Hi everybody,
after 2 days of playing around with my raspberry pi and openhab I received the Zwave USB stick.
Unfortunately I am not able to make that one work. Openhab ist installed, habmin and the iPhone App. So far the dry runs where working. Now to the problem with the stick.
The stick shows up in the lsusb as Device 13 pi@raspberrypi:/opt $ lsusb Bus 001 Device 013: ID 0658:0200 Sigma Designs, Inc. Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
dmesg -c looks ok to me as well
[ 4021.775595] usb 1-1.2: new full-speed USB device number 13 using dwc_otg
[ 4021.880865] usb 1-1.2: New USB device found, idVendor=0658, idProduct=0200
[ 4021.880891] usb 1-1.2: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4021.880909] usb 1-1.2: SerialNumber: 12345678-9012-3456-7890-123456789012
Unfortunately the device does not show up as /dev/ttyACM0
pi@raspberrypi:/opt $ ls -la /dev/ttyA*
crw–w---- 1 root tty 204, 64 Dec 18 14:17 /dev/ttyAMA0
Here is the tail when I start openhab
2015-12-19 13:10:05.737 [WARN ] [.o.c.p.e.PersistenceExtensions] - There is no queryable persistence service registered with the name ‘rrd4j’
2015-12-19 13:10:09.649 [INFO ] [.service.AbstractActiveService] - NTP Refresh Service has been started
2015-12-19 13:10:10.055 [INFO ] [.service.AbstractActiveService] - HTTP Refresh Service has been started
2015-12-19 13:10:10.876 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, port = /dev/ttyAMA0
2015-12-19 13:10:10.878 [INFO ] [.z.internal.ZWaveActiveBinding] - Update config, healtime = 2
2015-12-19 13:10:10.883 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been started
2015-12-19 13:10:10.986 [INFO ] [b.z.i.protocol.ZWaveController] - Starting Z-Wave controller
2015-12-19 13:10:10.987 [INFO ] [b.z.i.protocol.ZWaveController] - Z-Wave timeout is set to 5000ms. Soft reset is false.
2015-12-19 13:10:10.989 [INFO ] [b.z.i.protocol.ZWaveController] - Connecting to serial port /dev/ttyAMA0
2015-12-19 13:10:11.463 [INFO ] [g.openhab.model.script.Weather] - Temperature evolved of null degrees.
2015-12-19 13:10:11.468 [ERROR] [o.o.c.s.ScriptExecutionThread ] - Error during the execution of rule ‘Compute humidex’: Cannot cast org.openhab.core.types.UnDefType to org.openhab.core.library.types.DecimalType
2015-12-19 13:10:16.723 [ERROR] [b.z.i.protocol.ZWaveController] - Serial Error: Port /dev/ttyAMA0 does not exist
2015-12-19 13:10:21.696 [INFO ] [.service.AbstractActiveService] - ZWave Refresh Service has been shut down
Here is the zwave.log
2015-12-19 13:28:34.293 [DEBUG] [.zwave.internal.ZWaveActivator:36 ]- Z-Wave binding started. Version 1.8.0.201508211938
2015-12-19 13:28:34.423 [DEBUG] [.z.internal.ZWaveActiveBinding:175 ]- ConverterHandler not initialised. Polling disabled.
2015-12-19 13:28:34.432 [INFO ] [.z.internal.ZWaveActiveBinding:325 ]- Update config, port = /dev/ttyAMA0
2015-12-19 13:28:34.436 [INFO ] [.z.internal.ZWaveActiveBinding:330 ]- Update config, healtime = 2
2015-12-19 13:28:34.439 [DEBUG] [.z.internal.ZWaveActiveBinding:282 ]- Initialising zwave binding
2015-12-19 13:28:34.539 [INFO ] [b.z.i.protocol.ZWaveController:146 ]- Starting Z-Wave controller
2015-12-19 13:28:34.541 [INFO ] [b.z.i.protocol.ZWaveController:154 ]- Z-Wave timeout is set to 5000ms. Soft reset is false.
2015-12-19 13:28:34.542 [INFO ] [b.z.i.protocol.ZWaveController:320 ]- Connecting to serial port /dev/ttyAMA0
2015-12-19 13:28:34.644 [ERROR] [b.z.i.protocol.ZWaveController:342 ]- Serial Error: Port /dev/ttyAMA0 does not exist
Btw. I added the openhab user to dial out.
Any suggestions what I missed or what I could do next?
Given that you’re running as a service, I’m not 100% sure what user is actually being used - it probably is root, but if you run top, that should list the processes and it will show you the user being used.
It probably is root though, so I’m not sure why the stick wouldn’t work… (sorry).
Thats strange. I use the same stick and it shows up as /dev/ttyACM0. Do you have another Computer where you can test, if the stick is recognized there?
Okay, first try the other steps suggested, if you still can’t find the port, do this:
type dmesg on the console,
take a look at the output and find USB ACM device
to the left of this there should be the port, in my case /dev/ttyACM0:
[ 5.793385] cdc_acm 1-1.5:1.0: ttyACM0: USB ACM device
Second approach: grab the timestamps of all your tty* devices, usually the z-wave controller has the newest timestamp from the last reboot (that is my “dummy” approach)
Yes, I fully set-up openhab on my macbook and I got the stick to work there. It is really strange that it is not coming up in the raspberry. I will start with a new installation on the RPi2 again.
2.955689] usb 1-1.5: new full-speed USB device number 4 using dwc_otg [ 3.055685] usb 1-1.5: device descriptor read/64, error -32 [ 3.245683] usb 1-1.5: device descriptor read/64, error -32 [ 3.435686] usb 1-1.5: new full-speed USB device number 5 using dwc_otg [ 3.535681] usb 1-1.5: device descriptor read/64, error -32 [ 3.725684] usb 1-1.5: device descriptor read/64, error -32 [ 3.915688] usb 1-1.5: new full-speed USB device number 6 using dwc_otg [ 4.335683] usb 1-1.5: device not accepting address 6, error -32 [ 4.615687] usb 1-1.5: new full-speed USB device number 8 using dwc_otg [ 4.740814] usb 1-1.5: New USB device found, idVendor=0658, idProduct=0200 [ 4.749371] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=1 [ 4.758325] usb 1-1.5: SerialNumber: 12345678-9012-3456-7890-123456789012
[quote=“blackstar511, post:19, topic:5198, full:true”]
sihui, can you make sense out of this?[/quote]
Nope, not at all, but I can tell you I have the same messages and my stick (also a ZME_UZB1) is working fine …
[ 2.945748] usb 1-1.5: new full-speed USB device number 4 using dwc_otg
[ 3.035736] usb 1-1.5: device descriptor read/64, error -32
[ 3.225770] usb 1-1.5: device descriptor read/64, error -32
[ 3.445736] usb 1-1.5: new full-speed USB device number 5 using dwc_otg
[ 3.555718] usb 1-1.5: device descriptor read/64, error -32
[ 3.775716] usb 1-1.5: device descriptor read/64, error -32
[ 3.985725] usb 1-1.5: new full-speed USB device number 6 using dwc_otg
[ 4.790969] usb 1-1.5: New USB device found, idVendor=0658, idProduct=0200
[ 4.790983] usb 1-1.5: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[ 4.790993] usb 1-1.5: SerialNumber: 12345678-9012-3456-7890-123456789012
So it still could be a permission error, so try what @chris suggested and run with root.
