UI Widget: Weather
Look at this post
I have redesign the widget with the “f7-items-group” instead of “f7-items-list”.
My problem was, that ther were no dividers, no space between the listitems.
Here ist the Code for the whole widget.
uid: weatherPopup
tags:
  - weather
  - popup
  - daily forecast
  - OpenWeatherMap
props:
  parameters:
    - description: <b>Optional prefix</b> for item names.
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
    - description: <b>Additional prefix</b> for item names that belongs to another Things channel (valid for 'StationName' as it might differ)
      label: Additional item prefix
      required: false
      type: TEXT
      groupName: general
      advanced: true
    - description: The number of days you want to forecast (<u>default:</u> <b>3</b>)
      label: Number of days to forecast
      required: false
      type: TEXT
      groupName: general
    - description: Format of the timestamp (<u>default:</u> <b>HH:mm</b>)<br>Visit <a 'https://day.js.org/docs/en/display/format'>https://day.js.org/docs/en/display/format</a> for more informations.
      label: Timestamp format
      required: false
      type: TEXT
      groupName: general
    - description: Add suffix to the timestamp
      label: Custom timestamp suffix
      required: false
      type: TEXT
      groupName: general
    - description: Overwrite the location header
      label: Location title
      required: false
      type: TEXT
      groupName: general
    - label: Translation 'Feel'
      required: false
      type: TEXT
      groupName: wording
    - label: Translation 'Humidity'
      required: false
      type: TEXT
      groupName: wording
    - label: Translation 'Wind'
      required: false
      type: TEXT
      groupName: wording
    - label: Translation '%-Precipitation'
      required: false
      type: TEXT
      groupName: wording
    - label: Translation 'Last Update'
      required: false
      type: TEXT
      groupName: wording
  parameterGroups:
    - name: general
      label: General settings
    - name: wording
      label: Language settings
      description: Set alternative wordings
timestamp: May 2, 2024, 10:41:09 PM
component: f7-page
  style:
    position: relative
    -ms-user-select: none
    -moz-user-select: none
    -webkit-user-select: none
    user-select: none
    background: rgba(42,48,78,1)
    --f7-theme-color: none
    --f7-page-content-extra-padding-top: 0
    --f7-bars-bg-color: none
    --f7-bars-border-color: none
    --f7-navbar-shadow-image: none
    --f7-navbar-text-color: white
    --f7-bars-text-color: white
    --f7-navbar-link-color: white
    --f7-list-bg-color: rgba(0,0,0,.15)
    --f7-list-border-color: none
    --f7-list-margin-vertical: 7px
    --f7-page-navbar-offset: none
    --f7-page-toolbar-top-offset: none
    --f7-page-subnavbar-offset: none
    --f7-page-searchbar-offset: none
    --f7-bars-translucent-opacity: none
    --f7-bars-translucent-blur: none
    backdrop-filter: none
    --f7-button-border-radius: 0
    --weather-base-font-color: 255,255,255
    --weather-base-text-shadow-color: 0,0,0
    --weather-font-color: rgba(var(--weather-base-font-color),1)
    --weather-transparent-font-color: rgba(var(--weather-base-font-color),.75)
    --weather-text-shadow-color: rgba(var(--weather-base-text-shadow-color),.25)
    --weather-icon-color: rgba(var(--weather-base-font-color),1)
    --weather-hero-font-size: 91px
    --weather-hero-text-shadow: 2px 2px rgba(0,0,0,.35)
    --weather-small-font-size: 16px
    --weather-normal-font-size: 18px
slots:
  default:
    - component: f7-block
        style:
          background: "=(dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state) ? 'linear-gradient(to bottom, #355b8e, #c0d4f0)' : 'linear-gradient(to bottom, #413D8F, #CE9FC8)'"
          background-size: cover
          background-repeat: no-repeat
          background-position: bottom left
          padding: 30px 0 60px 0
          margin-top: 0
      slots:
        default:
              class:
                - no-padding
                - no-margin
              style:
                border-top: 80px solid white
                border-image-source: url('data:image/svg+xml,%3Csvg width="100%" height="100%" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:1.41421;"%3E%3Cg transform="matrix(1,0,0,0.198289,0,-19.1443)"%3E%3Cpath d="M2000,116C1713.19,117.226 1658.73,122.546 1360.08,153.634C1159.33,174.531 926.563,327.589 572.792,351.218C337.726,366.918 155.294,280.98 0,298.274L0,500L2000,500L2000,116Z" style="fill:rgba(42,48,78,1);" /%3E%3C/g%3E%3C/svg%3E')
                -moz-border-image-source: url('data:image/svg+xml,%3Csvg width="100%" height="100%" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:1.41421;"%3E%3Cg transform="matrix(1,0,0,0.198289,0,-19.1443)"%3E%3Cpath d="M2000,116C1713.19,117.226 1658.73,122.546 1360.08,153.634C1159.33,174.531 926.563,327.589 572.792,351.218C337.726,366.918 155.294,280.98 0,298.274L0,500L2000,500L2000,116Z" style="fill:rgba(42,48,78,1""/%3E%3C/g%3E%3C/svg%3E')
                -webkit-border-image-source: url('data:image/svg+xml,%3Csvg width="100%" height="100%" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:1.41421;"%3E%3Cg transform="matrix(1,0,0,0.198289,0,-19.1443)"%3E%3Cpath d="M2000,116C1713.19,117.226 1658.73,122.546 1360.08,153.634C1159.33,174.531 926.563,327.589 572.792,351.218C337.726,366.918 155.294,280.98 0,298.274L0,500L2000,500L2000,116Z" style="fill:rgba(42,48,78,1)"/%3E%3C/g%3E%3C/svg%3E')
                -o-border-image-source: url('data:image/svg+xml,%3Csvg width="100%" height="100%" version="1.1" xmlns="http://www.w3.org/2000/svg" xmlns:xlink="http://www.w3.org/1999/xlink" xml:space="preserve" xmlns:serif="http://www.serif.com/" style="fill-rule:evenodd;clip-rule:evenodd;stroke-linejoin:round;stroke-miterlimit:1.41421;"%3E%3Cg transform="matrix(1,0,0,0.198289,0,-19.1443)"%3E%3Cpath d="M2000,116C1713.19,117.226 1658.73,122.546 1360.08,153.634C1159.33,174.531 926.563,327.589 572.792,351.218C337.726,366.918 155.294,280.98 0,298.274L0,500L2000,500L2000,116Z" style="fill:rgba(42,48,78,1"/%3E%3C/g%3E%3C/svg%3E')
                -webkit-appearance: none
                border-image-slice: 100% 0 0 0
                border-image-width: 1 0 0 0
                width: 100%
                position: absolute
                left: 0
                bottom: 0
                height: 100%
                max-height: 80px
              style:
                text-align: center
              class:
                - no-margin
                - no-padding
            slots:
              default:
                - component: f7-row
                    class:
                      - justify-content-center
                  slots:
                    default:
                      - component: Label
                          text: "=!props.locationTitle ? items[(!props.itemPrefix2 ? (!props.itemPrefix ? '' : props.itemPrefix) : props.itemPrefix2) + 'StationName'].state : props.locationTitle"
                          style:
                            margin-top: calc(var(--f7-toolbar-height) / 2 - var(--f7-toolbar-height))
                            margin-bottom: 20px
                            font-size: var(--weather-normal-font-size)
                            color: var(--weather-font-color)
                            text-shadow: 2px 2px var(--weather-text-shadow-color)
                            white-space: nowrap
                            overflow: hidden
                            text-overflow: ellipsis
                            line-height: var(--f7-navbar-link-line-height,var(--f7-navbar-height))
                            text-transform: uppercase
                - component: f7-row
                    class:
                  slots:
                    default:
                      - component: Label
                          text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Temperature'].state.split(' ')[0]) + '°'"
                          style:
                            line-height: var(--weather-hero-font-size)
                            font-size: var(--weather-hero-font-size)
                            white-space: nowrap
                            overflow: hidden
                      - component: f7-icon
                          f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50n') ? 'cloud_fog_fill' : ''"
                          class:
                            - align-self-center
                          style:
                            color: var(--weather-icon-color)
                - component: Label
                    text: "=(!props.itemPrefix) ? items.Current_Condition.state : items[props.itemPrefix + 'Current_Condition'].state"
                    class:
                      - no-padding-top
                    style:
                      text-shadow: .5px .5px var(--weather-text-shadow-color)
                      white-space: nowrap
                      overflow: hidden
                - component: f7-row
                    class:
                    style:
                      flex-wrap: nowrap
                  slots:
                    default:
                      - component: Label
                          text: "=!props.wordingFeel ? 'Feel: ' : props.wordingFeel + ': '"
                          style:
                            color: var(--weather-transparent-font-color)
                            white-space: nowrap
                            overflow: hidden
                      - component: Label
                          text: "=(!props.itemPrefix) ? Math.round(items.Current_Apparenttemperature.state.split(' ')[0]) + '°' : Math.round(items[props.itemPrefix + 'Current_Apparenttemperature'].state.split(' ')[0]) + '°'"
                          style:
                            font-weight: 600
        style:
          margin-top: -20px
        class:
          - no-padding
      slots:
        default:
          - component: f7-row
              class:
                - no-gap
            slots:
              default:
                - component: f7-col
                    style:
                      text-align: center
                      border-right: 2px solid var(--weather-font-color)
                  slots:
                    default:
                          f7: drop
                          style:
                      - component: Label
                          text: "=(!props.itemPrefix) ? items.ForecastToday_Humidity.state : items[props.itemPrefix + 'ForecastToday_Humidity'].state"
                          style:
                            white-space: nowrap
                            overflow: hidden
                - component: f7-col
                    style:
                      text-align: center
                  slots:
                    default:
                          f7: thermometer
                          style:
                            width: 100%
                      - component: f7-row
                          style:
                            flex-wrap: nowrap
                          class:
                        slots:
                          default:
                            - component: Label
                                text: "=(!props.itemPrefix) ? Math.round(items.ForecastToday_Maxtemperature.state.split(' ')[0]) + '°' : Math.round(items[props.itemPrefix + 'ForecastToday_Maxtemperature'].state.split(' ')[0]) + '°'"
                                style:
                                  padding-right: 7px
                                  white-space: nowrap
                                  overflow: hidden
                            - component: Label
                                text: "=(!props.itemPrefix) ? Math.round(items.ForecastToday_Mintemperature.state.split(' ')[0]) + '°' : Math.round(items[props.itemPrefix + 'ForecastToday_Mintemperature'].state.split(' ')[0]) + '°'"
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                - component: f7-col
                    style:
                      text-align: center
                  slots:
                    default:
                          f7: wind
                          style:
                      - component: Label
                          text: "=(!props.itemPrefix) ? items.ForecastToday_Windspeed.displayState : items[props.itemPrefix + 'ForecastToday_Windspeed'].displayState"
                          style:
                            white-space: nowrap
                            overflow: hidden
    - component: oh-repeater
        sourceType: range
        for: days
        rangeStart: 1
        rangeStop: "=!props.forecastDays ? 3 : Number(props.forecastDays)"
      slots:
        default:
          - component: f7-list
            slots:
              default:
                - component: f7-accordion-item
                    style:
                  slots:
                    default:
                      - component: f7-accordion-toggle
                        slots:
                          default:
                            - component: f7-row
                                style:
                                  flex-wrap: nowrap
                                class:
                                  - align-items-center
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        overflow: hidden
                                        flex-wrap: nowrap
                                        margin: 5px 0 5px 16px
                                      class:
                                    slots:
                                      default:
                                            f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Iconid'].state === '50n') ? 'cloud_fog_fill' : ''"
                                            style:
                                              padding-right: 7px
                                        - component: Label
                                            text: =dayjs().add(loop.days,'days').format('dddd')
                                            style:
                                              font-size: var(--weather-small-font-size)
                                              overflow: hidden
                                  - component: f7-row
                                      style:
                                        flex-wrap: nowrap
                                        margin: 5px 16px 5px 7px
                                    slots:
                                      default:
                                        - component: Label
                                            text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Maxtemperature'].state.split(' ')[0]) + '°'"
                                            style:
                                              margin-right: 7px
                                              min-width: 27px
                                              text-align: right
                                        - component: Label
                                            text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Mintemperature'].state.split(' ')[0]) + '°'"
                                            style:
                                              color: rgba(255,255,255,.75)
                                              min-width: 27px
                                              text-align: right
                      - component: f7-accordion-content
                        slots:
                          default:
                            - component: f7-list-group
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        flex-wrap: nowrap
                                        border-bottom: solid 1px
                                        border-color: hsla(0,0%,100%,0.15)
                                      class:
                                    slots:
                                      default:
                                        - component: f7-row
                                            style:
                                              overflow: hidden
                                              flex-wrap: nowrap
                                              padding: 5px 0 5px 16px
                                            class:
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=!props.wordingHumidity ? 'Humidity' : props.wordingHumidity"
                                                  style:
                                        - component: f7-row
                                            style:
                                              flex-wrap: nowrap
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Humidity'].state"
                                                  style:
                                                    margin-right: 7px
                                                    min-width: 27px
                                                    text-align: right
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        flex-wrap: nowrap
                                      class:
                                    slots:
                                      default:
                                        - component: f7-row
                                            style:
                                              overflow: hidden
                                              flex-wrap: nowrap
                                            class:
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=!props.wordingWind ? 'Wind' : props.wordingWind"
                                                  style:
                                        - component: f7-row
                                            style:
                                              flex-wrap: nowrap
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Windspeed'].displayState"
                                                  style:
                                                    margin-right: 7px
                                                    min-width: 27px
                                                    text-align: right
                              slots:
                                default:
                                  - component: f7-row
                                      style:
                                        flex-wrap: nowrap
                                      class:
                                    slots:
                                      default:
                                        - component: f7-row
                                            style:
                                              overflow: hidden
                                              flex-wrap: nowrap
                                            class:
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=!props.wordingPrecipitation ? '%-Precipitation' : props.wordingPrecipitation"
                                                  style:
                                        - component: f7-row
                                            style:
                                              flex-wrap: nowrap
                                          slots:
                                            default:
                                              - component: Label
                                                  text: "=items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.days === 1) ? 'ForecastTomorrow' : 'ForecastDay' + (loop.days_idx+1)) + '_Precipprobability'].state.split(' ')[0] + '%'"
                                                  style:
                                                    margin-right: 7px
                                                    min-width: 27px
                                                    text-align: right
        style:
          text-align: center
      slots:
        default:
          - component: Label
              text: "=(!props.wordingLastUpdate ? 'Last Update: ' : props.wordingLastUpdate + ': ') + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ObservationTime'].state).format((!props.timestampFormat) ? 'HH:mm' : props.timestampFormat) + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix)"
              style:
                white-space: nowrap
                overflow: hidden
thanks to @kristofejro, who gave me the hint to the other post.
I had a few problems with the WeatherCard and would like to briefly share here how I solved them.
Firstly, the icons were not displayed, but only large “?”.
To solve this, you have to click on “show advanced” at the top when creating the items from the channels so that an item is really created for all channels.
Then I had the problem that the humidity is not displayed at the top right and the precipitation tab always shows 100%. I have adjusted the code a little bit. The modified widget code follows here (line 354 and 801):
uid: weatherCard
tags:
  - allInOne
  - weather
  - expandable
  - OpenWeatherMap
  - daily forecast
  - hourly forecast
props:
  parameters:
      label: Item prefix
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
    - description: The number of hours you want to forecast (<u>default:</u> <b>12</b>)
      label: Number of hours to forecast
      required: false
      type: TEXT
      groupName: general
      required: false
      type: TEXT
      groupName: general
    - description: Show all informations at once (increases height)
      label: Big card
      required: false
      type: BOOLEAN
      groupName: lookandfeel
    - description: Use this only on screens with a very small view-width
      label: Mobile optimized
      required: false
      type: BOOLEAN
      advanced: true
    - description: Set a background-image which will be shown during the day (if empty it will fall back to the linear-gradient)
      label: Background image-url (day-cycle)
      required: false
      type: TEXT
    - description: Set a background-image which will be shown during the night (if empty it will fall back to the linear-gradient)
      label: Background image-url (night-cycle)
      required: false
      type: TEXT
    - description: Activate day & night Indication on hourly forecast (background color & sunrise / sunset indicator icon)
      label: Show sunrise & sunset
      required: false
      type: BOOLEAN
    - description: Overwrite the global font-color as rgb (<u>default:</u> <b>255,255,255<b>)
      label: Font color (rgb)
      required: false
      type: TEXT
    - description: Overwrite the global text shadow color as rgb (<u>default:</u> <b>0,0,0<b>)
      label: Text shadow color(rgb)
      required: false
      type: TEXT
    - label: Daytime background indication color
      required: false
      type: TEXT
      advanced: true
    - label: Nighttime background indication color
      required: false
      type: TEXT
      advanced: true
    - description: Overwrite the station location name
      required: false
      type: TEXT
      groupName: localization
    - description: Format of the timestamp below the location-name (<u>default:</u> <b>DD. MMMM YYYY</b>)<br>Visit <a 'https://day.js.org/docs/en/display/format'>https://day.js.org/docs/en/display/format</a> for more informations.
      required: false
      type: TEXT
    - description: Acitvate 24-hour time-format (<u>default:</u> <b>12-hour clock-format</b>)
      label: 24h hour-format
      required: false
      type: BOOLEAN
    - description: Add suffix to the hourly-forecast timestamp
      label: Custom hour suffix
      required: false
      type: TEXT
      required: false
      type: TEXT
    - label: Translation 'Hourly'
      required: false
      type: TEXT
    - label: Translation 'Daily'
      required: false
      type: TEXT
      required: false
      type: TEXT
    - label: Translation 'Now'
      required: false
      type: TEXT
    - label: Translation 'Today'
      required: false
      type: TEXT
    - label: Translation 'Sunrise at'
      required: false
      type: TEXT
    - label: Translation 'Sunset at'
      required: false
      type: TEXT
  parameterGroups:
    - name: general
    - name: widgetAction
      context: action
      label: Action
      description: Action to perform when the element is clicked (<b>Experimental</b>)
    - name: lookandfeel
      label: Look & Feel
      description: Everything that influences the look & feel of the widget
    - name: localization
      label: Localization settings
      description: Set alternative wordings & date pattern
timestamp: Jul 3, 2024, 4:49:38 PM
component: f7-card
  class:
    - padding
  style:
    overflow: hidden
    height: "=(props.bigCard) ? '' : '160px'"
    user-select: none
    background: "=dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ? 'linear-gradient(to bottom, #355b8e, #c0d4f0)' : 'linear-gradient(to bottom, #413D8F, #CE9FC8)'"
    border-radius: var(--weather-card-border-radius)
    --weather-card-color: "=(!props.fontColor) ? '255,255,255' : props.fontColor"
    --weather-card-text-shadow-color: "=(!props.textShadowColor) ? '0,0,0' : props.textShadowColor"
    --weather-card-text-color: rgba(var(--weather-card-color),1)
    color: var(--weather-card-text-color)
    --weather-card-border-radius: 20px
    --weather-font-size-xxsmall: 12px
    --weather-font-size-xsmall: 14px
    --weather-font-size-small: 16px
    --weather-font-size-normal: 18px
    --weather-font-size-large: 26px
    --weather-font-size-xlarge: 60px
    --weather-font-size-xxlarge: 70px
    --weather-text-shadow-light: 2px 2px rgba(var(--weather-card-text-shadow-color),.15)
    --weather-text-shadow-strong: 2px 2px rgba(var(--weather-card-text-shadow-color),.35)
    --weather-text-transform-time: uppercase
slots:
  default:
    - component: oh-link
        visible: "=props.widget_action && (vars.moreInfo === false || !vars.moreInfo) ? true : false"
        actionPropsParameterGroup: widgetAction
        color: white
        class:
          - no-padding
          - no-margin
        style:
          max-height: 192px
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
          z-index: 98
        class:
          - no-padding
          - no-margin
        style:
          background: "=dayjs().format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunrise'].state && dayjs().format() < items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastToday_Sunset'].state ? 'no-repeat 100% / cover url(' + props.backgroundUrlDay + ')' : 'no-repeat 100% / cover url(' + props.backgroundUrlNight + ')'"
          width: 100%
          height: 100%
          position: absolute
          top: 0
          left: 0
    - component: f7-row
        visible: "=(!vars.moreInfo) ? true : false"
      slots:
        default:
          - component: f7-col
              style:
                z-index: 95
            slots:
              default:
                - component: Label
                    style:
                      white-space: nowrap
                      overflow: hidden
                      letter-spacing: .75px
                      font-size: var(--weather-font-size-large)
                      text-shadow: var(--weather-text-shadow-strong)
                      font-weight: 600
                - component: Label
                    text: "=dayjs().format(props.dateScheme ? props.dateScheme : 'DD. MMMM YYYY')"
                    style:
                      white-space: nowrap
                      overflow: hidden
                      color: rgba(var(--weather-card-color),.7)
                      font-size: var(--weather-font-size-xxsmall)
                      text-shadow: var(--weather-text-shadow-light)
                - component: f7-row
                    class:
                    style:
                      flex-wrap: nowrap
                  slots:
                    default:
                          f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                          style:
                            font-size: var(--weather-font-size-xxlarge)
                            padding-top: 5px
                            padding-bottom: 5px
                      - component: f7-col
                          visible: =props.mobile === true
                        slots:
                          default:
                            - component: Label
                                text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Temperature'].state.split(' ')[0] * 10) / 10 + '°'"
                                class:
                                  - padding-left
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: 31px
                                  line-height: 31px
                                  font-weight: 600
                            - component: Label
                                text: "=((!props.wordingFeel) ? 'Feel: ' : props.wordingFeel + ': ') + Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Apparenttemperature'].state.split(' ')[0]) + '°'"
                                class:
                                  - padding-left
                                style:
                                  white-space: nowrap
                                  overflow: hidden
                                  font-size: var(--weather-font-size-small)
                - component: Label
                    text: "=items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Condition'].state"
                    style:
                      white-space: nowrap
                      overflow: hidden
          - component: f7-col
              visible: =!props.mobile
              class:
                - text-align-right
              style:
                align-self: "=props.bigCard ? 'flex-start' : 'flex-end'"
                z-index: 95
            slots:
              default:
                - component: Label
                    style:
                      white-space: nowrap
                      overflow: hidden
                      font-size: var(--weather-font-size-xlarge)
                      line-height: var(--weather-font-size-xlarge)
                      font-weight: 600
                - component: Label
                    style:
                      white-space: nowrap
                      overflow: hidden
                      font-size: var(--weather-font-size-normal)
                - component: f7-row
                    class:
                      - justify-content-flex-end
                    style:
                      flex-wrap: nowrap
                      font-size: var(--weather-font-size-xsmall)
                  slots:
                    default:
                      - component: Label
                          text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Humidity'].state.split(' ')[0] * 100) + ' %'"
                          tooltip: Humidity
                          style:
                            white-space: nowrap
                            overflow: hidden
                      - component: Label
                          text: =" | "
                          style:
                            color: rgba(var(--weather-card-color),.25)
                      - component: Label
                          text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Windspeed'].state.split(' ')[0]) + ' ' + items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Current_Windspeed'].state.split(' ')[1]"
                          tooltip: Windspeed
                          style:
                            white-space: nowrap
                            overflow: hidden
    - component: oh-button
        colorTheme: white
        color: white
        iconMaterial: more_horiz
        iconSize: 20px
        action: variable
        actionVariable: moreInfo
        actionVariableValue: true
        visible: "=(props.bigCard) ? false : ((!vars.moreInfo || vars.moreInfo === false) ? true : false)"
        class:
          - margin-top
          - margin-right
        style:
          position: absolute
          top: 0
          right: 0
          font-weight: 600
          z-index: 99
        colorTheme: white
        color: white
        iconMaterial: close
        iconSize: 20px
        action: variable
        actionVariableValue: false
        visible: "=(props.bigCard) ? false : ((vars.moreInfo || vars.moreInfo === true) ? true : false)"
        class:
          - margin-top
          - margin-right
        style:
          position: absolute
          top: 0
          right: 0
          font-weight: 600
          z-index: 99
        visible: =vars.moreInfo || props.bigCard === true
        class:
          - no-padding
          - no-margin
          - align-items-space-between
      slots:
        default:
          - component: f7-segmented
              strong: true
              textColor: white
              style:
                --f7-segmented-strong-button-active-box-shadow: 0px 4px 0 -1px rgba(var(--weather-card-color),1)
                --f7-segmented-strong-button-active-text-color: rgba(var(--weather-card-color),1)
                --f7-button-text-color: rgba(var(--weather-card-color),.5)
                --f7-segmented-strong-text-color: rgba(var(--weather-card-color),.5)
                --f7-segmented-strong-padding: 3px
                --f7-button-active-text-color: rgba(var(--weather-card-color),1)
                --f7-button-raised-box-shadow: none
                --f7-segmented-strong-button-active-bg-color: transparent
                width: "=(props.bigCard) ? '100%' : 'calc(100% - 38px)'"
                padding-top: "=(props.bigCard) ? '16px' : '0'"
                background: transparent
                z-index: 999
                align-items: flex-end
            slots:
              default:
                    text: "=(!props.wordingForecastHours) ? 'Hourly' : props.wordingForecastHours"
                    active: =vars.tab === 'hourly_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: hourly_forecast
                    text: "=(!props.wordingForecastDays) ? 'Daily' : props.wordingForecastDays"
                    active: =vars.tab === 'daily_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: daily_forecast
                    text: "=(!props.wordingForecastPrecib) ? '%-Precipitation' : props.wordingForecastPrecib"
                    active: =vars.tab === 'precip_forecast'
                    action: variable
                    actionVariable: tab
                    actionVariableValue: precip_forecast
              class:
                - no-padding
              style:
                border-bottom: 4px solid rgba(var(--weather-card-color),.5)
                margin-left: 4px
                margin-right: 4px
          - component: f7-swiper
              visible: =vars.tab === 'hourly_forecast' || !vars.tab
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                runCallbacksOnInit: true
                grabCursor: true
                observer: true
                observeSlideChildren: true
                updateOnWindowResize: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                    slidesPerView: 2
                  "320":
                    slidesPerView: 3
                  "480":
                    slidesPerView: 4
                  "640":
                    slidesPerView: 5
              style:
                --swiper-navigation-size: 30px
                --swiper-navigation-color: var(--weather-card-text-color)
            slots:
              default:
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    rangeStop: "=(!props.forecastHours) ? 12 : Number(props.forecastHours)"
                    fragment: true
                  slots:
                    default:
                      - component: f7-swiper-slide
                          expandable: true
                          style:
                            background: "=(props.sunIndicator) ? ((dayjs().add(loop.hour,'hour').format() >= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state && dayjs().add(loop.hour,'hour').format() <= items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state) ? (!props.sunIndicatorColorDay ? 'rgba(255,255,255,.2)' : props.sunIndicatorColorDay) : (!props.sunIndicatorColorNight ? 'rgba(41,109,152,.2)' : props.sunIndicatorColorNight)) : 'none'"
                            border-radius: 5px
                        slots:
                          default:
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: sun_max_fill
                                tooltip: "=((!props.wordingSunrise) ? 'Sunrise at ' : props.wordingSunrise + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).format('H:mm') + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix) ) + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunrise'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                                visible: "=(dayjs().add(loop.hour,'hour').startOf('hour').format() === dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).startOf('hour').format() && props.sunIndicator === true)"
                                f7: moon_fill
                                tooltip: "=((!props.wordingSunset) ? 'Sunset at ' : props.wordingSunset + ' ') + ((!props.dateFormat) ? dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('h:mm A') : dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).format('H:mm') + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix) ) + '<br><b>' + dayjs(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').format() ? 'Today' : (dayjs().add(loop.hour,'hour').startOf('day').format() === dayjs().startOf('day').add(1,'day').format() ? 'Tomorrow' : 'Day2')) + '_Sunset'].state).fromNow() + '</b>'"
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.hour === 0) ? ((!props.wordingNow) ? 'Now' : props.wordingNow) : ((!props.dateFormat) ? dayjs().add(loop.hour,'hour').startOf('hour').format('h A') : dayjs().add(loop.hour,'hour').startOf('hour').format('H')) + (!props.timestampSuffix ? '' : ' ' + props.timestampSuffix)"
                                      style:
                                        text-transform: var(--weather-text-transform-time)
                                        font-weight: 700
                            - component: f7-col
                                class:
                                  - text-align-center
                              slots:
                                default:
                                      f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                                      style:
                                        padding-top: 5px
                                        padding-bottom: 5px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + ((loop.hour === 0) ? 'Current' : 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1))) + '_Temperature'].state.split(' ')[0]) + '°'"
                                      style:
                                        font-weight: 400
              visible: =vars.tab === 'daily_forecast'
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                watchOverflow: true
                mousewheel: true
                keyboard: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "210":
                    slidesPerView: "=(!props.forecastDays) ? 2 : ((props.forecastDays < 2) ? Math.round(Number(props.forecastDays) + 1) : 2)"
                  "480":
                    slidesPerView: "=(!props.forecastDays) ? 3 : ((props.forecastDays < 3) ? Math.round(Number(props.forecastDays) + 1) : 3)"
                  "640":
                    slidesPerView: "=(!props.forecastDays) ? 4 : ((props.forecastDays < 4) ? Math.round(Number(props.forecastDays) + 1) : 4)"
              style:
            slots:
              default:
                    sourceType: range
                    for: day
                    rangeStart: 0
                    rangeStop: "=(!props.forecastDays) ? 3 : Number(props.forecastDays)"
                    fragment: true
                  slots:
                    default:
                          class: text-align-center
                        slots:
                          default:
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=(loop.day === 0) ? ((!props.wordingToday) ? 'Today' : props.wordingToday) : dayjs().add(loop.day,'day').startOf('day').format('dddd')"
                                      style:
                                        font-weight: 700
                                f7: "=(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01d') ? 'sun_max_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '01n') ? 'moon_stars_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02d') ? 'cloud_sun_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '02n') ? 'cloud_moon_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '03n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04d') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '04n') ? 'cloud_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09d') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '09n') ? 'cloud_heavyrain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10d') ? 'cloud_sun_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '10n') ? 'cloud_moon_rain_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11d') ? 'cloud_sun_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '11n') ? 'cloud_moon_bolt_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13d') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '13n') ? 'cloud_snow_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50d') ? 'cloud_fog_fill' : (items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + (((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + loop.day_idx))) + '_Iconid'].state === '50n') ? 'cloud_fog_fill' : '?'"
                                style:
                                  padding-top: 5px
                                  padding-bottom: 5px
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Maxtemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 400
                                  - component: Label
                                      text: =" | "
                                      style:
                                        color: rgba(255,255,255,.2)
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'Forecast' + ((loop.day === 0) ? 'Today' : ((loop.day === 1) ? 'Tomorrow' : 'Day' + (loop.day_idx))) + '_Mintemperature'].state.split(' ')[0])+'°'"
                                      style:
                                        font-weight: 400
              visible: =vars.tab === 'precip_forecast'
              navigation: true
              class:
                - padding-top
              params:
                initalSlide: 0
                grabCursor: true
                observer: true
                spaceBetween: 5
                mousewheel: true
                keyboard: true
                watchOverflow: true
                breakpoints:
                  "0":
                    slidesPerView: 1
                  "240":
                    slidesPerView: 2
                  "320":
                    slidesPerView: 3
                  "480":
                    slidesPerView: 4
                  "640":
                    slidesPerView: 5
              style:
            slots:
              default:
                    sourceType: range
                    for: hour
                    rangeStart: 0
                    rangeStop: "=(props.forecastHours === undefined) ? 12 : Number(props.forecastHours)"
                    fragment: true
                  slots:
                    default:
                          expandable: true
                          style:
                            border-radius: 5px
                        slots:
                          default:
                                f7: sun_max_fill
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                                f7: moon_fill
                                style:
                                  position: absolute
                                  right: 3px
                                  top: 3px
                                  cursor: pointer
                                  z-index: 998
                            - component: f7-row
                                class:
                              slots:
                                default:
                                  - component: Label
                                      style:
                                        font-weight: 700
                            - component: f7-col
                                class:
                                  - text-align-center
                              slots:
                                default:
                                      f7: umbrella_fill
                                      style:
                                        padding-top: 5px
                                        padding-bottom: 5px
                                  - component: Label
                                      text: "=Math.round(items[((!props.itemPrefix) ? '' : props.itemPrefix) + 'ForecastHours' + ((loop.hour_idx+1 < 10 ? '0'+(loop.hour_idx+1) : loop.hour_idx+1)) + '_Precipprobability'].state.split(' ')[0] * 100) + '%'"
                                      style:
                                        font-weight: 400
Viele Grüße
Andy
Hi all,
I just wanted to share my refactored version of the weatherCard widget.
This new version makes use of the TimeSeries support (since openHAB 4.1.0) that allows to persist forecasts.
You can now finally get rid of the huge amount of hourly and daily forecast channels and Items that were required to use this widget, and I feel like this improves performance of Main UI pages where the widget is added.
The refactored version looks the same, but uses the new oh-context component to reduce code duplication and gets its data from a String Item that holds a JSON (this is created by a JavaScript rule on the server).
You might wonder why the widget does not directly request the forecast data from persistence, there are two reasons: a. I haven’t found a way to implement this in a nice way (yet) and b. I think performance-wise it anyway is better to collect the required data server-side - this way the client has to do less requests and less computations itself.
You can check out my refactored version on GitHub, where the required dependencies are provided as well:
EDIT: I should probably add that this version makes use of the oh-context component, which is broken in openHAB 4.2.0 — I have already created a fix and backported it to 4.2.x so it will be available in the next patch release, but until then you either need to use a recent UI JAR or upgrade to snapshot.
Hello Florian,
I’ve created the rule with the JSON file on my server in /etc/openhab/automation/js/openweathermap.js
I am unable to find the JSON item while configuring the widget in the list. Already restarted the openhab service.
What should be the name of it? Guess it should be openweathermap or something like this. But I cant find anything, just the items.
Regards.
The Item is included in the openweathermap.items and should be named OneCall_JSON.
Thank you. Possible to share your openweathermap.things syntax?
No. I have these Things defined in the UI …
You can basically create the account and OneCall Thing as you like and then replace the channel UIDs in the items file using search and replace.
Hi @florian-h05, I get this error when the openweathermap.js script runs. I added a log line to see what it is looking for just before where I think it fails. Do I need to wait longer to get data into the Item persistence? items.getItem(PREFIX + FORECAST + HOURLY + field).persistence must be returning null, but why?
2024-12-11 20:25:00.089 [INFO ] [mation.script.file.openweathermap.js] - looking for: OneCall_Forecast_Hourly_IconId
2024-12-11 20:25:00.091 [ERROR] [mation.script.file.openweathermap.js] - Failed to execute rule owm-one-call-weather-forecast-json: TypeError: undefined has no such function "getAllStatesBetween": TypeError: undefined has no such function "getAllStatesBetween"
        at addHourlyValues (openweathermap.js:62)
        at createJSON (openweathermap.js:181)
        at <program> (openweathermap.js:196)
        at _run (/etc/openhab/automation/js/node_modules/openhab/src/rules/rule-builder.js:53)
        at execute (/etc/openhab/automation/js/node_modules/openhab/src/rules/rule-builder.js:99)
        at doExecute (/etc/openhab/automation/js/node_modules/openhab/src/rules/rules.js:235)
2024-12-11 20:25:00.092 [ERROR] [e.automation.internal.RuleEngineImpl] - Failed to execute rule 'owm-one-call-weather-forecast-json': Failed to execute action: 1(Error: Failed to execute rule owm-one-call-weather-forecast-json: TypeError: undefined has no such function "getAllStatesBetween": TypeError: undefined has no such function "getAllStatesBetween"
        at doExecute (/etc/openhab/automation/js/node_modules/openhab/src/rules/rules.js:235))
I can see the “OneCall_Forecast_Hourly_IconId” in the event.log. Does this help debug?
I’m on OH 4.3.M5
2024-12-11 19:34:54.665 [INFO ] [openhab.event.ItemTimeSeriesEvent   ] - Item 'OneCall_Forecast_Hourly_IconId' shall process timeseries [Entry[timestamp=2024-12-12T03:00:00Z, state=02n], Entry[timestamp=2024-12-12T04:00:00Z, state=01n], Entry[timestamp=2024-12-12T05:00:00Z, state=02n], Entry[timestamp=2024-12-12T06:00:00Z, state=03n], Entry[timestamp=2024-12-12T07:00:00Z, state=04n], Entry[timestamp=2024-12-12T08:00:00Z, state=10n], Entry[timestamp=2024-12-12T09:00:00Z, state=10n], Entry[timestamp=2024-12-12T10:00:00Z, state=10n], Entry[timestamp=2024-12-12T11:00:00Z, state=10n], Entry[timestamp=2024-12-12T12:00:00Z, state=10n], Entry[timestamp=2024-12-12T13:00:00Z, state=10n], Entry[timestamp=2024-12-12T14:00:00Z, state=10n], Entry[timestamp=2024-12-12T15:00:00Z, state=10n], Entry[timestamp=2024-12-12T16:00:00Z, state=10d], Entry[timestamp=2024-12-12T17:00:00Z, state=10d], Entry[timestamp=2024-12-12T18:00:00Z, state=10d], Entry[timestamp=2024-12-12T19:00:00Z, state=03d], Entry[timestamp=2024-12-12T20:00:00Z, state=03d], Entry[timestamp=2024-12-12T21:00:00Z, state=03d], Entry[timestamp=2024-12-12T22:00:00Z, state=10d], Entry[timestamp=2024-12-12T23:00:00Z, state=10d], Entry[timestamp=2024-12-13T00:00:00Z, state=10d], Entry[timestamp=2024-12-13T01:00:00Z, state=10n], Entry[timestamp=2024-12-13T02:00:00Z, state=10n], Entry[timestamp=2024-12-13T03:00:00Z, state=10n], Entry[timestamp=2024-12-13T04:00:00Z, state=10n], Entry[timestamp=2024-12-13T05:00:00Z, state=10n], Entry[timestamp=2024-12-13T06:00:00Z, state=10n], Entry[timestamp=2024-12-13T07:00:00Z, state=10n], Entry[timestamp=2024-12-13T08:00:00Z, state=10n], Entry[timestamp=2024-12-13T09:00:00Z, state=04n], Entry[timestamp=2024-12-13T10:00:00Z, state=04n], Entry[timestamp=2024-12-13T11:00:00Z, state=04n], Entry[timestamp=2024-12-13T12:00:00Z, state=04n], Entry[timestamp=2024-12-13T13:00:00Z, state=04n], Entry[timestamp=2024-12-13T14:00:00Z, state=10n], Entry[timestamp=2024-12-13T15:00:00Z, state=10n], Entry[timestamp=2024-12-13T16:00:00Z, state=10d], Entry[timestamp=2024-12-13T17:00:00Z, state=04d], Entry[timestamp=2024-12-13T18:00:00Z, state=04d], Entry[timestamp=2024-12-13T19:00:00Z, state=04d], Entry[timestamp=2024-12-13T20:00:00Z, state=04d], Entry[timestamp=2024-12-13T21:00:00Z, state=04d], Entry[timestamp=2024-12-13T22:00:00Z, state=04d], Entry[timestamp=2024-12-13T23:00:00Z, state=04d], Entry[timestamp=2024-12-14T00:00:00Z, state=04d], Entry[timestamp=2024-12-14T01:00:00Z, state=04n], Entry[timestamp=2024-12-14T02:00:00Z, state=04n]]
2024-12-11 19:34:54.667 [INFO ] [hab.event.ItemTimeSeriesUpdatedEvent] - Item 'OneCall_Forecast_Hourly_IconId' updated timeseries [Entry[timestamp=2024-12-12T03:00:00Z, state=02n], Entry[timestamp=2024-12-12T04:00:00Z, state=01n], Entry[timestamp=2024-12-12T05:00:00Z, state=02n], Entry[timestamp=2024-12-12T06:00:00Z, state=03n], Entry[timestamp=2024-12-12T07:00:00Z, state=04n], Entry[timestamp=2024-12-12T08:00:00Z, state=10n], Entry[timestamp=2024-12-12T09:00:00Z, state=10n], Entry[timestamp=2024-12-12T10:00:00Z, state=10n], Entry[timestamp=2024-12-12T11:00:00Z, state=10n], Entry[timestamp=2024-12-12T12:00:00Z, state=10n], Entry[timestamp=2024-12-12T13:00:00Z, state=10n], Entry[timestamp=2024-12-12T14:00:00Z, state=10n], Entry[timestamp=2024-12-12T15:00:00Z, state=10n], Entry[timestamp=2024-12-12T16:00:00Z, state=10d], Entry[timestamp=2024-12-12T17:00:00Z, state=10d], Entry[timestamp=2024-12-12T18:00:00Z, state=10d], Entry[timestamp=2024-12-12T19:00:00Z, state=03d], Entry[timestamp=2024-12-12T20:00:00Z, state=03d], Entry[timestamp=2024-12-12T21:00:00Z, state=03d], Entry[timestamp=2024-12-12T22:00:00Z, state=10d], Entry[timestamp=2024-12-12T23:00:00Z, state=10d], Entry[timestamp=2024-12-13T00:00:00Z, state=10d], Entry[timestamp=2024-12-13T01:00:00Z, state=10n], Entry[timestamp=2024-12-13T02:00:00Z, state=10n], Entry[timestamp=2024-12-13T03:00:00Z, state=10n], Entry[timestamp=2024-12-13T04:00:00Z, state=10n], Entry[timestamp=2024-12-13T05:00:00Z, state=10n], Entry[timestamp=2024-12-13T06:00:00Z, state=10n], Entry[timestamp=2024-12-13T07:00:00Z, state=10n], Entry[timestamp=2024-12-13T08:00:00Z, state=10n], Entry[timestamp=2024-12-13T09:00:00Z, state=04n], Entry[timestamp=2024-12-13T10:00:00Z, state=04n], Entry[timestamp=2024-12-13T11:00:00Z, state=04n], Entry[timestamp=2024-12-13T12:00:00Z, state=04n], Entry[timestamp=2024-12-13T13:00:00Z, state=04n], Entry[timestamp=2024-12-13T14:00:00Z, state=10n], Entry[timestamp=2024-12-13T15:00:00Z, state=10n], Entry[timestamp=2024-12-13T16:00:00Z, state=10d], Entry[timestamp=2024-12-13T17:00:00Z, state=04d], Entry[timestamp=2024-12-13T18:00:00Z, state=04d], Entry[timestamp=2024-12-13T19:00:00Z, state=04d], Entry[timestamp=2024-12-13T20:00:00Z, state=04d], Entry[timestamp=2024-12-13T21:00:00Z, state=04d], Entry[timestamp=2024-12-13T22:00:00Z, state=04d], Entry[timestamp=2024-12-13T23:00:00Z, state=04d], Entry[timestamp=2024-12-14T00:00:00Z, state=04d], Entry[timestamp=2024-12-14T01:00:00Z, state=04n], Entry[timestamp=2024-12-14T02:00:00Z, state=04n]]
The OneCall_Forecast_Hourly_IconId state is NULL - is that expected?
Have you double checked your persistence config?
You can check if persistence works by opening the analyzer e.g. for the temperature forecast and selecting InMemory persistence service and a future period.
Yes, it will only have a value once the first entry of the timeseries becomes valid, e.g. at the next full hour.
Still struggling with this. I have now verified that I can see the daily max temperature data in a chart from the forecasted data. I’m using InfluxDB v1 and debugging inmemory on the side.
I added a couple more log lines, but somehow the ‘persistence’ object isn’t defined. What am I missing?
Here’s the code section with log lines added (focusing on daily max temperature):
  console.log("looking for: " + PREFIX + FORECAST + DAILY + field);
  console.log("Item label is: " + items.getItem(PREFIX + FORECAST + DAILY + field).label);
  var maxTempPersistence = items.getItem(PREFIX + FORECAST + DAILY + field).persistence;
  console.log("object type is: " + typeof(maxTempPersistence));
  items.getItem(PREFIX + FORECAST + DAILY + field).persistence.getAllStatesBetween(beginOfDay, beginOfDay.plusDays(days), PERSISTENCE).forEach((s, i) => {
And here we see that .getAllStatesBetween fails. Shouldn’t the ‘.persistence’ have a type? I’m sure I have something misconfigured, but I can’t find it. What else can I do to debug?
2024-12-13 14:55:00.821 [INFO ] [mation.script.file.openweathermap.js] - looking for: OneCall_Forecast_Daily_MaxTemperature
2024-12-13 14:55:00.821 [INFO ] [mation.script.file.openweathermap.js] - Item label is: Max. Temperatur
2024-12-13 14:55:00.821 [INFO ] [mation.script.file.openweathermap.js] - object type is: undefined
2024-12-13 14:55:00.823 [ERROR] [mation.script.file.openweathermap.js] - Failed to execute rule owm-one-call-weather-forecast-json: TypeError: undefined has no such function "getAllStatesBetween": TypeError: undefined has no such function "getAllStatesBetween"
        at addDailyValues (openweathermap.js:102)
        at createJSON (openweathermap.js:184)
        at <program> (openweathermap.js:204)
What is your openHAB version?
Do you have openhab-js manually installed?
OH 4.3.M5. Yes, manually installed. I tried an ‘npm i openhab’, but nothing changed. So I did the npm remove openhab and npm install openhab and it bumped the version from 4.9.0 to 5.8.1. And it works perfectly! That’s the hint I needed. Thank you.
One suggestion for your github weather widget page is add a line or two on the need to set up persistence with the forecast strategy for the gOWM_TimeSeries* in the Configuration section. The github page has good instructions except it doesn’t mention persistence (unless I missed it). It’s necessary to read through this thread to realize that must also be set.
It’s a very good widget - thanks for developing it.
Done :+1:
Hello Florian,
Greeting from snowy Alaska.
I seem to have a type issue with my icon-id and creating the JSON file when the openweathermap.js runs
I’m running OH ver 4.3. I configured all of the items in the item file from the UI, and they are all populating. I created the JSON item and it remaines null.
The items file from gethub shows that the Icons should be a String.
String OneCall_Current_IconId (gOWM) {channel=“openweathermap:onecall:bridge:local:current#icon-id”}
the channels from the One Call item show ICONS to be an Image.
The Persistance appears to be working for the icon as an image,
But the openweathermap.js throws this error when it runs:
looking at the script it does appear to be expecting a string NOT an image.
Stumped on how to resolve. I checked openweathermap, but can’t find any settings for the oneCall item. Any assistance would be appreciated.
Hi Eric,
you linked the wrong channel.
You need to link the icon-id channel to the IconId Item, I guess the icon-id channel might be advanced, in that case enable showing advanced channels.
Thank you SO much. the Icon ID was in fact an advanced Channel Somehow I missed this checkbox. I recreated the Icon ID with the correct channel and it works perfectly.
Thank you so much for creating a wonderful widget and for helping me find my way.
Is it possible to swap the Hourly with the Daily at the bottom of the widget? Is it as straightforward as finding the sections in the widget corresponding to these and swapping them? Or is there more work involved? I’m more interested in daily than hourly. Thanks.
It is as straightforward as finding and swapping the buttons that open them :+1:
