I have a kmtronic and I am sending and receiving information using UDP commands.
To know the state of the ports of the Kmtronic I am using the following configuration (.items):
String KmT_in " " {udp="<[192.168.1.151:12345:‘FF0000’]"}
This should return anything like “000000”, but only return… well, nothing
Then I change to: String KmT_in " " {udp=">[192.168.1.151:12345:‘FF0000’]"}
and start return “FF0000”
Then I changed to it’s initial value: String KmT_in " " {udp="<[192.168.1.151:12345:‘FF0000’]"}
And it starts to work fine.
If you restart the openhab, it all starts again in the same way.
Only works if you repeat these steps
Any clue?
