Hi Folks,
I’ve recently moved house, and I’ve decided to switch to OpenHAB2 but to start from scratch and copying over stuff I need as I go.
I’ve set up some of my devices onto OpenHAB, and that’s all good - and on PaperUI Control everything is coming across fine (I’d use it, but I seem to only have limited control as to where items appear). On BasicUI, my text fields which are populated from my Sonos only get populated on a state change, such as a song changing - so when you first load it it’s blank.
On android, my text fields don’t get populated no matter what. However on both the PaperUI and Android my Sonos and Hue changes on things like switches and sliders come across either instantly or within a few seconds - even if I make the changes outside of OpenHAB.
The issue is just with text fields.
Here is my sitemap:
sitemap main label="My home automation 2" {
Frame label="Sonos Office" {
Default item=SonosOffice_Controlcontent
Slider item=SonosOffice_Volume
Text item=SonosOffice_CurrentTitle
Text item=SonosOffice_CurrentAlbum
Text item=SonosOffice_CurrentArtist
Text item=SonosOffice_ZoneName
Frame label="Sonos Bathroom" {
Default item=SonosBathroom_Controlcontent
Slider item=SonosBathroom_Volume
Text item=SonosBathroom_CurrentTitle
Text item=SonosBathroom_CurrentAlbum
Text item=SonosBathroom_CurrentArtist
Text item=SonosBathroom_ZoneName
Frame label="Sonos Bedroom" {
Default item=SonosBedroom_Controlcontent
Slider item=SonosBedroom_Volume
Text item=SonosBedroom_CurrentTitle
Text item=SonosBedroom_CurrentAlbum
Text item=SonosBedroom_CurrentArtist
Text item=SonosBedroom_ZoneName
Frame label="Sonos Living Room" {
Default item=SonosLivingRoom_Controlcontent
Slider item=SonosLivingRoom_Volume
Text item=SonosLivingRoom_CurrentTitle
Text item=SonosLivingRoom_CurrentAlbum
Text item=SonosLivingRoom_CurrentArtist
Text item=SonosLivingRoom_ZoneName
Frame label="Sonos Kitchen" {
Default item=SonosKitchen_Controlcontent
Slider item=SonosKitchen_Volume
Text item=SonosKitchen_CurrentTitle
Text item=SonosKitchen_CurrentAlbum
Text item=SonosKitchen_CurrentArtist
Text item=SonosKitchen_ZoneName
Frame label="Office Lights" {
Slider item=OfficeMain_Brightness label="Main"
Slider item=OfficeLamp_Brightness label="Lamp"
Slider item=Lights_Office
I also have RRD4J turned on.
