I tried to upgrade to 3.2 but neither openhabian-config nor apt get-update and apt-get upgrade show me that there’s a new version available.
If I try to upgrade to 3.2 through the openhabian config menu, the tool tells me that openhabian 3 is already installed and migration will be canceled.
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name Version Architecture Description
ii openhab 3.1.1-1 all openhab
openhab.list does not exist, nor any other version of the file, which is strange. I’ve recreated the file with
echo 'deb https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab.list
apt-get update does not show any errors.
I updated to 3.1.1 a week ago with apt get and apt upgrade, so I don’t know how the list file could disappear?
could be that the name on your system is different. Just check the content of other files.
With sudo apt-get -s upgrade you can check what would be updated when you would run the same command but without the -s ( simulate ) switch.
In case you just added the openhab repo you need to run apt-get update before but I assume that you have done that already.
A few month ago I installed OpenHABian with OpenHAB 3.1.0 on a new fresh Raspberry PI 4B.
Today I followed the update instructions on the release notes for 3.2.0 which says, you have to select menu entry “03 - Install OpenHAB”. After that I got the message, that openhab 3 is already installed…
That just updates syncs the repository ‘database’ to a local file - which is necessary to be done before doing the real work.
To do the update you need to run sudo apt-get upgrade
In case you don’t want to do that for you whole system at the related package to be updated a the end of the command.
@Wolfang, I have a similar issue, unable to upgrade to 3.2.
I tried both with configure-openhab and with apt upgrade, but there is an error I am not able to manage.
I’d appreciate help.
Below the log
login as: xxxx
|_| openHAB 3.1.0 - Release Build
bruno@openhabian:~ $ sudo openhabian-config
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
vlc-bin : Depends: libvlc-bin (= 3.0.12-0+deb10u1+rpt2+arm64) but 3.0.12-0+deb10u1+rpt3 is to be installed
vlc-plugin-skins2 : Depends: vlc-plugin-qt (= 3.0.12-0+deb10u1+rpt3) but 3.0.12-0+deb10u1+rpt2+arm64 is to be installed
E: Broken packages
+ echo FAILED
FAILED
+ return 1
+ '[' 1 -ne 0 ']'
+ whiptail --msgbox 'There was an error or interruption during the execution of:\n "02 | Upgrade System"\n\nPlease try again. If the error persists, please read /opt/openhabian/docs/openhabian-DEBUG.md or https://github.com/openhab/openhabian/blob/main/docs/openhabian-DEBUG.md how to proceed.' 14 80
+ return 0
+ true
bruno@openhabian:~ $ sudo apt-get upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
E: Broken packages
bruno@openhabian:~ $ dpkg -l openhab
ii openhab 3.1.0-1 all openhab
Did you try either to just upgrade openhab: sudo apt-get upgrade openhab
resp. in case you also have the addons installed: sudo apt-get upgrade openhab openhab-addons
Other possibility might be to first deinstall the packages with the unmet dependencies ( vlc-bin, vlc-plugin-skin2 ) and thendothe upgrade.
