Penrose
(Thomas)
1
I have two Denon receivers and want to control them both through openHAB. So I simply added two lines in openhab.cfg:
denon:avr2113.host=DENON-AVR-2113
denon:ceol.host=CEOL-piccolo
Apparently this doesn’t work but I don’t see any errors in the logs. Is this supposed to be working?
Thomas
you have to set the IP-Adress, e.g. denon:avr2113.host=192.168.10.55
and denon:ceol.host=192.168.10.56
Penrose
(Thomas)
3
I tried with ip addresses before but it doesn’t help. It seems I can only control the last instance I defined in openhab.cfg either way.
Penrose
(Thomas)
4
Has anybody ever made two instances run in parallel?
alphaZ
(Rainer)
5
Same problem here: Two Maranz receivers, individually they work fine, when configured both at the same time, things don’t work anymore.
Any news on the topic?
Penrose
(Thomas)
6
Sharpy
(Aaron Sharp)
7
Does the binding work with a single 2113 AVR just got my hands on one but can’t setup yet no remote sadly
