OK I found the Exclude menu item and clicked it. Woke Node 20 up and when I look in the log I see that Node 30 was removed.
Consulting the manual for the Vision motion sensor I can set the device in exclude mode and a LED is blinking as it should. Just before I clicked the Exclude devices menu item.
This is the event log:
2017-04-27 14:21:42.806 [BindingEvent ] - org.openhab.binding.zwave.event.BindingEvent@7947b6
2017-04-27 14:21:42.841 [ThingUpdatedEvent ] - Thing 'zwave:serial_zstick:152b12ad' has been updated.
This is the openhab log:
2017-04-27 14:21:42.425 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update received
2017-04-27 14:21:42.506 [DEBUG] [zwave.handler.ZWaveControllerHandler] - Controller Configuration update controller_exclude to -232323
2017-04-27 14:21:42.508 [DEBUG] [serialmessage.RemoveNodeMessageClass] - Setting controller into EXCLUSION mode.
2017-04-27 14:21:42.509 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
2017-04-27 14:21:42.510 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2017-04-27 14:21:42.511 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:42.512 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.513 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:21:42.514 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.515 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:21:42.516 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.517 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.518 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.519 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.519 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.520 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.521 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.522 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:21:42.523 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.524 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:21:42.524 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.525 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.526 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.527 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.528 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.529 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.530 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-04-27 14:21:42.531 [DEBUG] [nal.protocol.ZWaveTransactionManager] - getTransactionToSend 6
2017-04-27 14:21:42.533 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 05 00 4B 01 AF 1F
2017-04-27 14:21:42.534 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 05 00 4B 01 AF 1F
2017-04-27 14:21:42.538 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 06
2017-04-27 14:21:42.540 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-04-27 14:21:42.542 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-04-27 14:21:42.543 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=null[0x00], type=ACK[0x02], dest=255, callback=0, payload=
2017-04-27 14:21:42.544 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-04-27 14:21:42.545 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg: ACK
2017-04-27 14:21:42.546 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4B AF 01 00 00 1D
2017-04-27 14:21:42.546 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-04-27 14:21:42.547 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - Message SENT
2017-04-27 14:21:42.548 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:42.549 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: Transaction Start type RemoveNodeFromNetwork
2017-04-27 14:21:42.550 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: TID 234: [WAIT_REQUEST] requiresResponse=true callback: 175
2017-04-27 14:21:42.551 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd class: null
2017-04-27 14:21:42.552 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage started: expected cmd: null
2017-04-27 14:21:42.553 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage Transactions outstanding: 1
2017-04-27 14:21:42.555 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Thu Apr 27 14:21:47 CEST 2017 - 5000ms
2017-04-27 14:21:42.556 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage lastTransaction: TID 234: [WAIT_REQUEST] requiresResponse=true callback: 175
2017-04-27 14:21:42.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-04-27 14:21:42.557 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction lastTransaction outstanding...
2017-04-27 14:21:42.559 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Thu Apr 27 14:21:47 CEST 2017 - 4995ms
2017-04-27 14:21:42.593 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-04-27 14:21:42.593 [DEBUG] [ve.internal.protocol.ZWaveController] - ZWave controller start exclusion
2017-04-27 14:21:42.593 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-04-27 14:21:42.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=1, callback=175, payload=AF 01 00 00
2017-04-27 14:21:42.595 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Start transaction timer to Thu Apr 27 14:21:47 CEST 2017 - 4959ms
2017-04-27 14:21:42.596 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=1, callback=175, payload=AF 01 00 00
2017-04-27 14:21:42.608 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=1, callback=175, payload=AF 01 00 00
2017-04-27 14:21:42.613 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction TID 234: [WAIT_REQUEST] requiresResponse=true callback: 175
2017-04-27 14:21:42.624 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 1
2017-04-27 14:21:42.633 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: TID 234: [WAIT_REQUEST] requiresResponse=true callback: 175
2017-04-27 14:21:42.642 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking TID 234: (Callback 175)
2017-04-27 14:21:42.655 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Callback match!
2017-04-27 14:21:42.664 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Correlated to TID 234: callback 175
2017-04-27 14:21:42.684 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=1, callback=175, payload=AF 01 00 00
2017-04-27 14:21:42.694 [DEBUG] [serialmessage.RemoveNodeMessageClass] - Remove Node: Learn ready.
2017-04-27 14:21:42.699 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInclusionEvent
2017-04-27 14:21:42.806 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: Transaction COMPLETED
2017-04-27 14:21:42.813 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: TransactionAdvance ST: DONE
2017-04-27 14:21:42.815 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: TransactionAdvance WT: null {}
2017-04-27 14:21:42.819 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: TransactionAdvance RX: Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=1, callback=175, payload=AF 01 00 00
2017-04-27 14:21:42.821 [DEBUG] [e.internal.protocol.ZWaveTransaction] - TID 234: TransactionAdvance TO: DONE
2017-04-27 14:21:42.823 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Response processed after 274ms
2017-04-27 14:21:42.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: TID 234: Transaction completed
2017-04-27 14:21:42.827 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: notifyTransactionResponse TID:234 DONE
2017-04-27 14:21:42.830 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2017-04-27 14:21:42.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-04-27 14:21:42.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:42.836 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.838 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:21:42.840 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:21:42.845 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.848 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.850 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.852 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.853 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.856 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:21:42.860 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.861 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:21:42.863 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.865 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.866 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.868 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.870 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:42.871 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:42.873 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:42.875 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-04-27 14:21:42.876 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-04-27 14:21:42.877 [DEBUG] [nal.protocol.ZWaveTransactionManager] - STOP transaction timer
2017-04-27 14:21:46.244 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 4B AF 02 00 00 1E
2017-04-27 14:21:46.248 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-04-27 14:21:46.252 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=2, callback=175, payload=AF 02 00 00
2017-04-27 14:21:46.255 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=2, callback=175, payload=AF 02 00 00
2017-04-27 14:21:46.258 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=2, callback=175, payload=AF 02 00 00
2017-04-27 14:21:46.259 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-04-27 14:21:46.261 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2017-04-27 14:21:46.262 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2017-04-27 14:21:46.263 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ****************** Transaction not correlated
2017-04-27 14:21:46.265 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=2, callback=175, payload=AF 02 00 00
2017-04-27 14:21:46.266 [DEBUG] [serialmessage.RemoveNodeMessageClass] - NODE {}: transaction not correlated for RemoveNodeMessageClass
2017-04-27 14:21:46.268 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-04-27 14:21:46.269 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:46.270 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.272 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:21:46.273 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.274 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:21:46.275 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.276 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.277 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.279 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.280 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.281 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.282 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.283 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:21:46.284 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.285 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:21:46.286 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.288 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.289 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.290 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.291 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.292 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.293 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.295 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-04-27 14:21:46.296 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-04-27 14:21:46.764 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 4B AF 03 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A 9A
2017-04-27 14:21:46.770 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-04-27 14:21:46.774 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=3, callback=175, payload=AF 03 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.779 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=3, callback=175, payload=AF 03 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.783 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=3, callback=175, payload=AF 03 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.784 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-04-27 14:21:46.786 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2017-04-27 14:21:46.786 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 18 00 4B AF 06 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A 9F
2017-04-27 14:21:46.787 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2017-04-27 14:21:46.788 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ****************** Transaction not correlated
2017-04-27 14:21:46.792 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=3, callback=175, payload=AF 03 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.794 [DEBUG] [serialmessage.RemoveNodeMessageClass] - NODE {}: transaction not correlated for RemoveNodeMessageClass
2017-04-27 14:21:46.794 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Response SENT 6
2017-04-27 14:21:46.795 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-04-27 14:21:46.796 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:46.798 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.799 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:21:46.801 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage inputMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=6, callback=175, payload=AF 06 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.801 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.803 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:21:46.804 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.806 [DEBUG] [nal.protocol.ZWaveTransactionManager] - processReceiveMessage past lockMessage: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=6, callback=175, payload=AF 06 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.807 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.809 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.810 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.811 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.812 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.813 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:21:46.814 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.816 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:21:46.817 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.818 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.819 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.820 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.821 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.822 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.824 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.825 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-04-27 14:21:46.826 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-04-27 14:21:46.829 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Received msg Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=6, callback=175, payload=AF 06 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.830 [DEBUG] [nal.protocol.ZWaveTransactionManager] - lastTransaction null
2017-04-27 14:21:46.832 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Checking outstanding transactions: 0
2017-04-27 14:21:46.833 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Last transaction: null
2017-04-27 14:21:46.834 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ****************** Transaction not correlated
2017-04-27 14:21:46.837 [DEBUG] [ve.internal.protocol.ZWaveController] - Incoming Message: Message: class=RemoveNodeFromNetwork[0x4B], type=Request[0x00], dest=6, callback=175, payload=AF 06 00 11 04 07 01 5E 98 86 72 5A 85 59 73 80 71 31 70 84 7A
2017-04-27 14:21:46.838 [DEBUG] [serialmessage.RemoveNodeMessageClass] - NODE {}: transaction not correlated for RemoveNodeMessageClass
2017-04-27 14:21:46.840 [DEBUG] [nal.protocol.ZWaveTransactionManager] - ZWaveReceiveThread queue empty
2017-04-27 14:21:46.841 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:21:46.842 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.843 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:21:46.844 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.845 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:21:46.847 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.848 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.849 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.850 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.851 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.853 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.854 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.855 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:21:46.856 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.857 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:21:46.858 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.859 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.861 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.862 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.863 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:21:46.864 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:21:46.865 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:21:46.866 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction from controllerQueue
2017-04-27 14:21:46.868 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage nothing
2017-04-27 14:22:12.593 [DEBUG] [ve.internal.protocol.ZWaveController] - Ending inclusion mode.
2017-04-27 14:22:12.595 [DEBUG] [ve.internal.protocol.ZWaveController] - Stopping inclusion timer.
2017-04-27 14:22:12.597 [DEBUG] [serialmessage.RemoveNodeMessageClass] - Ending EXCLUSION mode.
2017-04-27 14:22:12.600 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Adding to controller queue
2017-04-27 14:22:12.602 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 255: Added to queue - size 1
2017-04-27 14:22:12.605 [DEBUG] [nal.protocol.ZWaveTransactionManager] - Transaction SendNextMessage 0 out at start
2017-04-27 14:22:12.607 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 17: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.609 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 17: Node not awake!
2017-04-27 14:22:12.612 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 16: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.614 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 16: Node not awake!
2017-04-27 14:22:12.616 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.619 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:22:12.621 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.623 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:22:12.625 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.628 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:22:12.630 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 27: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.632 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 27: Node not awake!
2017-04-27 14:22:12.635 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 20: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.637 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 20: Node not awake!
2017-04-27 14:22:12.639 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:22:12.641 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.644 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:22:12.646 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
2017-04-27 14:22:12.648 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 29: listening == false, frequentlyListening == false, awake == false
2017-04-27 14:22:12.650 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 29: Node not awake!
2017-04-27 14:22:12.653 [DEBUG] [nal.protocol.ZWaveTransactionManager] - NODE 30: Node not found - has this node been removed?!?
As you can see both nodes 20 and 30 are still pinged and still lists in HABmin list of Things. What should I do?
