after updating my openhab installation to 2.4 I tried the new smartmeter binding to read data from my power meter (Landis+Gyr E650) using the IR reader from volkszähler project.
I receive the following error:
2018-12-29 15:18:43.461 [INFO ] [ding.smartmeter.internal.MeterDevice] - Opening connection to smartmeter:meter:power 2018-12-29 15:19:13.481 [WARN ] [ding.smartmeter.internal.MeterDevice] - Failed to read: The source did not signal an event for 30 seconds and has been terminated.. Closing connection and trying again in 2 seconds...; smartmeter:meter:power java.util.concurrent.TimeoutException: The source did not signal an event for 30 seconds and has been terminated. at io.reactivex.internal.operators.flowable.FlowableTimeoutTimed$TimeoutSubscriber.onTimeout(FlowableTimeoutTimed.java:139) [234:org.openhab.binding.smartmeter:2.4.0] at io.reactivex.internal.operators.flowable.FlowableTimeoutTimed$TimeoutTask.run(FlowableTimeoutTimed.java:170) [234:org.openhab.binding.smartmeter:2.4.0] at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker$BooleanRunnable.run(ExecutorScheduler.java:260) [234:org.openhab.binding.smartmeter:2.4.0] at io.reactivex.internal.schedulers.ExecutorScheduler$ExecutorWorker.run(ExecutorScheduler.java:225) [234:org.openhab.binding.smartmeter:2.4.0] at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) [?:?] at java.util.concurrent.FutureTask.run(FutureTask.java:266) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?] at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?] at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:?] at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:?] at java.lang.Thread.run(Thread.java:748) [?:?]
My thing configuration (…tested different settings without success):
smartmeter:meter:power [port="/dev/ttyUSB1", baudrateChangeDelay=250, refresh=60, mode="ABC"]
Btw: reading data using the script provided by GitHub - ohitz/smartmeter-readout: IEC 62056 smart meter readout in perl works perfectly fine with the following debug output:
DEBUG: Opening /dev/ttyUSB1 DEBUG: Sending sign-on DEBUG: Reading identification DEBUG: Read on serial port: `/LGZ5\2ZMD3104407.B32..' DEBUG: Identification received: `/LGZ5\2ZMD3104407.B32..' DEBUG: Upgrading to 9600 bps. DEBUG: Receiving telegram. ...
Any help would be appreciated.
