What is almost certainly happening is that there is not an openhab server starting when the Pi boots up, or it is failing to come up. If it were running then you wouldn’t be able to start it later using start.sh as it would be unable to bind to the needed ports.
i tried following other tutorials to make it start on boot, and thats where i believe i have messed up. when the rpi boots up and i put ls /var/run it shows openhab.pid
but it my sitemap doesnt work.
then when i go to /opt/openhab and start.sh it allows me to start and the sitemap starts to work.
i think i am going to to do a fresh install on the rpi
That tutorial is pretty out of date. The preferred installation method is documented here.
Installation via apt-get will:
make it run as a non-privileged user, necessary for security
put everything in a standard Debian based location (raspbian is Debian based)
makes sure all the proper file permissions are configured
makes it much much easier for us on this forum to help you with problems like this because we can make certain assumptions about where things are located and how things are configured
gives you automatic updates when new releases come out
When you do the fresh, please install via apt-get.
I don’t know. I just ran apt-get install mosquitto but I’m running on Ubuntu, not raspbian. But I would be shocked if that command didn’t work on the Pi too.
well i did a fresh install via the apt-get method, but openhab does not load on boot up. i followed the instructions to the t. not sure why i have to start it manually.
edit: nevermind, it starts automatically, now its another problem
my esp8266 esp01 module keeps disconnecting and reconnecting.
tried asking in the esp8266 forum, but everytime i post a mod needs to approve it…
