Unable to include z-wave devices anymore
  • Platform information:
    • Hardware: Raspberry 4
    • OS: openHABian (Debian 11)
    • Java Runtime Environment: openjdk 17
    • openHAB version: openHAB 4.3.0.M4 - Milestone Build
Hi!
I am currently having massive problems with my Z-Wave mesh network.
After I excluded a device, I could no longer add it via openHAB.
I then imported a backup via Z-Way. Now I can no longer include five devices (the two devices I wanted to swap and three that weren’t there when the last backup was made).
However, I was able to add the devices via Z-Way without any problems, so the problem seems to be with openHAB.
I would also have no problem adding the devices via Z-Way and then only using them in openHAB, but unfortunately the wrong devices are then displayed, namely those that were previously integrated under these node IDs under openHAB.
I have no idea what to do at the moment. I have already done a soft reset of the controller twice, but that didn’t change anything.
Best regards
Unfortunately, I have just discovered that no more Z-Wave devices are being addressed.
What happens to the Things if I uninstall the Z-Wave binding? Could that help at all?
I have uninstalled and reinstalled the binding and it has made no difference.
Then all I could do was hard reset the controller.
That didn’t make any difference either, at least at first glance. After I re-integrated the devices with Z-Way, they were again found under the wrong names in openHAB. This time, however, I removed the devices in openHAB and then included them again - it worked.
I can’t say whether it would have worked without the hard reset, but at least it’s working again now.
Thanks to everyone who wanted to help!
Best regards
