UK MET Office Data Hub Binding (Weather Provider) for openHAB 4.X
logo
This is now part of the standard add-on’s available for openHAB since the last release of 4.X.
I am using the Solar Forecast binding to predict how to operate my solar / battery system. I find that their data is not very useful for UK. So wondering if the UK data also includes solar forecasts?
A new version of this binding has been built here. This supports the latest API, while the current one goes through the PR process: , since the last 4.X release.
Any chance the published tag could be added to this thread so that the binding appears within the openHAB Community Marketplace? Would save having to ‘sideload’ the jar…
Hi @hafniumzinc,
Actually I’m just working through the final bits of the PR / MR process hopefully. So this should be visible as part of the next release I’m hoping if it can get merged in time. In which case, I’ll likely see if I can remove the references here to it, as then it will be like any other binding included in OpenHab. The only cavet is if you are using it the channel names, etc have all had to be updated as part of this process, so if anyone is switching to the released one, then the channel names, etc will have to be adjusted according to the new names in the readme of the published one - sorry.
This is now merged into the last 4.X build before the shift to 5.X. It should be available in the standard builds going forward. It can be found by searching for “metoffice” here: Add-ons | openHAB
