version>
<versionSupported>11</versionSupported>
<sensors>
<entry>
<multilevelSensorType>TEMPERATURE</multilevelSensorType>
<multilevelSensor>
<sensorType>TEMPERATURE</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>RELATIVE_HUMIDITY</multilevelSensorType>
<multilevelSensor>
<sensorType>RELATIVE_HUMIDITY</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>DEW_POINT</multilevelSensorType>
<multilevelSensor>
<sensorType>DEW_POINT</sensorType>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters/>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>HEAT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmType>WEATHER</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>881</deviceManufacturer>
<deviceType>2</deviceType>
<deviceId>9</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>70</batteryLevel>
<batteryLow>false</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>86400</interval>
<minInterval>3600</minInterval>
<maxInterval>15724800</maxInterval>
<defaultInterval>604800</defaultInterval>
<intervalStep>240</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>6</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.12</protocolVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<version>3</version>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2023-02-04 10:05:40.750 UTC</lastReceived>
</node>
I’ve taken the first step to add the ZWA009@12.1 to the Z-Wave database (OpenSmartHouse Z-Wave Device Database ):
Please follow the instructions in the Blog Posts to complete the device data. AFAIK most (if not all?) data can be copied from OpenSmartHouse Z-Wave Device Database .
Mclupo
(Wolf Kroenert )
February 4, 2023, 2:19pm
57
Thanks for the start. Even I don’t know, what to do, I gave it a try but I couldn’t edit the page you created. I only have read permission. Maybe it‘s due to „Modified“ state?
Recently I made a new install of the Zwave network, by that including all devices from scratch.
I’m running OH 4.0.4 stable.
All went well except the ZWA009 which was running on OH3.x since around April 2021, now on OH 4.0.4 inclusion didn’t work.
chris:
So, based on this we would need to create a new version of ZWA009 with Version=12, change the current ZWA009 to V=1.000-1.255, and set the new ZWA039 to 2.000-2.255.
It seems the “old” version of the ZWA009 is not supported by the zwave binding any longer. Not sure, but most probably the firmware was V1.xx.
I found the following XML in one of my backup files:
<node>
<homeId>xxxxxxxxxx</homeId>
<nodeId>21</nodeId>
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>0</int>
<endPoint>
<deviceClass>
</deviceClass>
<entry>
</entry>
<entry>
</entry>
<entry>
<commandClass>COMMAND_CLASS_CONTROLLER_REPLICATION</commandClass>
<COMMAND__CLASS__CONTROLLER__REPLICATION>
</COMMAND__CLASS__CONTROLLER__REPLICATION>
</entry>
<entry>
<types>
<binarySensorType>UNKNOWN</binarySensorType>
<binarySensorType>CO</binarySensorType>
<binarySensorType>AUX</binarySensorType>
<binarySensorType>GLASSBREAK</binarySensorType>
</types>
</entry>
<entry>
<sensors>
<entry>
<multilevelSensor>
</multilevelSensor>
</entry>
<entry>
<multilevelSensor>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>SOLAR_RADIATION</multilevelSensorType>
<multilevelSensor>
<sensorType>SOLAR_RADIATION</sensorType>
<initialised>false</initialised>
</multilevelSensor>
</entry>
<entry>
<multilevelSensor>
</multilevelSensor>
</entry>
</sensors>
</entry>
<entry>
<commandClass>COMMAND_CLASS_CRC_16_ENCAP</commandClass>
<COMMAND__CLASS__CRC__16__ENCAP>
</COMMAND__CLASS__CRC__16__ENCAP>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>1</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>2</size>
<value>-22336</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>9</int>
<index>9</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>11</int>
<index>11</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>64</int>
<index>64</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>255</int>
<index>255</index>
<size>4</size>
<value>0</value>
</entry>
</configParameters>
</entry>
<entry>
<alarms>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<batteryLevel>0</batteryLevel>
<batteryLow>true</batteryLow>
</entry>
<entry>
<interval>604800</interval>
</entry>
<entry>
</entry>
<entry>
</entry>
<entry>
<ZWaveIndicator>
</ZWaveIndicator>
</entry>
<entry>
</entry>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors>
<int>1</int>
<int>5</int>
<int>6</int>
<int>7</int>
<int>11</int>
<int>15</int>
<int>16</int>
<int>17</int>
</nodeNeighbors>
<lastReceived>2023-11-29 09:33:39.432 UTC</lastReceived>
</node>
I’d thought that devices once supported will be supported also in future releases.
Is there a chance to get support for this device again?
Anything I can do?
Thank you.
maxmaximax
apella12
(Bob Eckhoff)
December 12, 2023, 9:42pm
59
If it was 1.xx it should work. What looks odd given the history of the device is this in the XML you posted.
My guess this is the problem. Does the UI page for the device show any different version? (there is no Version 4 in the DB and my guess it was included before the versions were separated. Default is all versions)
The ZWA009 was included back sometime in April/May 2021, well before the version split was done from what I can see in this thread.
It seems no firmware version info is put neither on the device nor on the packaging (unlike Fibaro and others).
On the packaging and device labels it refers to “ZWA009-C”.
Well, I can’t access the UI page of the device, since there is no such Thing
due to failed inclusion - XML file from backups is the only information I have.
I tried to capture logs from failed inclusion - however nothing is shown in the openhab.log.
Worth noting that the device was constantly sending measurement reports up until I made the new install of the Zwave network.
I seems as if the device was doing its job properly even after the zwave binding has been updated with the version split.
Any chance to get the Version 4 included in the database based on the XML I shared?
Thank you.
maxmaximax
