Just come back to the thread after a long time.
I moved away from LightwaveRF heating devices and now have Drayton Wiser, which is much better and also supported in OpenHAB.
I also have Drayton wiser (3 years now) - lightwave just for my sockets, Zwave for everything else.
I am however trying to get my Aurora sockets added with zigbee but struggling at the moment
I bought one of these to see if I could integrate it. I have it working via Alexa so that it appears as a smart device in the Alex app then I have a switch item in OpenHAB with a rule that sends the phrase āTurn socket 1 onā to Alexa if the switch is on and āTurn socket 1 offā when the item goes off.
It works but itās not as neat as I would like.
Iāve tried sniffing the Wi-Fi messages to the socket using WireShark but I see absolutely nothing addressed to the IP address or MAC. I donāt really know WireShark so I must be missing something because I didnāt know that messages could get around the network without being visible to WireShark.
I was hoping to be able to decode the messages so I could reconstruct them (or at least spoof them) via the http binding or a future TCP binding.
I did consider the bg sockets. Donāt have energy monitoring though which was a non starter for me.
Have a look on an mDNS browser too to see if it publishes any lan services.
Thereās a good few places where I donāt need to measure energy because the appliances under control are lights. In those cases, I can either use the consumption figure from the packet or connect my portable monitoring plug for a few hours and get a usage value - itās probably more accurate than the type of monitor you can fit into a smart device anyway! Obviously doesnāt work for variable loads, although even some of those (washing machine, dishwasher) use a similar amount per cycle even if I donāt know what they are consuming at an instant.
There are a good few appliances that I need to use and use them when I need them so knowing what they consume doesnāt inform any decisions. I have enough data about the house without adding more that doesnāt provide any value!
I can see the IP address and MAC but not what it is doing. Look like thereās progress being made here using the Broadlink protocol so hopefully a binding on its way soon.
