- Platform information:
- Hardware: RPi 4b 8 Gb
- OS: Linux/6.6.51+rpt-rpi-v8 (aarch64)
- Java Runtime Environment: Debian, 17.0.13 (undefined)
- openHAB version: 4.3.2
- Issue of the topic:
Dear Community,
I have been using OpenHAB since version 3. I connected it to the myopenHAB cloud and Google Home, and everything worked flawlessly. Over time, I was able to sync changes with Google Home without any issues.
However, after updating to version 4.3.2 and migrating the remaining six Philips Hue lights to Zigbee2MQTT, I added them to OpenHAB and configured the relevant metadata for Google Home. Unfortunately, I could no longer sync the devices using the âSync devicesâ command.
In the Google Home app, I was prompted to log in to my myopenHAB account. After logging in, I received the message: âOpenHAB is not reachable. Please try again.â During this time, I was still able to control previously configured items through Google Home.
After several days of troubleshooting, including restarting OpenHAB, I decided to delete the connection in Google Home and reconnect it. However, I am now unable to link OpenHAB to Google Home. I can still log in to my myopenHAB account through the Google Home app, but the same error message appears: âOpenHAB is not reachable.â
I tried setting the log level of the OpenHAB Cloud Binding to debug but did not see any errors when attempting to connect. The only changes I made before encountering this issue were updating to version 4.3.2 and adding the new lamps through Zigbee2MQTT.
What could be causing this problem?
Thank you all in advance!
- If logs where generated please post these here using code fences:
2025-01-20 20:59:30.123 [DEBUG] [io.openhabcloud.internal.CloudClient] - on(): request
2025-01-20 20:59:30.125 [DEBUG] [io.openhabcloud.internal.CloudClient] - Got request 19165226
2025-01-20 20:59:30.126 [DEBUG] [io.openhabcloud.internal.CloudClient] - Path /rest/items/
2025-01-20 20:59:30.127 [DEBUG] [io.openhabcloud.internal.CloudClient] - Method GET
2025-01-20 20:59:30.128 [DEBUG] [io.openhabcloud.internal.CloudClient] - Headers: {"host":"myopenhab.org","accept":"application/json","user-agent":"openhab-cloud/0.0.1"}
2025-01-20 20:59:30.129 [DEBUG] [io.openhabcloud.internal.CloudClient] - Query {"metadata":"ga,synonyms","fields":"groupNames,groupType,name,label,metadata,type,state"}
2025-01-20 20:59:30.131 [DEBUG] [io.openhabcloud.internal.CloudClient] - Request method is GET
2025-01-20 20:59:30.132 [DEBUG] [io.openhabcloud.internal.CloudClient] - Jetty set header host = myopenhab.org
2025-01-20 20:59:30.133 [DEBUG] [io.openhabcloud.internal.CloudClient] - Jetty set header accept = application/json
2025-01-20 20:59:30.134 [DEBUG] [io.openhabcloud.internal.CloudClient] - Jetty set header user-agent = openhab-cloud/0.0.1
2025-01-20 20:59:30.330 [DEBUG] [io.openhabcloud.internal.CloudClient] - onHeaders 19165226
2025-01-20 20:59:30.335 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16194
2025-01-20 20:59:30.339 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16384
2025-01-20 20:59:30.345 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 190
2025-01-20 20:59:30.588 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16376
2025-01-20 20:59:30.590 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16384
2025-01-20 20:59:30.592 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 8
2025-01-20 20:59:30.806 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16376
2025-01-20 20:59:30.811 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 16384
2025-01-20 20:59:30.816 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 8
2025-01-20 20:59:30.877 [DEBUG] [io.openhabcloud.internal.CloudClient] - onResponseContent: 19165226, content size 10421
2025-01-20 20:59:30.880 [DEBUG] [io.openhabcloud.internal.CloudClient] - onComplete: 19165226
2025-01-20 20:59:30.883 [DEBUG] [io.openhabcloud.internal.CloudClient] - Finished responding to request 19165226
2025-01-20 20:59:43.647 [DEBUG] [io.openhabcloud.internal.CloudClient] - Socket.IO ping
