Typo in the Debian part of installation documentation
There is a typo in documentation at openHAB on Linux | openHAB
In the Apt Based Systems paragraph, the gpg extension is written pgp. The script line shows:
curl -fsSL "https://openhab.jfrog.io/artifactory/api/gpg/key/public" | gpg --dearmor > openhab.pgp
sudo mkdir /usr/share/keyrings
sudo mv openhab.pgp /usr/share/keyrings
sudo chmod u=rw,g=r,o=r /usr/share/keyrings/openhab.pgp
Where it should read:
curl -fsSL "https://openhab.jfrog.io/artifactory/api/gpg/key/public" | gpg --dearmor > openhab.gpg
sudo chmod u=rw,g=r,o=r /usr/share/keyrings/openhab.gpg
That typo is fixed in latest. @Confectrician what do we need to do to get that fix backported to the Stable 3.3.0 docs?
Note, at the bottom of all the web pages in the docs is a link you can click on to report issues like this or even make the correction yourself.
Tx, sorry. I missed the report option.
We have to introduce the same change as a PR with final-stable as target.
Seems i have missed that one while merging the pr.
Usually in cases where a change is needed in latest and stable docs, you can make a pull request against main docs and add the release-stable lable (or ask for it). This will automatically open a second pr which copies the finished result into the stable docs website.
But we can still do it by hand in this case. :slightly_smiling_face:
I made a new PR but I couldn’t see how to apply a label and I couldn’t find a release-stable tag nor would it let me make one.
Info in the PR is good enough.
I have applied the label.
The automation failed, but after a manual check, the stable docs seem to be correct already.
