Hi guys,
I am finally playing around with HABot and it really is great! Thanks so much for that, it does immediately adds tremendous show-off-potential ![]()
I am confused though, I have read the walkthrough, especially part 2, but it does not want to do what I expect.
I have this simple setup:
Group G_Sensors "Sensoren" ["Measurement"]
Group G_Humidity "Luftfeuchtigkeit" (G_Sensors) ["Humidity"]
Group G_OG "OG" ["FirstFloor"]
Group G_Lukasbedroom "Lukas Zimmer" (G_OG) ["Room"] { synonyms="Kinderzimmer" }
Number lukasbedroom_Sensor2_Humidity "Kinderzimmer Luftfeuchtigkeit [%d %%]" (G_Lukasbedroom, G_Humidity) {channel="zwave:device:1eb9918f:node13:sensor_relhumidity" }
And If I ask the bot to find “wie ist die Luftfeuchtigkeit im Kinderzimmer” or “wie ist die Luftfeuchtigkeit im Lukas Zimmer”, it cannot tell.
I eventually created a custom Card that contains both locations, Kinderzimmer and Lukas Zimmer, as well es objects feuchtigkeit and luftfeuchtigkeit, but even that only works if I ask “Wie ist die (Luft-)Feuchtigkeit”, and not “Wie ist die (Luft-)Feuchtigkeit im Kinderzimmer” . As soon as I add the Location, it will fail.
It seems to work a little, because Luftfeuchtigkeit is not a common tag, I assume it was determined by the parents group’s name.
Then, to add to the strangeness, I changed the tag of G_Lukasbedroom from [“Room”] to [“Bedroom”], and it finally understands “Wie ist die Luftfeuchtigkeit im Lukas Zimmer”… But it does not understand “Wie ist die Luftfeuchtigkeit im Kinderzimmer”..
Can somebody spot my problem?
Thanks in Advance,
best regards
PhiL
