Hmm, says 4.0.3.
"version": "5",
"locale": "en_US",
"measurementSystem": "US",
"runtimeInfo": {
"version": "4.0.3",
"buildString": "Release Build"
"links": [
"type": "systeminfo",
"url": "http://openhab-server:8080/rest/systeminfo"
"type": "persistence",
"url": "http://openhab-server:8080/rest/persistence"
"type": "things",
"url": "http://openhab-server:8080/rest/things"
"type": "voice",
"url": "http://openhab-server:8080/rest/voice"
"type": "items",
"url": "http://openhab-server:8080/rest/items"
"type": "sitemaps",
"url": "http://openhab-server:8080/rest/sitemaps"
"type": "config-descriptions",
"url": "http://openhab-server:8080/rest/config-descriptions"
"type": "auth",
"url": "http://openhab-server:8080/rest/auth"
"type": "tags",
"url": "http://openhab-server:8080/rest/tags"
"type": "channel-types",
"url": "http://openhab-server:8080/rest/channel-types"
"type": "habpanel",
"url": "http://openhab-server:8080/rest/habpanel"
"type": "iconsets",
"url": "http://openhab-server:8080/rest/iconsets"
"type": "services",
"url": "http://openhab-server:8080/rest/services"
"type": "templates",
"url": "http://openhab-server:8080/rest/templates"
"type": "profile-types",
"url": "http://openhab-server:8080/rest/profile-types"
"type": "logging",
"url": "http://openhab-server:8080/rest/logging"
"type": "actions",
"url": "http://openhab-server:8080/rest/actions"
"type": "links",
"url": "http://openhab-server:8080/rest/links"
"type": "events",
"url": "http://openhab-server:8080/rest/events"
"type": "audio",
"url": "http://openhab-server:8080/rest/audio"
"type": "transformations",
"url": "http://openhab-server:8080/rest/transformations"
"type": "inbox",
"url": "http://openhab-server:8080/rest/inbox"
"type": "addons",
"url": "http://openhab-server:8080/rest/addons"
"type": "spec",
"url": "http://openhab-server:8080/rest/spec"
"type": "uuid",
"url": "http://openhab-server:8080/rest/uuid"
"type": "ui",
"url": "http://openhab-server:8080/rest/ui"
"type": "rules",
"url": "http://openhab-server:8080/rest/rules"
"type": "module-types",
"url": "http://openhab-server:8080/rest/module-types"
"type": "thing-types",
"url": "http://openhab-server:8080/rest/thing-types"
"type": "discovery",
"url": "http://openhab-server:8080/rest/discovery"
Hereβs the running process:
openhab 1100 0.0 30.7 2445264 634004 - I 11:47 3:00.05 | `-- /usr/local/openjdk17/bin/java -XX:-UsePerfData -Dopenhab.home=/usr/local/libexec/openhab -Dopenhab.conf=/usr/local/etc/openhab -Dopenhab.runtime=/usr/local/libexec/openhab/runtime -Dopenhab.userdata=/var/db/openhab/userdata -Dopenhab.logdir=/var/log/openhab -Dfelix.cm.dir=/var/db/openhab/userdata/config -Djava.library.path=/var/db/openhab/userdata/tmp/lib -Djdk.util.zip.disableZip64ExtraFieldValidation=true -Djetty.host=0.0.0.0 -Djetty.http.compliance=RFC2616 -Dorg.apache.cxf.osgi.http.transport.disable=true -Dorg.ops4j.pax.web.listening.addresses=0.0.0.0 -Dorg.osgi.service.http.port=8080 -Dorg.osgi.service.http.port.secure=8443 -Djava.awt.headless=true -Dfile.encoding=UTF-8 -Dgnu.io.rxtx.SerialPorts=/dev/cuau0 -Dsun.nio.fs.watchservice=polling -Djava.net.preferIPv4Stack=true -Dsun.nio.fs.watchservice=polling --add-reads=java.xml=java.logging --add-exports=java.base/org.apache.karaf.specs.locator=java.xml,ALL-UNNAMED --patch-module java.base=/usr/local/libexec/openhab/runtime/lib/endorsed/org.apache.karaf.specs.locator-4.4.5.jar --patch-module java.xml=/usr/local/libexec/openhab/runtime/lib/endorsed/org.apache.karaf.specs.java.xml-4.4.5.jar --add-opens java.base/java.security=ALL-UNNAMED --add-opens java.base/java.net=ALL-UNNAMED --add-opens java.base/java.lang=ALL-UNNAMED --add-opens java.base/java.util=ALL-UNNAMED --add-opens java.naming/javax.naming.spi=ALL-UNNAMED --add-opens java.rmi/sun.rmi.transport.tcp=ALL-UNNAMED --add-opens java.base/java.io=ALL-UNNAMED --add-opens java.base/java.lang.reflect=ALL-UNNAMED --add-opens java.base/java.text=ALL-UNNAMED --add-opens java.base/java.time=ALL-UNNAMED --add-opens java.desktop/java.awt.font=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.file=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.ftp=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.http=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.https=ALL-UNNAMED --add-exports=java.base/sun.net.www.protocol.jar=ALL-UNNAMED --add-exports=java.base/sun.net.www.content.text=ALL
Hereβs the SHA1 sum of the binary:
7debec3431d5a7834bdca4534a6ff613c9e0f272 /usr/local/libexec/openhab/runtime/bin/karaf
If you need me to check other files, let me know which ones.
