When I configure openhab paperui using url http://13.XXX.XXX.XXX:3000 I am able to connect to the openhab cloud connector.
But when I am trying to configure it with the url https://13.XXX.XXX.XXX (or with https://13.XXX.XXX.XXX:3000) I am not able to connect to the cloud instance. I have configured nginx with openssl certificate.
As you mentioned above I tried connecting to the url https://13.XXX.XXX.XXX:443 and even https://13.XXX.XXX.XXX still I am not able to connect to the cloud instance.
“Shutting down openHAB Cloud service connection”.
But when I try to configure openHAB paperui http://13.XXX.XXX.XXX:3000 I will be able to connect to cloud instance.
“Shutting down openHAB Cloud service connection 12:32:27.778 INFO [EventThread] Connected to the openHAB Cloud service (UUID = XXX-XXXX-XXXX-XXXX-XXXX, base URL = http://localhost:8181)”
