Iam getting this strange Error. Basic stuff of my Openhab instaalation is working (RP2, OH2 b4).
[ERROR] [org.jupnp.transport.Router ] - Unable to initialize network router: org.jupnp.transport.spi.InitializationException: Could not initialize MulticastReceiverImpl: java.net.BindException: Address already in use
[ERROR] [org.jupnp.transport.Router ] - Cause: org.jupnp.transport.spi.InitializationException: Could not initialize MulticastReceiverImpl: java.net.BindException: Address already in use
[INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
[INFO ] [assic.internal.servlet.WebAppServlet] - Started Classic UI at /classicui/app
[INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /ui
[INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
First stop OH (assuming it hasn’t crashed because of this error).
Then run:
sudo netstat -elf | grep 8080
If there is a process listening on 8080 this will give you a line that reads something like:
tcp6 0 0 :::8080 :::* LISTEN 13213/java
The last column tells you that a program named “java” running on PID 13213 is listening on port 8080 in both TCP and UDP for both TCP v4 and v6.
Repeat for: 8080, 8433, 8101, and maybe 5353 and possibly 1900 and make sure all of them are either don’t exist or if there is something listening on the port.
“java” is not very useful. You can get more information by running:
ps -ef | grep 13213
where 13213 is the PID from the previous command. This will tell you the full path of the process which will usually tell you what it is. In my case, surprise surprise, OH 2.
so its avahi-deamon and deconz thats not good. deCONZ is my Zigbee Software from dresden electronic…
i have no idea what needs a avahi-deamon only other thing is homegear on this device…
what do you think is the easiest why to clear this problems now?
okay i checked it now with openhab running. it think the problem is this here? Or is the Openhab2 Task not even displayed here if the port is already blocked?
the java task is openhab2.
the other task is avahi-deamon, it must be something like apples bonjour service for finding devices. I think it comes with my Homegear Installation.
Now my question why does Openhab2 uses this port and how can i chacne it? I only find instructions for changing the http ports…
mhm okay its not the avahi-daemon its deconz… without it it displays me no error. Openhab2 seems to run perfectly now but still no connection to my.openhab this drives me crazy
I do not know what that port is for or how to change it.
But if OH is starting up without showing errors in the log (or if you are on the latest build it is only complaining about Java Sound) then you have some other problem.
I don’t know because I don’t know the error. You can look at which bundles are running and such. I primarily had you rund the ssh to prove that OH was running at all. Since it is I have no ideas what could be the problem.
188 | Active | 80 | 0.9.0.b1 | Eclipse SmartHome hue Binding
189 | Active | 80 | 0.9.0.b1 | Eclipse SmartHome UPnP Transport Bundle
192 | Active | 80 | 0.9.0.b1 | Eclipse SmartHome Map Transformation Service
193 | Active | 80 | 2.0.0.b4 | my.openHAB Service Bundle
everything acts as it should, the log gives me no errror. I have my UIDD and my Secret. Is there somehow a way to check if there keys are the right ones?
PS: okay i set an higher Loglevel. Now i get some strange errors.
10:31:37.574 [DEBUG] [ache.sshd.common.io.nio2.Nio2Session] - Read 68 bytes
10:31:37.576 [DEBUG] [e.sshd.server.channel.ChannelSession] - Received SSH_MSG_CHANNEL_REQUEST window-change on channel ChannelSess ion[id=0, recipient=0] (wantReply false)
10:31:37.579 [DEBUG] [e.sshd.server.channel.ChannelSession] - window-change for channel 0: (131 - 33), (0, 0)
10:31:42.461 [DEBUG] [io.socket.client.Manager ] - attempting reconnect
10:31:42.463 [DEBUG] [io.socket.client.Manager ] - readyState CLOSED
10:31:42.471 [DEBUG] [io.socket.client.Manager ] - opening https://my.openhab.org:443/
10:31:42.472 [DEBUG] [io.socket.client.Manager ] - connection attempt will timeout after 20000
10:31:42.479 [DEBUG] [io.socket.engineio.client.Socket ] - creating transport 'polling'
10:31:42.480 [DEBUG] [io.socket.engineio.client.Socket ] - setting transport polling
10:31:42.481 [DEBUG] [t.engineio.client.transports.Polling] - polling
10:31:42.482 [DEBUG] [ngineio.client.transports.PollingXHR] - xhr poll
10:31:42.484 [DEBUG] [ngineio.client.transports.PollingXHR] - xhr open GET: https://my.openhab.org/socket.io/?EIO=3&transport=polli ng
10:31:42.486 [DEBUG] [ngineio.client.transports.PollingXHR] - sending xhr with url https://my.openhab.org/socket.io/?EIO=3&transpor t=polling | data null
10:31:42.615 [DEBUG] [io.socket.engineio.client.Socket ] - socket error io.socket.engineio.client.EngineIOException: xhr poll er ror
10:31:42.617 [DEBUG] [io.socket.client.Manager ] - connect_error
10:31:42.620 [DEBUG] [io.socket.client.Manager ] - reconnect attempt error
10:31:42.622 [DEBUG] [io.socket.client.Manager ] - will wait 5000ms before reconnect attempt
10:31:42.625 [DEBUG] [io.socket.engineio.client.Socket ] - socket close with reason: transport error
10:31:42.626 [DEBUG] [t.engineio.client.transports.Polling] - transport not open - deferring close
whats the problem?
i run an unmodified raspbian, so no firewall
i reinstalled openhab2 completly maybe something crashed during the last few updates. At the moment i cant reach myopenhab. I think the website is down?
