Hardware:
Machine: System: Apple product: Macmini3 1 v: 1.0
Mobo: Apple model: Mac-F22C86C8 Bios: Apple v: MM31.88Z.0081.B06.0904271717 date: 04/27/09
CPU: Dual core Intel Core2 Duo P7350 (-MCP-) cache: 3072 KB
flags: (lm nx sse sse2 sse3 sse4_1 ssse3 vmx) bmips: 7959
clock speeds: max: 1995 MHz 1: 1862 MHz 2: 1596 MHz
Drives: HDD Total Size: 120.0GB (9.0% used) ID-1: /dev/sda model: FUJITSU_MHZ2120B size: 120.0GB temp: 54C
Partition: ID-1: / size: 106G used: 6.5G (7%) fs: ext4 dev: /dev/sda2
ID-2: swap-1 size: 4.02GB used: 0.00GB (0%) fs: swap dev: /dev/sda3
Software:
System: Host: ubuntu Kernel: 4.4.0-116-generic x86_64 (64 bit gcc: 5.4.0)
Desktop: Gnome 3.18.5 (Gtk 3.18.9-1ubuntu3.3) Distro: Ubuntu 16.04 xenial
Java Runtime Environment:
openjdk version “1.8.0_163”
OpenJDK Runtime Environment (Zulu 8.28.0.1-linux64) (build 1.8.0_163-b01)
OpenJDK 64-Bit Server VM (Zulu 8.28.0.1-linux64) (build 25.163-b01, mixed mode)
openHAB version:
build-no : Release Build
online-repo : https://dl.bintray.com/openhab/mvn/online-repo/2.2
Repository Version
openhab-distro : 2.2.0
smarthome : 0.10.0.b1
openhab-core : 2.2.0
openhab1-addons : 1.11.0
openhab2-addons : 2.2.0
karaf : 4.1.3
openHAB Log:
tim@ubuntu:~$ cat /var/log/openhab2/openhab.log
2018-03-16 07:02:20.511 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:02:20.531 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:02:20.532 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:16.945 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:16.949 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:16.954 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:17.133 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:17.134 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:17.139 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:22.149 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:22.153 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:22.154 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:52.167 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:10:52.168 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:11:52.185 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:11:52.188 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:11:52.192 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:16:52.204 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:16:52.206 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:16:52.208 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:26:52.219 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:26:52.224 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
2018-03-16 07:26:52.225 [WARN ] [ache.karaf.main.ShutdownSocketThread] - Karaf shutdown socket: Invalid command 'GET / HTTP/1.1' received
openHAB Status:
tim@ubuntu:~$ sudo systemctl status openhab2.service
[sudo] password for tim:
● openhab2.service - openHAB 2 - empowering the smart home
Loaded: loaded (/usr/lib/systemd/system/openhab2.service; enabled; vendor preset: enabled)
Active: active (running) since Fri 2018-03-16 08:31:27 CDT; 3h 17min ago
Docs: http://docs.openhab.org
https://community.openhab.org
Main PID: 1436 (java)
Tasks: 32
Memory: 170.5M
CPU: 27.260s
CGroup: /system.slice/openhab2.service
└─1436 /usr/bin/java -Dopenhab.home=/usr/share/openhab2 -Dopenhab.conf=/etc/openhab2 -Dopenhab.runtime=/usr/share/openhab2/runtime -Dopenhab.userdata=/var/lib/openhab2 -Dopenhab.logdir=/var/log/openha
Mar 16 08:31:27 ubuntu systemd[1]: Started openHAB 2 - empowering the smart home.
Port status:
tim@ubuntu:~$ sudo lsof -i
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
cupsd 1046 root 10u IPv6 18980 0t0 TCP localhost:ipp (LISTEN)
cupsd 1046 root 11u IPv4 18981 0t0 TCP localhost:ipp (LISTEN)
avahi-dae 1053 avahi 12u IPv4 19461 0t0 UDP *:mdns
avahi-dae 1053 avahi 13u IPv6 19462 0t0 UDP *:mdns
avahi-dae 1053 avahi 14u IPv4 19463 0t0 UDP *:58292
avahi-dae 1053 avahi 15u IPv6 19464 0t0 UDP *:60070
cups-brow 1143 root 8u IPv4 19744 0t0 UDP *:ipp
smbd 1217 root 34u IPv6 19837 0t0 TCP *:microsoft-ds (LISTEN)
smbd 1217 root 35u IPv6 19838 0t0 TCP *:netbios-ssn (LISTEN)
smbd 1217 root 36u IPv4 19839 0t0 TCP *:microsoft-ds (LISTEN)
smbd 1217 root 37u IPv4 19840 0t0 TCP *:netbios-ssn (LISTEN)
dhclient 1265 root 6u IPv4 16700 0t0 UDP *:bootpc
sshd 1425 root 3u IPv4 27220 0t0 TCP *:ssh (LISTEN)
sshd 1425 root 4u IPv6 27222 0t0 TCP *:ssh (LISTEN)
java 1436 openhab 27u IPv6 25319 0t0 TCP localhost:40303 (LISTEN)
mysqld 1465 mysql 17u IPv4 23135 0t0 TCP localhost:mysql (LISTEN)
nmbd 1670 root 16u IPv4 22504 0t0 UDP *:netbios-ns
nmbd 1670 root 17u IPv4 22505 0t0 UDP *:netbios-dgm
nmbd 1670 root 18u IPv4 22507 0t0 UDP ubuntu:netbios-ns
nmbd 1670 root 19u IPv4 22508 0t0 UDP 192.168.0.255:netbios-ns
nmbd 1670 root 20u IPv4 22509 0t0 UDP ubuntu:netbios-dgm
nmbd 1670 root 21u IPv4 22510 0t0 UDP 192.168.0.255:netbios-dgm
nmbd 1670 root 23u IPv4 32848 0t0 UDP ubuntu:netbios-ns
nmbd 1670 root 24u IPv4 32849 0t0 UDP 192.168.122.255:netbios-ns
nmbd 1670 root 25u IPv4 32850 0t0 UDP ubuntu:netbios-dgm
nmbd 1670 root 26u IPv4 32851 0t0 UDP 192.168.122.255:netbios-dgm
apache2 1715 root 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 1776 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 1777 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 1778 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 1779 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 1780 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
dnsmasq 2305 libvirt-dnsmasq 3u IPv4 27258 0t0 UDP *:bootps
dnsmasq 2305 libvirt-dnsmasq 5u IPv4 27261 0t0 UDP ubuntu:domain
dnsmasq 2305 libvirt-dnsmasq 6u IPv4 27262 0t0 TCP ubuntu:domain (LISTEN)
firefox 2844 tim 130u IPv4 48688 0t0 TCP ubuntu:44028->46.101.248.207:https (ESTABLISHED)
apache2 2990 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
apache2 3124 www-data 4u IPv6 23717 0t0 TCP *:http (LISTEN)
gvfsd-smb 5060 tim 13u IPv4 60340 0t0 TCP localhost:44756->ubuntu:netbios-ssn (ESTABLISHED)
smbd 5070 root 9u IPv4 60341 0t0 TCP ubuntu:netbios-ssn->localhost:44756 (ESTABLISHED)
I’m totally new to openHAB. I have read over most of the related posts in the forum, but most apply to rPI installs, which i not sure how much they really relate to my setup. I have tried to include everything I have seen asked from the OPs on other posts. To the best of my knowledge the firewall has been completely disabled.
When attempting to access the web UI from the host machine by navigating to localhost:8080, I get a message saying “Unable to connect”.
netstat and lsof both show no signs of anything listening on port 8080.
