Anyway I (we) could get a copy of that version? I’ve tried these 2 versions below from the posts above and neither work; same results. I used the date in your version to try to get close to it.
Hi
hope this is the right discussion.
What I have issues with: I have the Unifi Binding installed, the Controller is online, and I’ve added some wireless clients - which show online, but are not, apparently, receiving any data.
Example: I have the item String PatricksMacAdr "Patrick iPhone Mac [%s]" (Lichter_EG, PatrickZuhause) { channel="u unifi:wirelessClient:abe64366:macAddress" }
And in the corresponding sitemap, it doesn’t show anything.
I do have an issue in the log:
2019-04-19 13:40:08.945 [WARN ] [.handler.UniFiControllerThingHandler] - Unhandled exception while refreshing the UniFi Controller unifi:controller:a21fe124 - Unknown HTTP status code 503 returned by the controller
org.eclipse.smarthome.model.item.BindingConfigParseException: ID segment 'u unifi' contains invalid characters. Each segment of the ID must match the pattern [A-Za-z0-9_-]*.
2019-04-19 14:40:05.056 [WARN ] [.handler.UniFiControllerThingHandler] - Unhandled exception while refreshing the UniFi Controller unifi:controller:a21fe124 - Unknown HTTP status code 503 returned by the controller
2019-04-19 15:40:05.423 [WARN ] [.handler.UniFiControllerThingHandler] - Unhandled exception while refreshing the UniFi Controller unifi:controller:a21fe124 - Unknown HTTP status code 503 returned by the controller
Here’s my setup:
I’ve just upgraded to 2.5. M1 for both OH and Unifi, running on ubuntu, Unifi Controller Version is atag_5.6.26_10236
I had the unifi binding up and running before, since the upgrade I’ve also noticed that the “client” was replaced with “wirelessClient”.
Looking through my commit logs, that was right before I added wiredClient and site support. If I can find some free time today, I will try and figure out what exactly is causing the latest binding code to throw an error in 2.4 and try and provide a work around.
If you look at those 2 URLs you posted, you’ll notice they both have ‘…/lastSuccessfulBuild/…’ in them which means you were downloading the latest build. You can always access the complete build history on my Jenkins server located at https://jenkins.otr.mx/job/openhab2-unifi-binding/
There you can see that build #92 was on March 7th.
You’re using a channel identifier of u unifi:... (a u, followed by a space, followed by unifi:) - that’s an invalid binding config. Please remove the u and space before unifi: and report back.
If you’re running OH 2.5M1, I would suggest upgrading to the build #101 (the latest as of this post)
I hope you can figure it out. i really would like to usr the latest build that would be compatible with OH 2.4.
Thank you for all the effort you put in it.
For all of you stuck on 2.4, you can run the latest binding code (minus the 2.5 specific “trust” bits) by installing build #10 of the 2.4 specific branch.
Hey Matthew,
I get this error on 2.4 on syno with build #10:
2019-04-21 09:22:10.842 [WARN ] [org.apache.felix.fileinstall ] - Error while starting bundle: file:/volume1/public/openHAB/addons/org.openhab.binding.unifi-2.5.0-SNAPSHOT.jar
org.osgi.framework.BundleException: Could not resolve module: org.openhab.binding.unifi [282]
Another singleton bundle selected: osgi.identity; type="osgi.bundle"; version:Version="2.4.0"; osgi.identity="org.openhab.binding.unifi"; singleton:="true"
at org.eclipse.osgi.container.Module.start(Module.java:444) ~[?:?]
at org.eclipse.osgi.internal.framework.EquinoxBundle.start(EquinoxBundle.java:383) ~[?:?]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundle(DirectoryWatcher.java:1260) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startBundles(DirectoryWatcher.java:1233) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.startAllBundles(DirectoryWatcher.java:1221) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.doProcess(DirectoryWatcher.java:515) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.process(DirectoryWatcher.java:365) [10:org.apache.felix.fileinstall:3.6.4]
at org.apache.felix.fileinstall.internal.DirectoryWatcher.run(DirectoryWatcher.java:316) [10:org.apache.felix.fileinstall:3.6.4]
I seem to recall that this means there’s already a binding installed. Are you certain you uninstalled the one that was running? You can confirm if there’s already one installed by running this in the console.
Ok guys so I did a little reorganization on the commit history to help make maintaining two branches easier.
Now I have two builds setup in Jenkins:
openhab2-unifi-binding - compatible with 2.4.0+
openhab2-unifi-binding-2.5 - compatible with 2.5.0.M1+
The 2.5 branch uses the OH2 internal HttpClientFactory and ExtensibleTrustManager to communicate with the UniFi controller. @Kai requested this some time ago and this will be the default after 2.5 is released.
Moving forward, I will work on the 2.4 branch and do a rebase of the 2.5 branch each time I push a new build (effectively creating two builds for each commit).
Additionally, I force incremented the build number on the 2.5 build in Jenkins so the build numbers are synchronized.
If you’re running 2.5.0.M1+, please use the 2.5 specific version to help discover any potential issues with using the OH2 internal bits for communication.
Unfortunately not yet. It’s a “device” and not a “client” as far as the controller is concerned. I’m about to setup my new UniFi network at home and will be adding support for switches soon!
Is there a way to detect current and “available” firmware versions? I have just logged in into my unifi web page and got the notification there that the cloud key has minor updates to its firmware.
If we have this information, I could integrate that into the nightly “please update systems X, Y and Z” notification that I send from my openHAB instance…
Hi, I found this binding and want to use it to block and unblock clients.
But It is not working I only see the blocked and reconnect via the openhab android app
and in the log I see:
2019-04-14 21:49:10.688 [ome.event.ItemCommandEvent] - Item ‘MatthewsPhoneBlocked’ received command ON
2019-04-14 21:49:10.691 [nt.ItemStatePredictedEvent] - MatthewsPhoneBlocked predicted to become NULL
