Unfortunately mixed success with producing useful logfile output or a new xml file. I can hardly get HABmin to give me the option to reinitialise the Qubino Flush Shutter nodes under HABmin->configuration->things->nodeXX->tools(advance). For the Qubino Flush 2 Relays it is there all the time. I normally did “remove device from controller” to reinit it as said in the doc, so I never payed attention to this before.
After some waiting I got the option in HABmin for node 5, so I did this after setting “log:set DEBUG org.openhab.binding.zwave”. The first output I am getting for node 5 is:
2016-11-14 22:22:07.505 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update received
2016-11-14 22:22:07.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Configuration update action_reinit to -232323.0
2016-11-14 22:22:07.515 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Re-initialising node!
2016-11-14 22:22:07.528 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
2016-11-14 22:22:07.528 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2016-11-14 22:22:07.531 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 5: Init node thread start
2016-11-14 22:22:07.541 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 5: Serializing from file /Users/markus/HausSteuerung/Openhab2/openhab/userdata/zw\
ave/node5.xml
2016-11-14 22:22:07.541 [DEBUG] [l.initialization.ZWaveNodeSerializer] - NODE 5: Error serializing from file: file does not exist.
2016-11-14 22:22:07.542 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Starting initialisation from EMPTYNODE
2016-11-14 22:22:07.542 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - EMPTYNODE: queue length(0), free to send(true)
2016-11-14 22:22:07.542 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - EMPTYNODE try 1: stageAdvanced(false)
2016-11-14 22:22:07.542 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: Initialisation starting
2016-11-14 22:22:07.542 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - advancing to PROTOINFO
2016-11-14 22:22:07.542 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
2016-11-14 22:22:07.542 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2016-11-14 22:22:07.576 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - PROTOINFO try 0: stageAdvanced(true)
2016-11-14 22:22:07.576 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: PROTOINFO - send IdentifyNode
2016-11-14 22:22:07.576 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - queued packet. Queue length is 1
2016-11-14 22:22:07.576 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 142. Queue={}
2016-11-14 22:22:07.576 [DEBUG] [ve.internal.protocol.ZWaveController] - NODE 5: Init node thread finished
I can confirm that the original “node5_orig.xml” file (attached the backup copy) was deleted when I re-initialised the node. Later, after tons of other (seemingly unrelated debug output) I find:
2016-11-14 22:22:12.111 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 144. Queue={}
2016-11-14 22:22:12.111 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 143
2016-11-14 22:22:12.111 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 41 05 BF
2016-11-14 22:22:12.111 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 41 05 BF
2016-11-14 22:22:12.113 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 01 41 D3 9C 01 04 11 07 EA
2016-11-14 22:22:12.114 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-11-14 22:22:12.114 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 01 41 D3 9C 01 04 11 07 EA
2016-11-14 22:22:12.114 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 09 01 41 D3 9C 01 04 11 07 EA
2016-11-14 22:22:12.114 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=IdentifyNode[0x41], type=Response[0x01], priority=High, dest=255, callback=0, payload=D3 9C 01 04 11 07
2016-11-14 22:22:12.114 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: ProtocolInfo
2016-11-14 22:22:12.114 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Listening = true
2016-11-14 22:22:12.114 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Routing = true
2016-11-14 22:22:12.114 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Beaming = true
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Version = 4
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: FLIRS = false
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Security = false
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Max Baud = 40000
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Basic = Routing Slave
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Generic = Multi-Level Switch
2016-11-14 22:22:12.115 [DEBUG] [rialmessage.IdentifyNodeMessageClass] - NODE 5: Specific = Motor Control Class C
2016-11-14 22:22:12.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class NO_OPERATION
2016-11-14 22:22:12.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class NO_OPERATION, endpoint null created
2016-11-14 22:22:12.115 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Version = 1, version set. Enabling extra functionality.
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class NO_OPERATION to the list of supported command classes.
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class BASIC
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class BASIC, endpoint null created
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class BASIC to the list of supported command classes.
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class SWITCH_MULTILEVEL
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class SWITCH_MULTILEVEL, endpoint null created
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class SWITCH_MULTILEVEL to the list of supported command classes.
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class SWITCH_BINARY
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class SWITCH_BINARY, endpoint null created
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class SWITCH_BINARY to the list of supported command classes.
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class VERSION
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class VERSION, endpoint null created
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class VERSION to the list of supported command classes.
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Creating new instance of command class MANUFACTURER_SPECIFIC
2016-11-14 22:22:12.116 [DEBUG] [tocol.commandclass.ZWaveCommandClass] - NODE 5: Command class MANUFACTURER_SPECIFIC, endpoint null created
2016-11-14 22:22:12.116 [DEBUG] [ng.zwave.internal.protocol.ZWaveNode] - NODE 5: Adding command class MANUFACTURER_SPECIFIC to the list of supported command classes.
2016-11-14 22:22:12.117 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=IdentifyNode[0x41], type=Request[0x00], priority=High, dest=255, callback=\
0, payload=05
2016-11-14 22:22:12.117 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=IdentifyNode[0x41], type=Response[0x01], priority=High, dest=255, callback\
2016-11-14 22:22:12.117 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=IdentifyNode, callback id=0, expected=IdentifyNode, cancelled=false transaction c\
omplete!
2016-11-14 22:22:12.117 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-11-14 22:22:12.117 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - PROTOINFO: Transaction complete (IdentifyNode:Request) success(true)
2016-11-14 22:22:12.117 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - checking initialisation queue. Queue size 1.
2016-11-14 22:22:12.117 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - message removed from queue. Queue size 0.
2016-11-14 22:22:12.117 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - PROTOINFO: queue length(0), free to send(true)
2016-11-14 22:22:12.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Initialisation retry timer started 5000
2016-11-14 22:22:12.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - PROTOINFO try 1: stageAdvanced(false)
2016-11-14 22:22:12.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - advancing to INIT_NEIGHBORS
2016-11-14 22:22:12.118 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
2016-11-14 22:22:12.118 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2016-11-14 22:22:12.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - INIT_NEIGHBORS try 0: stageAdvanced(true)
2016-11-14 22:22:12.118 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: INIT_NEIGHBORS - send RoutingInfo
2016-11-14 22:22:12.119 [DEBUG] [almessage.GetRoutingInfoMessageClass] - NODE 5: Request routing info
2016-11-14 22:22:12.119 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - queued packet. Queue length is 1
2016-11-14 22:22:12.119 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 144. Queue={}
2016-11-14 22:22:12.119 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 7ms/4381ms.
2016-11-14 22:22:12.119 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 143
2016-11-14 22:22:12.120 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 07 00 80 05 00 00 03 7E
2016-11-14 22:22:12.120 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 07 00 80 05 00 00 03 7E
2016-11-14 22:22:12.123 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 20 01 80 EF E3 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6A
2016-11-14 22:22:12.123 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-11-14 22:22:12.124 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 20 01 80 EF E3 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00\
6A
2016-11-14 22:22:12.124 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 20 01 80 EF E3 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 6A
2016-11-14 22:22:12.124 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=GetRoutingInfo[0x80], type=Response[0x01], priority=High, dest=255, callback=0, payload=EF E3 38 00 00 00 00 0\
2016-11-14 22:22:12.124 [DEBUG] [almessage.GetRoutingInfoMessageClass] - NODE 5: Got NodeRoutingInfo request.
2016-11-14 22:22:12.125 [DEBUG] [almessage.GetRoutingInfoMessageClass] - NODE 5: Neighbor nodes: 1 2 3 4 6 7 8 9 10 14 15 16 20 21 22
2016-11-14 22:22:12.125 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveNetworkEvent
2016-11-14 22:22:12.125 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveNetworkEvent
2016-11-14 22:22:12.125 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=GetRoutingInfo[0x80], type=Request[0x00], priority=High, dest=255, callbac\
k=0, payload=05 00 00 03
2016-11-14 22:22:12.125 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=GetRoutingInfo[0x80], type=Response[0x01], priority=High, dest=255, callba\
ck=0, payload=EF E3 38 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
2016-11-14 22:22:12.125 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=GetRoutingInfo, callback id=0, expected=GetRoutingInfo, cancelled=false transacti\
on complete!
2016-11-14 22:22:12.125 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - INIT_NEIGHBORS: Transaction complete (GetRoutingInfo:Request) success(true)
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - checking initialisation queue. Queue size 1.
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - message removed from queue. Queue size 0.
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - INIT_NEIGHBORS: queue length(0), free to send(true)
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Initialisation retry timer started 5000
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - INIT_NEIGHBORS try 1: stageAdvanced(false)
2016-11-14 22:22:12.125 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - advancing to FAILED_CHECK
2016-11-14 22:22:12.125 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
2016-11-14 22:22:12.125 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2016-11-14 22:22:12.126 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - FAILED_CHECK try 0: stageAdvanced(true)
2016-11-14 22:22:12.126 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 5: Requesting IsFailedNode status from controller.
2016-11-14 22:22:12.126 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - queued packet. Queue length is 1
2016-11-14 22:22:12.126 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 144. Queue={}
2016-11-14 22:22:12.127 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 7ms/4381ms.
2016-11-14 22:22:12.127 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 143
2016-11-14 22:22:12.127 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 00 62 05 9C
2016-11-14 22:22:12.127 [DEBUG] [ing.zwave.handler.ZWaveSerialHandler] - NODE 255: Sending REQUEST Message = 01 04 00 62 05 9C
2016-11-14 22:22:12.128 [DEBUG] [WaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 62 00 98
2016-11-14 22:22:12.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
2016-11-14 22:22:12.129 [DEBUG] [wave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 62 00 98
2016-11-14 22:22:12.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Process Message = 01 04 01 62 00 98
2016-11-14 22:22:12.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Message: class=IsFailedNodeID[0x62], type=Response[0x01], priority=High, dest=255, callback=0, payload=00
2016-11-14 22:22:12.129 [DEBUG] [rialmessage.IsFailedNodeMessageClass] - NODE 5: Is currently marked as healthy by the controller
2016-11-14 22:22:12.129 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=IsFailedNodeID[0x62], type=Request[0x00], priority=High, dest=255, callbac\
k=0, payload=05
2016-11-14 22:22:12.129 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=IsFailedNodeID[0x62], type=Response[0x01], priority=High, dest=255, callba\
ck=0, payload=00
2016-11-14 22:22:12.129 [DEBUG] [.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=IsFailedNodeID, callback id=0, expected=IsFailedNodeID, cancelled=false transacti\
on complete!
2016-11-14 22:22:12.129 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - FAILED_CHECK: Transaction complete (IsFailedNodeID:Request) success(true)
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - checking initialisation queue. Queue size 1.
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - message removed from queue. Queue size 0.
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - FAILED_CHECK: queue length(0), free to send(true)
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Initialisation retry timer started 5000
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - FAILED_CHECK try 1: stageAdvanced(false)
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - advancing to WAIT
2016-11-14 22:22:12.130 [DEBUG] [ve.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveInitializationStateEvent
2016-11-14 22:22:12.130 [DEBUG] [ding.zwave.handler.ZWaveThingHandler] - NODE 5: Got an event from Z-Wave network: ZWaveInitializationStateEvent
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - WAIT try 0: stageAdvanced(true)
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: WAIT - Listening=true, FrequentlyListening=false
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: WAIT - Advancing
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - advancing to PING
2016-11-14 22:22:12.130 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: loop - PING try 0: stageAdvanced(true)
2016-11-14 22:22:12.131 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer: PING - send NoOperation
2016-11-14 22:22:12.131 [DEBUG] [ndclass.ZWaveNoOperationCommandClass] - NODE 5: Creating new message for command No Operation
2016-11-14 22:22:12.132 [DEBUG] [alization.ZWaveNodeInitStageAdvancer] - NODE 5: Node advancer - queued packet. Queue length is 1
2016-11-14 22:22:12.132 [DEBUG] [ve.internal.protocol.ZWaveController] - Message queued. Queue length = 144. Queue={}
2016-11-14 22:22:12.132 [DEBUG] [ocol.ZWaveController$ZWaveSendThread] - NODE 255: Response processed after 5ms/4381ms.
I did not get the node5.xml file recreated, unfortunately. At the end I tried restarting the system after some waiting. No success either.
Not sure how helpful this is, I am still struggling with the system which keeps me from producing seemingly more useful information.
