Unable to retrieve marketplace add-ons (most of the time)
When I try to browse the community Marketplace widgets then in almost all cases it results in an error.
Unable to retrieve marketplace add-ons: Server returned HTTP response code: 429 for URL: Add-on Marketplace - openHAB Community
When I am lucky then I can access the widgets and install one, but if I try to install a 2nd one right after then the list is gone again. Accessing the widgets page with a browser is never a problem.
Running openHAB 5.2.0.M5 but I encountered this issue also in previous builds.
My openHAB runs in a Proxmox LXC container
429 means “too many requests” so for some reason the forum software thinks too many requests are comming from your IP. Are you perhaps behind a CGNAT? There might be many openHAB users comming from the same IP.
There was a time a few months ago where this was a persistent problem for many users but changes were made and we haven’t heard of many users with this same problem recently.
Hi Rich,
I am indeed behind a CG-NAT (Deutsche Glasfaser) and I read the post about this issue that should be fixed in one of the earlier milestone builds. I recently moved from Windows to linux with openHab and also wanted to switch to main UI instead of Sitemaps. The default widgets are a bit limited, so I wanted to try the community widgets, but like I said, it seldomly works for me. I know I can copy the code, but this is not very convenient.
Thank you for your help!
Peter
