I tried this manual installation to but no succes!
My devices only updates to “connected” but when disconnected from the WiFi the state don’t change in openhab (worked well on my 2.4 setup).
also tried the OH3.0 snapshot binding but this give me the same result.
Also having problems after upgrade to OH 2.5 regarding away detection and Unifi Binding 2.5. Under OH 2.4 presence worked like a charm using Unifi. Now after the upgrade the things I defined are always “ON” and never “OFF” when away. I see a number of these when using the 2.5 binding:
2019-12-30 10:08:03.575 [WARN ] [rnal.handler.UniFiClientThingHandler] - Ignoring unsupported command = OFF for channel = unifi:wirelessClient:MyHome:Iphone:online
2019-12-30 10:39:16.583 [WARN ] [rnal.handler.UniFiClientThingHandler] - Ignoring unsupported command = OFF for channel = unifi:wirelessClient:MyHome:Iphone:online
2019-12-30 10:58:31.834 [WARN ] [rnal.handler.UniFiClientThingHandler] - Ignoring unsupported command = OFF for channel = unifi:wirelessClient:MyHome:Iphone:online
2019-12-30 11:13:24.810 [WARN ] [rnal.handler.UniFiClientThingHandler] - Ignoring unsupported command = OFF for channel = unifi:wirelessClient:MyHome:Iphone:online
2019-12-30 11:35:06.481 [WARN ] [rnal.handler.UniFiClientThingHandler] - Ignoring unsupported command = OFF for channel = unifi:wirelessClient:MyHome:Iphone:online
When installing earlier 2.5 bindings (june-nov) I do not get these messages, but things are still always “ON” ie online.
Keep an eye on your controller and check if your Wifi devices appear as LAN devices (as mentioned in the link). If there are still visibable as LAN devices, the binding won’t turnt the items off. This is very frustrating.
Hey guys, sorry for my absence. I had a super busy holiday season with my family and after surviving that, I just had to take a ski vacation I’m finally back home! I have to put some effort into setting up my dev environment as I got a new laptop for Christmas - yay!
With all the recent changes to the tree, I have some work todo to get everything up to date with the current status of master. Once everything’s all sync’d up, I will begin working on new features that have been requested (and fixing any bugs you guys have uncovered).
Since today I am able to switch on and off POE ports using the “EXEC” binding. Allthough I now am happy with the fact I can switch off stuff when leaving home or switch on stuff when I arrive home, I am not very fond of the steps I had to take. So dear @mgbowman, if it is possible to integrate POE in the binding I would be the first one to test
I just took the time last night to get my local OH server updated to 2.5.1-2 (testing/main) and next is to get my dev environment up and running (going to start fresh here considering the repo / namespace changes).
I took this opportunity of starting with a fresh OS to sort / organise my data (something I’ve been needing to do) and I’m almost done. Unfortunately my free time is rather limited as I’ve got some major IRL work projects because it’s the beginning of the year
Things will settle down over the next week or so and I’ll have more time to hack away at home!
I promise promise promise I will start development again very very very soon!
// "%2$s" will be replace by the input channel command, this makes it possible to use one command line with different arguments.
// e.g: "ls" as <YOUR COMMAND> and "-a" or "-l" as additional argument set to the input channel in the rule.
Thing exec:command:poe_actions [ command="/openhab/conf/scripts/poe.sh %2$s", interval=0, autorun=false ]
item file:
//POE Stuff
// state of the execution, is running or finished
Switch poe_actions_Run {channel="exec:command:poe_actions:run", autoupdate="false"}
// Arguments to be placed for '%2$s' in command line
String poe_actions_Args {channel="exec:command:poe_actions:input"}
// Output of command line execution
String poe_actions_Out {channel="exec:command:poe_actions:output"}
rule file (presence is arranged through the Unifi binding):
rule "Presence changing"
Item Presence changed
then {
logInfo("Rule presence 03", "Presence just changed!")
switch (Presence.state) {
case ON : {
logInfo("Rule presence 03", "Presence just became ON!")
poe_actions_Args.sendCommand("192.168.1.15 5 auto") // Switch ON telephone
poe_actions_Run.sendCommand(ON)
case OFF : {
logInfo("Rule presence 03", "Presence just became OFF!")
poe_actions_Args.sendCommand("192.168.1.15 5 shutdown") // Switch OFF telephone
quit a bit of hacking , make sure the script file is executable, SSHPAS is installed, the EXEC binding is installed and that the openhab user is allowed to run the file. I btw use a Docker OH2.5 image
My dev env has been restored and I have merged all my local work and sorted my github config considering the changes in “master”. I’m finally back in business
The latest build includes all my local (unpublished) improvements / features that had been (partially?) implemented and still in need of testing
I installed the latest build and it works well so far.
A problem I have since a while is that iPhone XS (on IOS 13.3) is disconnecting often. It seems to go into sleep mode and disconnects from wifi.
Another iPhone 8 (on IOS 13.3) is working like a charm.
Anyone with the same behavior?
