UI editor tooltips not working
Hi all!
How do i get the “tooltips” in the main-UI to work?
I’ve tried different browsers but no code-suggestions are showing…
thanks
They will show up if you starting to type something or you could use CTRL + Space at the desired position within the YAML structure to bring them up.
If it does not work for you, more informations regarding your version and the steps you’ ve tried would be helpful.
Many thx!
CTRL+Space did the trick :relaxed:
