I installed the pentair binding and I created two things. One is the serial bridge and the other is a pump on the serial bridge. I tried removing them and it stays in the “removing state”. Hoping someone can either help or point me to a post.
When it is stuck in removing you try again and it will force remove it. The first try will try to gracefully shutdown and remove it but if the binding is uninstalled for example it will get stuck till you try the second time.
Binding is still installed; just trying to remove the things. I’ve tried multiple times but it hasn’t removed it. Do you suggest I remove the binding as well?
Okay, I reread the pop-out dialog and the second attempt it asked if I wanted to do a forced removal. Thanks.
