Let me see what has been done so far. Normally the DB is updated by the person with the device. If you look a couple of posts above yours there is a similar XML, but it displays on the UI page as 12.1, not 4. It appears that XML was uploaded, but the rest of the work has not finished. Are you sure you do not have a similar UI page? Even unknown devices have some information there. You could try to wake the device a few times to get more information and an XML in the userdata/zwave folder.
Issue is that I made a “full reset” of my Zwave network including controller.
I can see the above UI for all devices that were added to the Zwave network successfully, XML files exist for each of them in the userdata/zwave folder, whereas the inclusion of the ZWA009 failed → hence, I can’t find any entry related to the ZWA009, nowhere, not even in userdata/zwave folder.
The XML I uploaded is not part of the userdata/zwave folder any longer. It was taken from a backup which was done before I made the “full reset”.
I contacted Aeotec support asking whether version V4 ever existed - waiting for their reply.
Would 12.01 work as well?
Maybe I can upgrade to that version (upgrade files are available on the Aeotec website)
Before you go through a lot of work, can you check if the device fully excluded? At this point I’d try the factory reset. It actually should get discovered as an unknown device, not as failure. Maybe this will solve the problem.
Part 2: If you get to the unknown device stage, I marked up an XML from what was in the DB that can be added to your binding for a test following the procedure here. The location in this case is /jarmodify/OH-INF/thing/aeotec
and the file is
zwa009_3_0.xml (16.2 KB)
That file should work with any version greater than 3.
It works
It seems the device is fully functional !!
This was the case.
This made me suspicious…
I thought I had done that already. For all other 19 devices (most of the Fibaros) I did that.
Seems it was not done properly for the ZWA009.
This might not sound logical - 3 steps I followed…
- Factory reset (1st)
- Remove battery
- Factory reset (2nd)
Then I started inclusion to Zwave network.
Device was discovered as “Z-Wave Node 021: ZWA009 Temperature and Humidity Sensor”.
I checked UI → version is 1.1
XML file → It still says version 4. This is probably not related to the firmware version.
XML file in userdata/zwave
<node>
<homeId>xxxxxxxxx</homeId>
<nodeId>21</nodeId>
<version>4</version>
<manufacturer>0x371</manufacturer>
<deviceId>0x9</deviceId>
<deviceType>0x2</deviceType>
<listening>false</listening>
<frequentlyListening>false</frequentlyListening>
<routing>true</routing>
<security>false</security>
<beaming>true</beaming>
<maxBaudRate>40000</maxBaudRate>
<sleepDelay>500</sleepDelay>
<nodeInformationFrame>
<commandClass>COMMAND_CLASS_ZWAVEPLUS_INFO</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_MULTI_CHANNEL_ASSOCIATION</commandClass>
<commandClass>COMMAND_CLASS_ASSOCIATION_GRP_INFO</commandClass>
<commandClass>COMMAND_CLASS_TRANSPORT_SERVICE</commandClass>
<commandClass>COMMAND_CLASS_VERSION</commandClass>
<commandClass>COMMAND_CLASS_MANUFACTURER_SPECIFIC</commandClass>
<commandClass>COMMAND_CLASS_DEVICE_RESET_LOCALLY</commandClass>
<commandClass>COMMAND_CLASS_INDICATOR</commandClass>
<commandClass>COMMAND_CLASS_POWERLEVEL</commandClass>
<commandClass>COMMAND_CLASS_BATTERY</commandClass>
<commandClass>COMMAND_CLASS_SECURITY_2</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_BINARY</commandClass>
<commandClass>COMMAND_CLASS_CONFIGURATION</commandClass>
<commandClass>COMMAND_CLASS_ALARM</commandClass>
<commandClass>COMMAND_CLASS_SENSOR_MULTILEVEL</commandClass>
<commandClass>COMMAND_CLASS_WAKE_UP</commandClass>
<commandClass>COMMAND_CLASS_SUPERVISION</commandClass>
<commandClass>COMMAND_CLASS_FIRMWARE_UPDATE_MD</commandClass>
</nodeInformationFrame>
<associationGroups class="concurrent-hash-map">
<entry>
<int>1</int>
<associationGroup>
<index>1</index>
<maxNodes>0</maxNodes>
<associations>
<associationMember>
<node>1</node>
</associationMember>
</associations>
</associationGroup>
</entry>
<entry>
<int>2</int>
<associationGroup>
<index>2</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>3</int>
<associationGroup>
<index>3</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>4</int>
<associationGroup>
<index>4</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>5</int>
<associationGroup>
<index>5</index>
<associations/>
</associationGroup>
</entry>
<entry>
<int>6</int>
<associationGroup>
<index>6</index>
<associations/>
</associationGroup>
</entry>
</associationGroups>
<endpoints class="concurrent-hash-map">
<entry>
<int>0</int>
<endPoint>
<deviceClass>
<basicDeviceClass>BASIC_TYPE_ROUTING_SLAVE</basicDeviceClass>
<genericDeviceClass>GENERIC_TYPE_SENSOR_NOTIFICATION</genericDeviceClass>
<specificDeviceClass>SPECIFIC_TYPE_NOTIFICATION_SENSOR</specificDeviceClass>
</deviceClass>
<endpointId>0</endpointId>
<secureCommandClasses/>
<supportedCommandClasses class="concurrent-hash-map">
<entry>
<commandClass>COMMAND_CLASS_NO_OPERATION</commandClass>
<COMMAND__CLASS__NO__OPERATION>
<version>1</version>
<instances>1</instances>
<control>false</control>
<versionSupported>1</versionSupported>
</COMMAND__CLASS__NO__OPERATION>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__BINARY>
<version>2</version>
<versionSupported>2</versionSupported>
<isGetSupported>true</isGetSupported>
<types>
<binarySensorType>GENERAL</binarySensorType>
</types>
</COMMAND__CLASS__SENSOR__BINARY>
</entry>
<entry>
<COMMAND__CLASS__SENSOR__MULTILEVEL>
<version>10</version>
<versionSupported>11</versionSupported>
<sensors>
<entry>
<multilevelSensorType>TEMPERATURE</multilevelSensorType>
<multilevelSensor>
<sensorType>TEMPERATURE</sensorType>
<initialised>true</initialised>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>RELATIVE_HUMIDITY</multilevelSensorType>
<multilevelSensor>
<sensorType>RELATIVE_HUMIDITY</sensorType>
</multilevelSensor>
</entry>
<entry>
<multilevelSensorType>DEW_POINT</multilevelSensorType>
<multilevelSensor>
<sensorType>DEW_POINT</sensorType>
</multilevelSensor>
</entry>
</sensors>
</COMMAND__CLASS__SENSOR__MULTILEVEL>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION__GRP__INFO>
<versionSupported>3</versionSupported>
<autoSubscribeGroups/>
</COMMAND__CLASS__ASSOCIATION__GRP__INFO>
</entry>
<entry>
<COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</COMMAND__CLASS__DEVICE__RESET__LOCALLY>
</entry>
<entry>
<COMMAND__CLASS__ZWAVEPLUS__INFO>
<zwPlusVersion>2</zwPlusVersion>
<zwPlusRole>ROLE_TYPE_SLAVE_SLEEPING_REPORTING</zwPlusRole>
<zwPlusNodeType>NODE_TYPE_ZWAVEPLUS_NODE</zwPlusNodeType>
</COMMAND__CLASS__ZWAVEPLUS__INFO>
</entry>
<entry>
<COMMAND__CLASS__CONFIGURATION>
<versionSupported>4</versionSupported>
<configParameters>
<entry>
<int>1</int>
<configurationParameter>
<index>1</index>
<size>1</size>
<value>20</value>
<readOnly>false</readOnly>
<writeOnly>false</writeOnly>
</configurationParameter>
</entry>
<entry>
<int>2</int>
<index>2</index>
<size>1</size>
<value>5</value>
</entry>
<entry>
<int>4</int>
<index>4</index>
<size>2</size>
<value>-22336</value>
</entry>
<entry>
<int>5</int>
<index>5</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>6</int>
<index>6</index>
<size>2</size>
<value>0</value>
</entry>
<entry>
<int>7</int>
<index>7</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>8</int>
<index>8</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>9</int>
<index>9</index>
<size>1</size>
<value>-1</value>
</entry>
<entry>
<int>10</int>
<index>10</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>11</int>
<index>11</index>
<size>1</size>
<value>-1</value>
</entry>
<entry>
<int>12</int>
<index>12</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>13</int>
<index>13</index>
<size>1</size>
<value>0</value>
</entry>
<entry>
<int>64</int>
<index>64</index>
<size>1</size>
<value>1</value>
</entry>
<entry>
<int>255</int>
<index>255</index>
<size>4</size>
<value>0</value>
</entry>
</configParameters>
</COMMAND__CLASS__CONFIGURATION>
</entry>
<entry>
<COMMAND__CLASS__ALARM>
<version>8</version>
<versionSupported>8</versionSupported>
<alarms>
<entry>
<alarmType>HEAT</alarmType>
<alarmState>
<reportedEvents/>
<outer-class reference="../../../.."/>
</alarmState>
</entry>
<entry>
<alarmType>POWER_MANAGEMENT</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
<entry>
<alarmType>WEATHER</alarmType>
<alarmState>
<reportedEvents/>
</alarmState>
</entry>
</alarms>
<v1Supported>true</v1Supported>
</COMMAND__CLASS__ALARM>
</entry>
<entry>
<COMMAND__CLASS__MANUFACTURER__SPECIFIC>
<initSerialNumber>false</initSerialNumber>
<deviceManufacturer>881</deviceManufacturer>
<deviceType>2</deviceType>
<deviceId>9</deviceId>
</COMMAND__CLASS__MANUFACTURER__SPECIFIC>
</entry>
<entry>
<COMMAND__CLASS__POWERLEVEL>
<powerLevel>0</powerLevel>
<powerTimeout>0</powerTimeout>
</COMMAND__CLASS__POWERLEVEL>
</entry>
<entry>
<COMMAND__CLASS__FIRMWARE__UPDATE__MD>
<versionSupported>5</versionSupported>
</COMMAND__CLASS__FIRMWARE__UPDATE__MD>
</entry>
<entry>
<COMMAND__CLASS__BATTERY>
<batteryLevel>0</batteryLevel>
<batteryLow>true</batteryLow>
</COMMAND__CLASS__BATTERY>
</entry>
<entry>
<COMMAND__CLASS__WAKE__UP>
<targetNodeId>1</targetNodeId>
<interval>604800</interval>
<minInterval>3600</minInterval>
<maxInterval>15724800</maxInterval>
<defaultInterval>604800</defaultInterval>
<intervalStep>240</intervalStep>
</COMMAND__CLASS__WAKE__UP>
</entry>
<entry>
<COMMAND__CLASS__ASSOCIATION>
<maxGroups>6</maxGroups>
</COMMAND__CLASS__ASSOCIATION>
</entry>
<entry>
<COMMAND__CLASS__VERSION>
<libraryType>LIB_SLAVE_ENHANCED</libraryType>
<protocolVersion>7.12</protocolVersion>
<applicationVersion>1.1</applicationVersion>
<hardwareVersion>1</hardwareVersion>
</COMMAND__CLASS__VERSION>
</entry>
<entry>
<COMMAND__CLASS__INDICATOR>
<version>3</version>
<supportedIndicatorsInitialised>true</supportedIndicatorsInitialised>
<supportedIndicators>
<ZWaveIndicator>
<type>NODE_IDENTIFY</type>
</ZWaveIndicator>
</supportedIndicators>
</COMMAND__CLASS__INDICATOR>
</entry>
<entry>
<COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</COMMAND__CLASS__MULTI__CHANNEL__ASSOCIATION>
</entry>
</supportedCommandClasses>
</endPoint>
</entry>
</endpoints>
<nodeNeighbors/>
<lastReceived>2023-12-13 16:23:39.136 UTC</lastReceived>
</node>
Thank you so much for your kind support - really appreciated!
Final question: Is V12.01 supported?
maxmaximax
I found the partial ZW DB update from above (it was marked deleted), finished it and marked for review. Tried to undelete, but not successful, so answer: not yet, but maybe in a couple of weeks.
EDIT: It was approved and merged in the 4.1 release (stable)
I’m running 12.01 FW, and for the first time in over a year, my ZWA009s are online!
Thank you to everyone for your work on this!
Which OH release are you on?
openHAB 4.1.0 Release Build
I upgraded my sensors to FW 12.01 and inclusion worked perfectly on OH 4.1!
Thanks a lot!
