In preparation for migration to OH4, I created a clean new install using openhabian. In the process, I had hoped based on xxxxx that both mirroring and Amanda would be set up, but it appears that only mirroring was actually set up.
I read this 2 year old thread openHABian unattended - amanda not installed - #18 by narf27. Rather than reopening an old thread, I thought i would start this new one.
Here is the relevant section of \boot\openhabian.conf
# external SD card device to backup and mirror the internal SD card to
backupdrive=/dev/sda
storageconfig=openhab-dir
storagedir=/storage
storagetapes=15
storagecapacity=1024
And from /boot/first-boot.log
$ install -m 755 /opt/openhabian/includes/SD/set-partuuid /usr/local/sbin
2023-07-04_09:40:26_CDT [openHABian] Setting up automated SD mirroring and backup...
$ apt-get install --yes -o DPkg::Lock::Timeout=60 gdisk
Reading package lists...
Building dependency tree...
Reading state information...
gdisk is already the newest version (1.0.6-1.1).
gdisk set to manually installed.
0 upgraded, 0 newly installed, 0 to remove and 4 not upgraded.
Failed to stop storage.mount: Unit storage.mount not loaded.
Checking that no-one is using this disk right now ... OK
Disk /dev/sda: 58.24 GiB, 62534975488 bytes, 122138624 sectors
Disk model: Storage Device
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0x4d721b07
Old situation:
Device Boot Start End Sectors Size Id Type
/dev/sda1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/sda2 532480 60751871 60219392 28.7G 83 Linux
/dev/sda3 60751872 122138623 61386752 29.3G 83 Linux
>>> Script header accepted.
>>> Created a new DOS disklabel with disk identifier 0x5c840b2f.
/dev/sda1: Created a new partition 1 of type 'W95 FAT32 (LBA)' and of size 256 MiB.
Partition #1 contains a vfat signature.
/dev/sda2: Created a new partition 2 of type 'Linux' and of size 14.2 GiB.
Partition #2 contains a ext4 signature.
/dev/sda3: Created a new partition 3 of type 'Linux' and of size 43.8 GiB.
/dev/sda4: Done.
New situation:
Disklabel type: dos
Disk identifier: 0x5c840b2f
/dev/sda2 532480 30244863 29712384 14.2G 83 Linux
/dev/sda3 30244864 122138623 91893760 43.8G 83 Linux
The partition table has been altered.
Calling ioctl() to re-read partition table.
Syncing disks.
$ mke2fs -F -t ext4 /dev/sda3
mke2fs 1.46.2 (28-Feb-2021)
Creating filesystem with 11486720 4k blocks and 2875392 inodes
Filesystem UUID: 6a2dea56-e977-4859-8781-f63e6ec34a3b
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208,
4096000, 7962624, 11239424
Allocating group tables: done
Writing inode tables: done
Creating journal (65536 blocks): done
Writing superblocks and filesystem accounting information: done
$ chmod 644 /etc/systemd/system/storage.mount
$ systemctl -q daemon-reload
$ systemctl enable --now storage.mount
Created symlink /etc/systemd/system/local-fs.target.wants/storage.mount → /etc/systemd/system/storage.mount.
Created symlink /etc/systemd/system/zram-config.service.wants/storage.mount → /etc/systemd/system/storage.mount.
Taking a raw partition copy, be prepared this may take long such as 20-30 minutes for a 16 GB SD card
$ dd if=/dev/mmcblk0p1 bs=1M of=/dev/sda1 status=progress
226492416 bytes (226 MB, 216 MiB) copied, 5 s, 45.2 MB/s
256+0 records in
256+0 records out
268435456 bytes (268 MB, 256 MiB) copied, 36.7534 s, 7.3 MB/s
$ dd if=/dev/mmcblk0p2 bs=1M of=/dev/sda2 status=progress
15211692032 bytes (15 GB, 14 GiB) copied, 1610 s, 9.4 MB/s
14508+0 records in
14508+0 records out
15212740608 bytes (15 GB, 14 GiB) copied, 1686.7 s, 9.0 MB/s
yes: standard output: Broken pipe
$ e2fsck -y /dev/sda2
e2fsck 1.46.2 (28-Feb-2021)
rootfs: clean, 75157/908352 files, 1161504/3714048 blocks
$ tune2fs /dev/sda2 -U random
tune2fs 1.46.2 (28-Feb-2021)
This operation requires a freshly checked filesystem.
Please run e2fsck -f on the filesystem.
FAILED (set random UUID)
$ fsck -y -t ext4 /dev/sda2
fsck from util-linux 2.36.1
$ install -m 644 -t /etc/systemd/system /opt/openhabian/includes/SD/sdrawcopy.timer /opt/openhabian/includes/SD/sdrsync.timer
$ install -m 755 /opt/openhabian/includes/SD/mirror_SD /usr/local/sbin
From what I can tell, it looks like there was sufficient space allocated to sda3 for Amanda.
After rereading the documentation, I’m thinking that perhaps I might need to specify the amount of storage for Amanda to use:
“ Use storagecapacity=xxx to override how much space to consume at most for Amanda backup storage (in MB). openHABian will create partitions 1 and 2 to be mirrors of your internal card and will assign the remaining space to another partition that you can use for storage. NOTE: if you do and if the remaining space is sufficient, selecting this will also result in setting up the Amanda backup system on that extra space.”
Based on the advice to not back up the raw SD card if it has a capacity of greater than 8 GB (mine is 16 GB), and since I don’t have any idea how much space to use, it appears I should enter 1024, based on:
“ * “Backup raw SD card?” (not asked if you selected AWS S3 storage) Answer “yes” if you want to create raw disk backups of your SD card. This is only recommended if your SD card is 8GB or less in size, otherwise the backup can take too long. You can always add/remove this by editing ${confdir}/disklist at a later time.”
And
“ If you don’t have any idea and chose to NOT backup your SD card, enter 1024 (= 1 GByte).”
After going through all of the above, I see that I had storagecapacity=1024 in openhabian.conf, which brings me back to why I created this thread in the first place.
I’m sure I missed something, but I can’t figure out what it is.
Any suggestions on what I am missing on setting up Amanda in unattended mode?
P.S. I’m running openHAB 4.0.1 on a Pi 4B running openhabian. Here is the system info from the UI:
runtimeInfo:
version: 4.0.1
buildString: Release Build
locale: en-US
systemInfo:
configFolder: /etc/openhab
userdataFolder: /var/lib/openhab
logFolder: /var/log/openhab
javaVersion: 17.0.7
javaVendor: Raspbian
osName: Linux
osVersion: 6.1.21-v8+
osArchitecture: arm
availableProcessors: 4
freeMemory: 105993872
totalMemory: 778567680
startLevel: 100
bindings: null
clientInfo:
device:
ios: true
android: false
androidChrome: false
desktop: false
iphone: false
ipod: false
ipad: true
edge: false
ie: false
firefox: false
macos: false
windows: false
cordova: false
phonegap: false
electron: false
nwjs: false
os: ios
osVersion: 13.0.0
webView: true
webview: true
standalone: true
pixelRatio: 2
prefersColorScheme: light
isSecureContext: false
locationbarVisible: true
menubarVisible: true
navigator:
cookieEnabled: true
deviceMemory: N/A
hardwareConcurrency: 8
language: en-US
languages:
- en-US
onLine: true
platform: MacIntel
screen:
width: 1024
height: 1366
colorDepth: 32
support:
touch: true
pointerEvents: true
observer: true
passiveListener: true
gestures: true
intersectionObserver: true
themeOptions:
dark: light
filled: true
pageTransitionAnimation: default
bars: light
homeNavbar: default
homeBackground: default
expandableCardAnimation: default
userAgent: Mozilla/5.0 (Macintosh; Intel Mac OS X 10_15_7) AppleWebKit/605.1.15
(KHTML, like Gecko)
timestamp: 2023-08-05T02:18:58.947Z
(I noticed that is says binds are null. I am using many bindings, and they all seem to be working, so I’m sure what’s up with the null.)
