Unfortunately I had to re-install my openHAB machine (the SD-card of the RPi got corrupted).
Using Raspbian Jessie and OH 1.7.1 through apt-get
I have added the SYMLINK to be able to use /dev/USBrfxcom and have tested the device with rfxcmd.
$ ls -l /dev/*USB*
crw-rw-rw- 1 root dialout 188, 0 Oct 11 07:26 /dev/ttyUSB0
lrwxrwxrwx 1 root root 7 Oct 10 20:39 /dev/USBrfxcom -> ttyUSB0
I have already added the openhab user to the dial out group:
$ sudo usermod -a -G dialout openhab
I also changed ownership of the symlink:
$ sudo chown root:dialout /dev/USBrfxcom
This is an excerpt from the /etc/init.d/openhab file:
JAVA_ARGS_DEFAULT="-Dosgi.clean=true \
-Declipse.ignoreApp=true \
-Dosgi.noShutdown=true \
-Djetty.port=${HTTP_PORT} \
-Dopenhab.configfile="${OPENHAB_CONF_DIR}/configurations/openhab.cfg" \
-Dopenhab.configdir="${OPENHAB_CONF_DIR}/configurations" \
-Dopenhab.logdir="${OPENHAB_LOG_DIR}" \
-Dsmarthome.userdata="${OPENHAB_USER_DATA_DIR}"
-Djetty.home="${OPENHAB_DIR}" \
-Djetty.port.ssl=${HTTPS_PORT} \
-Djetty.config="${OPENHAB_CONF_DIR}/jetty" \
-Djetty.logs="${OPENHAB_LOG_DIR}" \
-Djetty.rundir="${OPENHAB_DIR}" \
-Dfelix.fileinstall.dir="${OPENHAB_DIR}/addons" \
-Dfelix.fileinstall.filter=.*\\.jar \
-Djava.library.path="${OPENHAB_DIR}/lib" \
-Djava.security.auth.login.config="${OPENHAB_CONF_DIR}/login.conf" \
-Dorg.quartz.properties="${OPENHAB_CONF_DIR}/quartz.properties" \
-Dequinox.ds.block_timeout=240000 \
-Dequinox.scr.waitTimeOnBlock=60000 \
-Dfelix.fileinstall.active.level=4 \
-Dgnu.io.rxtx.SerialPorts=/dev/USBrfxcom \
-Djava.awt.headless=true \
-jar ${LAUNCHER} \
-configuration ${OPENHAB_WORKSPACE_DIR} \
-data ${OPENHAB_WORKSPACE_DIR} \
-console ${TELNET_PORT}"
This is my openhab.cfg
################################ RFXCOM Binding #######################################
# Serial port of RFXCOM interface
# Valid values are e.g. COM1 for Windows and /dev/ttyS0 or /dev/ttyUSB0 for Linux
rfxcom:serialPort=/dev/USBrfxcom
However, I am unable to connect to the device. See excerpt from the logs below.
2015-10-11 07:29:22.709 [INFO ] [.b.r.internal.RFXComConnection] - Connecting to RFXCOM [serialPort='/dev/USBrfxcom' ].
2015-10-11 07:29:22.846 [ERROR] [.b.r.internal.RFXComConnection] - Connection to RFXCOM controller failed.
gnu.io.NoSuchPortException: null
at gnu.io.CommPortIdentifier.getPortIdentifier(CommPortIdentifier.java:273) ~[na:na]
at org.openhab.binding.rfxcom.internal.connector.RFXComSerialConnector.connect(RFXComSerialConnector.java:60) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.connect(RFXComConnection.java:118) ~[na:na]
at org.openhab.binding.rfxcom.internal.RFXComConnection.updated(RFXComConnection.java:103) ~[na:na]
at org.eclipse.equinox.internal.cm.ManagedServiceTracker$1.run(ManagedServiceTracker.java:183) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
at org.eclipse.equinox.internal.cm.SerializedTaskQueue$1.run(SerializedTaskQueue.java:36) [org.eclipse.equinox.cm_1.0.400.v20120522-1841.jar:na]
I assume this has something to do with permissions, but I’m not sure why, where and how.
Could anyone help out?
Thanks in advance.
