Hi all
seen this a few times. And this is what I’ve observed from the log file. I shut down the system to install a new binding manually in the add on folder and when I went to start it, the server rebooted.
Any ideas as to why?
Dec 20 10:08:33 openhab2 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Dec 20 10:08:39 openhab2 karaf[1462]: Write action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errorWrite action failed! Input/output errororg.osgi.framework.BundleException: Unable to acquire the state change lock for the module: osgi.identity; type="osgi.bundle"; version:Version="3.12.100.v20180210-1608"; osgi.identity="org.eclipse.osgi"; singleton:="true" [id=0] STOPPED [STOPPED]
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.container.Module.lockStateChange(Module.java:337)
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.asyncStop(EquinoxBundle.java:156)
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.stop(EquinoxBundle.java:262)
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle.stop(EquinoxBundle.java:267)
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.launch.Equinox.stop(Equinox.java:123)
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.apache.karaf.main.Main$2.run(Main.java:354)
Dec 20 10:08:39 openhab2 karaf[1462]: Caused by: java.util.concurrent.TimeoutException: Timeout after waiting 5 seconds to acquire the lock.
Dec 20 10:08:39 openhab2 karaf[1462]: #011at org.eclipse.osgi.container.Module.lockStateChange(Module.java:334)
Dec 20 10:08:39 openhab2 karaf[1462]: #011... 5 more
Dec 20 10:08:51 openhab2 systemd[1]: Stopped openHAB 2 - empowering the smart home.
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0000256/cgroup/filp(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/sock_inode_cache/cgroup/sock_inode_cache(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0002112/cgroup/mm_struct(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0000704/cgroup/files_cache(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0000208/cgroup/vm_area_struct(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0001024/cgroup/signal_cache(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0005824/cgroup/task_struct(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:A-0000064/cgroup/pid(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/anon_vma/cgroup/anon_vma(1038:openhab2.service)"
Dec 20 10:08:51 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/sighand_cache/cgroup/sighand_cache(1038:openhab2.service)"
Dec 20 10:08:52 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:0000192/cgroup/kmalloc-192(1038:openhab2.service)"
Dec 20 10:08:52 openhab2 snapd[1573]: udevmon.go:184: udev monitor observed remove event for unknown device "/sys/kernel/slab/:0001024/cgroup/kmalloc-1024(1038:openhab2.service)"
Dec 20 10:09:03 openhab2 systemd[1]: Started Session 28 of user kris.
Dec 20 10:09:53 openhab2 systemd[1]: Started Session 29 of user kris.
Dec 20 10:10:20 openhab2 systemd[1]: Started openHAB 2 - empowering the smart home.
Dec 20 10:11:10 openhab2 influxd[1284]: [httpd] 192.168.0.3 - - [20/Dec/2018:10:11:10 +1100] "GET /ping HTTP/1.1" 204 0 "-" "okhttp/2.4.0" 5f626271-03e3-11e9-8926-e02f6de0d414 137
Dec 20 10:11:13 openhab2 systemd[1]: Stopping openHAB 2 - empowering the smart home...
Dec 20 10:11:19 openhab2 systemd[1]: Stopping NFS status monitor for NFSv2/3 locking....
Dec 20 10:11:19 openhab2 systemd[1]: Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Dec 20 10:11:19 openhab2 systemd[1]: Stopping User Manager for UID 1000...
Dec 20 10:11:19 openhab2 systemd[1]: Stopped target RPC Port Mapper.
Dec 20 10:11:19 openhab2 systemd[1]: Stopped target Cloud-init target.
Dec 20 10:11:19 openhab2 systemd[1]: Stopped target Remote File Systems (Pre).
Dec 20 10:11:19 openhab2 systemd[32501]: Stopped target Default.
