Openhab 3.3.0
I’ve created a chart for a persistent item I have but I get a JS error and no X axis or points rendered in the chart
with this error in the javascript console:
app.js:7 TypeError: Cannot read properties of undefined (reading 'coordinateSystem')
at Object.r (12.app.js:1:88913)
at e.render (39.app.js:1:32711)
at 5.app.js:31:181974
at Array.forEach (<anonymous>)
at C (5.app.js:1:35349)
at er (5.app.js:31:181911)
at tr (5.app.js:31:181757)
at e.update (5.app.js:31:177881)
at e.setOption (5.app.js:31:167326)
at i.init (5.app.js:31:261849)
I’m using mysql and checked that the databse is ok and has data in it
The chart is quite simple:
label: Batteries
period: 2D
sidebar: true
slots:
calendar: []
grid:
- component: oh-chart-grid
config: {}
legend:
- component: oh-chart-legend
orient: horizontal
show: true
series:
- component: oh-time-series
gridIndex: 0
item: plant1_bat
type: line
xAxisIndex: 0
yAxisIndex: 0
title:
- component: oh-chart-title
show: true
text: Battery levels
xAxis:
- component: oh-time-axis
gridIndex: 0
gridIndex: 1
yAxis:
- component: oh-value-axis
gridIndex: 0
name: Raw Battery reading
scale: true
gridIndex: 1
it’s getting data from this item:
Number plant1_bat "Plant1 Battery" (plant1, batteries)
I’m using jdbc with mysql:
jdbc:mysql://127.0.0.1:3306/plant_items?serverTimezone=EET
the table looks ok:
mysql> describe plant1_bat_0011;
| Field | Type | Null | Key | Default | Extra |
| time | timestamp | NO | PRI | CURRENT_TIMESTAMP | on update CURRENT_TIMESTAMP |
| value | double | YES | | NULL | |
2 rows in set (0.01 sec)
mysql> select * from plant1_bat_0011 ;
| time | value |
| 2022-10-04 12:06:32 | 847 |
| 2022-10-04 12:10:33 | 848 |
| 2022-10-04 12:16:47 | 849 |
| 2022-10-04 12:22:57 | 848 |
| 2022-10-04 12:27:05 | 849 |
| 2022-10-04 12:29:08 | 850 |
| 2022-10-04 12:31:11 | 849 |
and I can see that the chart is making a request to the persistence api which is returning data:
-> http://server.local:8080/rest/persistence/items/plant1_temp?starttime=2022-09-27T20%3A26%3A29.964Z&endtime=2022-10-04T20%3A26%3A29.963Z
{"name":"plant1_temp","datapoints":"259","data":[{"time":1664874391000,"state":"22.2"},{"time":1664874510000,"state":"22.6"},{"time":1664874633000,"state":"22.4"},
Anyone got any clues? I’ve tried it in Chromium Version 105.0.5195.102 (Official Build) snap (64-bit)
and firefox 92.0.
