I try to install the System Info Binding on Openhab 3.1.0.M2 and I always get the following error:
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-systeminfo': Error:
Error downloading mvn:org.openhab.addons.bundles/org.openhab.binding.systeminfo/3.1.0.M2
To check if this is an issue with this binding i tried to install the AVM Fritz Box Binding. Now I repeatedly get the following error:
[ERROR] [core.karaf.internal.FeatureInstaller] - Failed installing 'openhab-binding-avmfritz, openhab-binding-systeminfo': Error:
It seems as if the installation trial of the System Binding has broken the feature install mechanism.
- How can I fix the feature installation mechanismn? A reboot didn’t work.
- How can I properly install the System Info Binding
Im using Openhab in a Docker container.
