Glad to hear you got it sorted out.
Hi Mathew,
Iām kind of in a catch 22 scenario here; Iām running on a Synology that the development lead has only released 2.4 so far for the Synology platform. I was able to trick Synology version 2.4 to use 2.5m1 bindings by modifying the host file to point it locally for binding installs.
Iāve been running your 2.5 binding prior to the Unifi upgrade to 5.10.x and itās worked excellent.
Now I have your build #101 dated 2.5.0.201903210729 and Iām having trouble getting it to work with the Unifi 5.10.x version which Iām assuming is because of the quoted requirement of having 2.5 for OH as the core ā ExtensibleTrustManager
Is there any other work around other than reverting back my Unifi version to 5.9.x?
It just sits in starting mode:
197 ā Starting ā 80 ā 2.5.0.201903210720 ā org.openhab.binding.unifi
Debug mode shows this:
2019-04-11 19:31:40.878 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent [unknown:512] - org.openhab.binding.unifi
Best, Jay
Hereās the latest DEBUG log file; is there a specific OH 2.5m1 JAR I can drop in to get the new `āExtensibleTrustManagerā working with the new Unifi binding?
2019-04-12 20:15:24.338 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent [unknown:512] - org.openhab.binding.unifi
2019-04-12 20:39:13.894 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent STOPPING - org.openhab.binding.unifi
2019-04-12 20:39:13.898 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent STOPPED - org.openhab.binding.unifi
2019-04-12 20:39:33.241 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent UNRESOLVED - org.openhab.binding.unifi
2019-04-12 20:39:34.158 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent RESOLVED - org.openhab.binding.unifi
2019-04-12 20:39:43.271 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent [unknown:512] - org.openhab.binding.unifi
Best, Jay
How can get a JAR for this feature for my openHAB 2.4.0 Release Build on a Synology?
Best, Jay
I have the same issue with the Unifi binding since the 2.5.0.201903071727 build.
161 x Starting x 80 x 2.5.0.201903210720 x org.openhab.binding.unifi
232 x Starting x 80 x 2.5.0.201903100737 x org.openhab.binding.unifi
Iām running the default Openhabian build with stable 2.4 version.
hope someone can fix it.
Hi Mike,
We have the same issues but yours has one more issue; your trying to run 2 Unifi bindings versions at the same time. Make sure you only have 1 running, meaning 1 in the ADDON directory and NO entry in the addons.cfg file for it.
Youāll still see the Starting and it will just stay in that state (the problem we both have running OH 2.4).
Trying to get you past 1 of the 2 hurdles we both have.
Best, Jay
Hi Jay,
Sorry was a bit unclear wit that, iām running only one version. I only tried to showed that all bindings after 20190307 are not starting anymore(at least for me).
Iām running the latest starting version:
233 x Active x 80 x 2.5.0.201903071727 x org.openhab.binding.unifi
Is it certain that OH 2.4 is the issue?
regards,
Mic
I believe it is, based on @mgbowman statement of āas the required change to ExtensibleTrustManager
isnāt in 2.4ā.
We both need a workaround to it.
Best, Jay
@jwiseman @M1C Iāll try and create a 2.4 specific build for you two later this evening. Iām still swamped with my house - only a few more weeks until I move!
Iām also on synology on 2.4 so count me in if you do make an alt version! Cheers!
For all of you stuck on 2.4, try this build: openhab2-unifi-binding-2.4
It has a work around for the missing ātrustā code thatās only in 2.5 and youāll have all the latest features of the binding.
Once 2.5 is released, this build will go away.
Matthew
Thanks Matthew, thatās very generous of you.
Will try tonight⦠Cheers!
Hi Mathew,
First of all, thank you for doing this!
I binding above; the link says 2.4 but the file downloaded was 2.5. Is that correct file?
I did clean out the /cache and /tmp directories also.
Iām still getting the same issue like I was with your latest version.
2019-04-18 08:18:00.579 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent INSTALLED - org.openhab.binding.unifi
2019-04-18 08:18:03.201 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent RESOLVED - org.openhab.binding.unifi
2019-04-18 08:18:04.060 [DEBUG] [org.openhab.binding.unifi ] - BundleEvent [unknown:512] - org.openhab.binding.unifi
Best, Jay
Thank you Matthew.
But for me it also keeps the status starting.
Regards,
Mic
@jwiseman @M1C Iām sorry to hear thisā¦
Let me spin up an OH 2.4 installation and see if I can reproduce your issue and maybe get a proper work around.
Iām sorry guys but I just removed all references to the ātrustā framework and even I get an error in a fresh 2.4 install
Thereās a deeper problem here and unfortunately I donāt have the time to figure it out. My only suggestion for now would be to stick with the 2.4 version of the binding and accept the fact youāll have to wait until 2.5 to have access to the new features.
Again Iām sorry.
All the best.
Thanks for trying! Hereās the questions I think weāll have?
What is the URL to the 2.4 JAR binding to manually download it?
Will it work with the Unifi Controller 10.5.2x version?
Best, Jay
You should be able to install it via the PaperUI - it was a part of the 2.4 release
Iām running 2.5m1 bindings on OH2.4 installation. I have mapped my host file download URL entry to point to itself so I insure I get 2.5m1 bindings from the local KAR file; hence the reason I need the actual download path to manually install it.
Best, Jay
Hi Jay,
Iām running binding version 2.5.0.201903071727 on Openhab 2.4 with Unifi controller 5.10.21. For me its running as expected. I tried most version after this one also but with no success, as far as i can see this is the last version of the binding that does start.
Regards,
Micha
